Local Time 16:35 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIO and WebMite questions
homa
Posted: 07:03pm 12 Aug 2024
Hi guys,
I'm going to try the PIOs again. First I want to receive a MIDI signal (serial 8N1 at 31250 baud). This works fine with the UARTs. But now I want to learn how to use the PIOs.
I have chosen the GP15 as the input pin.
I also used this source for the PIO programmer: https://github.com/raspberrypi/pico-examples/blob/master/pio/uart_rx/uart_rx.pio
I have consulted the manual "Appendix F - The PIO Programming Package" and the link there.
But I have problems to understand
the >option list
WebMite MMBasic Version 5.08.00
OPTION COLOURCODE ON
Here is my Basic attempt which unfortunately fails:
'Only PIO 0 is available on the WebMite
'as PIO1 is used by the WIFI interface
'disconnect ARM from GP15
' SETPIN GP15,PIO0
'PIO program
PIO ASSEMBLE 0,".program uart_rx"    'a program needs a Name
PIO ASSEMBLE 0,".wrap target"
PIO ASSEMBLE 0,"start:"
PIO ASSEMBLE 0,"wait 0 pin 0"
PIO ASSEMBLE 0,"set x, 7    [10]"
PIO ASSEMBLE 0,"bitloop:"
PIO ASSEMBLE 0,"in pins, 1"
PIO ASSEMBLE 0,"jmp x-- bitloop [6]"
PIO ASSEMBLE 0,"jmp pin good_stop"
PIO ASSEMBLE 0,"irq 4 rel"
PIO ASSEMBLE 0,"wait 1 pin 0"
PIO ASSEMBLE 0,"jmp start"
PIO ASSEMBLE 0,"good_stop:"
PIO ASSEMBLE 0,"push"
PIO ASSEMBLE 0,".wrap"
PIO ASSEMBLE 0,".end program list"
Print "CPUspeed", MM.Info(CPUSPEED)
Pause 1000
'configure pio0
p=Pio(PINCTRL 0,0,,gp15,,,)      'gp15 in
f=15625 'Hz for 31250 baud, MIDI 8n1 > 31250/2 = 15625 Hz ?!
s=Pio(shiftctrl 0,0,0,0,0,0)     'shift in from LSB for IN
e=Pio(execctrl gp15,Pio(.wrap target),Pio(.wrap) )
'write the configuration
PIO init machine 0,0,f,p,e,s,0
'start the pio0 code
PIO start 0,0
'Check the the read data in MMBasic and print
 Dim d%,b%
   PIO read 0,0,1,d%
   b%=d% Xor &hFF
   If b%>0 Then Print Bin$(b%), Hex$(b%)
   'Pause 200
 Loop
End
Who can help me and give me the right hint?
PhenixRising
Posted: 09:51pm 12 Aug 2024
Cool 😎
We sorely need MIDI stuff
Posted: 06:04am 13 Aug 2024
Hi Homa,
When the uart should run 31250 baud, the PIO clock must be a multiple of that. I have no access to pico atm. Cannot help you short time. But try f=2*31250, or f=3*31250.
homa
Posted: 05:53pm 13 Aug 2024
Hi Volhout,
Thanks for your tip, according to my research it should actually be baud = Hz. But I also tried f *2 or f *3. Unfortunately without success.
First I added the interrupt to separate the bytes. But the result is not what I expected :-(
> run
0: 2020
1: EA27
2: 4001
3: 0642
4: 00C8
5: C014
6: 20A0
7: 0000
8: 8000
CPUspeed        133000000
11100000        E0
10000000        80
I actually expect something like this (when I press a midi keyboad button) as it comes via UART and is correct:
10010000        90
110000  30
100000  20
110000  30
0       0
Current programme code:
'PIO program
Pause 100
Dim d%,b%
'configure pio0
f=31250 '? Hz for 31250 baud, MIDI 8n1 ?!?
PIO INTERRUPT 0,0,myPioRX,0
PIO start 0,0
' MAIN
'    PIO read 0,0,1,d%
'   b%=d% Xor &hFF
'    If b%>0 Then Print Bin$(b%), Hex$(b%)
'    Pause 20
 Loop
End
Sub myPioRX
  ' PIO stop 0,0
  ' PIO init machine 0,0,f,p,e,s,0
  PIO read 0,0,1,d%
  b%=d% Xor &hFF
  ' PIO start 0,0
End Sub
Matthias
Edited 2024-08-14 03:54 by homa
Posted: 05:59pm 13 Aug 2024
For a bitbanged serial the clock rate is typically 2x baud rate
Wait for the start bit
Wait 1.5x bit time
repeat x8
sample input
wait bit time
loop
If I read your code correctly you are sampling as the bit is changing
homa
Posted: 08:04pm 13 Aug 2024
Hello Peter, hello Volhout,
I did it. Now I understand the PIO example code more and more.
