Local Time 11:52 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteHDMI firmware - first cut
Posted: 06:10pm 21 Aug 2024
PicoMiteHDMI.zip
Should run on any RP2350 with pins GP12 to GP19 broken out.
Wiring:
GP12 : D0+  GP13 D0-
GP14 : CK+  GP15 CK-
GP16 : D2+  GP17 D2-
GP18 : D1+  GP19 D1-
This should behave pretty much like the VGA firmware. CPU speed is fixed at 315MHz and your screen will see 640x480@75Hz
The maximum number of variables is increased to 768 and the maximum number of function/subroutines/labels to 512.
Maximum program size is now 180Kbytes and there is 42Kbytes used for simple variables and variable headers and another 180Kbytes for arrays and strings.
I expect with the M33 core that it should be possible to enable MP3 playback with just the standard audio connections. This is the next job.
There are many conditional compilation directives to support the HDMI/RP2350 version with exactly the same codebase as all other Picomite variants so there may well be bugs and/or functionality I have patched out and not yet converted - please report anything you find
At the moment graphics modes 1 and 2 are implemented and things like frame-buffers and layer-buffers should work like the VGA version EXCEPT that when creating them you don't use any of the user memory. Set OPTION COLOURCODE ON to have colour highlighting in mode 1 editing as before.
The map command is now more powerful and will work in mode 2.
MAP(n)=RGB888colour 'n=0 to 15
'this sets up an internal mapping for colour n in RGB555
MAP SET
'this actions any previous map(n) commands and the screen will then change colour. So you can now use any 16 of 32768 colours in mode 2
MAP RESET
'sets the mapping back to the default RGB332 mapping
MAP GREYSCALE/GRAYSCALE
'instantly changes all 16 colours to greyscale levels. Try this then do GUI TEST LCDPANEL to see the effect. You can then still use the MAP(n)/MAP SET to change some of the greys to another colour
MAP MAXIMITE
'instantly changes all colours so that colours 0 to 7 are the same as the colour Maximite
REMEMBER to access a mapped colour use the MAP function
MAP(1)=RGB(50,50,50):MAP SET
TEXT 0,0,"Hello world",,,,MAP(1) 'output text in the grey colour just defined
PSRAM can be enabled with
OPTION PSRAM PIN n ' n=0, 8, 19, or 47. If this is done on a RP2350 without PSRAM then the option will be automatically disabled.
To access PSRAM use the address &H11000000
e.g.
poke word &H11000000,&H12345678
? peek(word &H11000000)
More to come on this later
Edited 2024-08-22 04:11 by matherp
Martin H.
Posted: 06:23pm 21 Aug 2024
Thank you Peter
with the Map command we are able to redefine the Color pallet at runtime, right?
So it should be possible to make those deluxe paint color mapping animation like on the AMIGA back then
I'll test it out as soon as I get the Pico 2
Edited 2024-08-22 04:28 by Martin H.
'no comment
Posted: 08:36pm 21 Aug 2024
@Peter
When using the USB version, are GP8 and GP9 bitbanged as a serial oprt or is COM2 used for the console? Just trying to sort out whether to put a ESP on COM2.
al18
Posted: 08:31am 22 Aug 2024
Peter,
What Pico2 hardware are you using?
Based on the info you’ve mentioned, I’ll guess Pimoroni Pico Plus 2 with the Adafruit DVI breakout board 4984
Posted: 08:43am 22 Aug 2024
  Quote  What Pico2 hardware are you using?
My own little adapter board (gerbers on the other thread ) and a breadboarded Pimoroni PGA2350
Edited 2024-08-22 18:47 by matherp
Bleep
Posted: 04:10pm 22 Aug 2024
For completeness, I have run the BubbleUniverse on this HDMI version, as well as the others and get the following results:-
2040  VGA  @ 378MHz bubble runs at 286mS per frame
2350A VGA  @ 378MHz bubble runs at 163mS per frame
2350A HDMI @ 315MHz bubble runs at 191mS per frame
For VGA approx. a 1.75 times speed up, over 2040 VGA. :-)
For HDMI approx. a 1.5 times speed up, over 2040 VGA, only limited by the fact that the core frequency is 315Mhz (HDMI clock requirement) as opposed to 378Mhz for VGA.
Not too shabby. I'll have to increase the number of points it plots to slow it down again ;-)
Otherwise everything I have so far tested is working fine on the PicoMiteHDMI, display quality looks good stable & sharp & full screen. :-)
Regards Kevin.
Edited 2024-08-23 02:47 by Bleep
