Local Time 17:02 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Electride  ( f77 -ish) on rp2350
zeitfest
Posted: 12:48pm 26 Aug 2024
Tried my interpreter on a RP2350.
First light...  very encouraging !!
The aim is to run the prg. calculator   in the other thread.
   Electride 2350  © S. Oliver 2024
   (G) Get    (L) List       (M) Mount SD
   (S) Save   (A) Analyse    (U) Unmount SD
   (R) Run                   (E) Erase file
>G
Waiting
OK
>R
Running
     PROGRAM helloworld
C
     PRINT *, "Hello, world"
     END
Hello, world
OK
     SUBROUTINE plott ( page )
     INTEGER*4 x, y
     CHARACTER*10 fm
     fm = '(64A1,/)'
     DO y = 1, 21
     WRITE (6,fm) ( page(x,y), x = 1, 64 )
     END DO
     RETURN
     END
start
hotcarrier
Posted: 07:51pm 28 Aug 2024
I tried your F77 version on the 32mx170f and it worked just fine. Brought back a memory of my first computer program in 1970 on an IBM 1130 with F4. I look forward to trying it on the new pico 2350
zeitfest
Posted: 01:12pm 29 Aug 2024
Thank you ! The rp2040 version is looking good,  but I got sidetracked.. Trying to avoid labelled format statements at this stage, but they would be a standard compatibility. It is only supposed to be a micro system after all. I will wrap/clean up the rp2040 version to make it presentable and see what happens.
All credit to the earlephilhower / adafruit / arduino-genuino people which built the foundation for this. I am still amazed it works
