Local Time 17:02 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5 in touch and pico
PeterB
Posted: 08:30am 18 Aug 2024
G'Day
Some time ago somebody posted details about a 5 in touch screen with a matching PCB containing a pico and other circuits which I thought looked useful. Did I dream this or did it really happen?
If it did happen, can I have more information please?
PeterB
al18
Posted: 07:16pm 18 Aug 2024
I posted about a board offered on Tindie in June https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17035#222882
stanleyella
Posted: 07:46pm 18 Aug 2024
https://www.ebay.co.uk/itm/295410670887?
the display, dunno if it's for the display board.. which is $37.02 with shipping to uk
PeterB
Posted: 02:42am 20 Aug 2024
G'Day again.
Thanks for trying to help.
Gragster made a board for us some time ago that fits a 7 in touch screen and uses his E64 board as the brains plus my line drivers / receivers plus a few connectors for GPS etc. Sadly, the E64 chip no longer exists so I thought perhaps something like that using the pico and resized for a 5 in screen could be useful.
It looks like al18 has similar ideas.
Peter
Posted: 07:06am 20 Aug 2024
The main problem with using a parallel interface LCD with a Pico is that it uses a lot of GPIO pins. I designed a little adapter some time ago. It includes a MAX3488E to give a full duplex RS-422 interface, a I2C port (which can be used for a little RTC) and 4x GPIO pins on a header. Info is in the link in my sig. "SSD1963 Mini Adapter".
This is designed to fit the 5" display and can be fixed to it using mounting pillars. It should also work with other pin-compatible displays but the fixing points may not line up. :)
Posted: 10:48am 20 Aug 2024
Like this
PeterB
Posted: 11:26am 20 Aug 2024
And again.
We are making progress (I think)
More work for me to do.
Peter
