Local Time 11:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects
  Topics Started By Replies Views
Last Post By
Sticky Topics
Forum upgrade Gizmo, 05/07/2019 314 367646 wiseguy  04:07am 12 Dec 2025
Forum Guidelines Gizmo, 11/12/2011 2 536539   02:49pm 16 Dec 2015
Photos Geoffg, 28/01/2019 138 57922 DaveJacko  10:28pm 19 Oct 2026
Part suppliers. Gizmo, 10/01/2016 30 76070 WhiteWizzard  12:32pm 03 May 2025
Micromite MMBasic Library(s) Gizmo, 14/12/2014 1 87083 lizby  03:55pm 26 Nov 2021
Read Me. Guidelines for this section. Gizmo, 24/11/2011 7 69855 GregZone  09:03pm 06 Jun 2020
Normal Topics
   Page 74 of 469
H7 is most compatible to...... gadgetjack, 08/08/2024 31 4005 Wolfgang  03:34pm 29 Aug 2024
Electride  ( f77 -ish) on rp2350 zeitfest, 26/08/2024 2 1604 zeitfest  01:12pm 29 Aug 2024
RP2350 PSRAM: how to wire, how to use? matherp, 22/08/2024 26 5514 Mixtel90  07:38am 29 Aug 2024
Pimoroni Pico Plus 2 PhenixRising, 28/08/2024 0 1457 PhenixRising  11:05am 28 Aug 2024
QSPI... Grogster, 30/01/2022 3 3361 Volhout  09:13am 28 Aug 2024
SSD1963 SPI LCD or not Bryan1, 28/08/2024 2 1534 Mixtel90  06:58am 28 Aug 2024
RP2350 and 5V tolerance PhenixRising, 27/08/2024 6 3782 stanleyella  07:51pm 27 Aug 2024
PicoMite 3D MonsterMaze Martin H., 11/04/2024 21 4298 Martin H.  10:39am 27 Aug 2024
Anyone done CAN Bus communications Hans, 25/08/2024 15 2373 PhenixRising  05:48am 27 Aug 2024
PicoMite V5.09.00 release candidates matherp, 24/03/2024 251 21078 Volhout  04:35pm 26 Aug 2024
2 new Picos announced! Bleep, 09/08/2024 110 9399 Volhout  02:16pm 26 Aug 2024
MM-Basic Sprite Editor Martin H., 02/12/2022 36 7066 Martin H.  05:52pm 25 Aug 2024
PIO and WebMite questions homa, 13/08/2024 11 2944 Volhout  05:47pm 25 Aug 2024
RP2350B 64 Pin development board circuit, 24/08/2024 11 3520 Mixtel90  06:41am 25 Aug 2024
CMM2: KEYDOWN() and internationalisation thwill, 24/08/2024 0 1642 thwill  09:27am 24 Aug 2024
LOAD command question electricat, 23/08/2024 21 2655 electricat  04:30pm 23 Aug 2024
Nothing to do with uC: measuring parasitic draw from car battery thwill, 16/08/2024 31 3382 Mixtel90  06:48am 23 Aug 2024
Measuring PH in MMBasic Bryan1, 12/08/2024 23 3461 electricat  04:51am 23 Aug 2024
MMEdit is on the move. TassyJim, 14/08/2024 20 3505 PeteCotton  07:47pm 22 Aug 2024
PicoMiteHDMI firmware - first cut matherp, 22/08/2024 5 2649 Bleep  04:10pm 22 Aug 2024
Pico 2 max cpuspeed (asking for a friend) PhenixRising, 22/08/2024 7 1942 PhenixRising  03:19pm 22 Aug 2024
What HTML standard does WebMite Pico W support? Supertech, 09/08/2024 19 2308 TassyJim  09:58am 22 Aug 2024
DVI board possibilities Mixtel90, 18/08/2024 17 2844 Mixtel90  07:37am 21 Aug 2024
ChatGPT when you need code explaining PhenixRising, 20/08/2024 10 2335 Rickard5  02:27am 21 Aug 2024
5 in touch and pico PeterB, 18/08/2024 6 2044 PeterB  11:26am 20 Aug 2024
= New posts since you last visited .
   Page 74 of 469