I still have some questions!
The PIO example says the following:
; Autopush must be enabled, with a threshold of 8.
   // Shift to right, autopush enabled
   sm_config_set_in_shift(&c, true, true, 8);
   sm_config_set_fifo_join(&c, PIO_FIFO_JOIN_RX);
   // SM transmits 1 bit per 8 execution cycles.
   float div = (float)clock_get_hz(clk_sys) / (8 * baud);
   sm_config_set_clkdiv(&c, div);
So I reduced the PIO code to the simpler example. I adjusted the frequency to the baud rate and used the MMBasic command
PIO(SHIFTCTRL a,b,c,d,e,f,g,h), c/ autopush
is enabled. However, a 32-bit value is returned. Is it possible to enable 8-bit autopush as in the notes? And if so, how?
I have done this by adding
PIO ASSEMBLE 0, "push"
which solved the problem.
I also had the shift direction wrong.
Now:
s=Pio(shiftctrl 0,0,0,0,1,0)     'shift in from MSB for IN
To make the 32-Bit value correct, I added the "value>>24" to the output in MMBasic.
Thanks for your suggestions!
> run
0: 2020
1: EA27
2: 4001
3: 0642
4: 8000
CPUspeed        133000000
10010000        90       144
110000  30       48
1010100 54       84
110000  30       48
0       0        0
'PIO program
Pause 100
Dim d%,b%
'configure pio0
f=31250*8 'Hz for 31250 baud, MIDI 8n1 = *8 for the PIO-Code!
PIO start 0,0
'MAIN
   'nothing
 Loop
End
Sub myPioRX
  PIO read 0,0,1,d%
  b%=d%>>24
  Print Bin$(b%), Hex$(b%), b%
End Sub
Matthias
Posted: 05:47am 14 Aug 2024
Goog work Matthias, you are understanding PIO well
Thanks Peter, for helping out
homa
Posted: 06:57pm 17 Aug 2024
Unfortunately, I haven't quite understood it yet :-(
Now I want to try the other direction (send) and I fail ...
It looks like the OUT does not write from the OSR to the PIN.
Can anyone tell me my mistake?
Matthias
' pio out TEST
'disconnect ARM from GP14
SetPin GP14,pio0
Dim d%,b%,o%
PIO ASSEMBLE 0,".program uart_tx"
PIO ASSEMBLE 0,".side_set 1"
PIO ASSEMBLE 0,"set pindirs, 1"
PIO ASSEMBLE 0,"pull       side 1 [7]"
PIO ASSEMBLE 0,"set x, 7   side 0 [7]"
PIO ASSEMBLE 0,"out pins, 1          "
'configure pio0 StateMachine 1
f=31250*8
'             a b c d    e    f    g      a,e=side set   c,g=OUT
p=Pio(PINCTRL 1,1,1,gp15,gp14,gp14,gp14)
'                 7   .
s=Pio(shiftctrl 0,7,0,0,1,1)
'start the pio0 code state machine 0
PIO start 0,0
'MAIN
   'nothing
   Pause 500
   o%=&haa
   Print Bin$(o%)
   'Print "Status1:", Pio(FLEVEL 0 ,0 , tx)
   PIO write 0,0,1,o%
   Print "..."
 Loop
End
homa
Posted: 05:19pm 20 Aug 2024
@Volhout: please check your PM, thx.
Matthias
Posted: 07:49am 24 Aug 2024
Hi Matthias,
When using SIDE SET, a field in each instruction is reserved for SIDE SET.
But there are many instructions where SIDE SET is not to be executed.
There is a configuration in the EXECCTRL register that only activates SIDE SET when it is actively programmed in the assembler.
In your program, change:
into
e=Pio(execctrl gp15,Pio(.wrap target),Pio(.wrap),0,1 )  'side set only when defined
Then, it works....
So in essence, your program worked, but on each instruction (also the OUT) the hidden SIDE SET re-programmed the GPIO pin to 0.
P.s. you may have to change the PULL into PULL BLOCK so you only send data when there is new data in the fifo.
Edited 2024-08-24 21:10 by Volhout
homa
Posted: 11:37am 25 Aug 2024
You are a genius for PIO :-)
Peter was not wrong to refer to you.
But why doesn't it say so in the manual or do I have tomatoes on my eyes? ... ye...no ...
I found this: “[,side_pindir][,side_en]” BUT without any explanation. @geoffg: “Please add this to the manual. Especially in the appendix there is no mention of this yet!”
Matthias
Posted: 05:47pm 25 Aug 2024
Actually, this is an omission from my side. When I wrote the text for this chapter, the 2 fields where not defined yet. At some moment in time these fields where added by Peter, and the manual was not updated.
