Local Time 06:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Draft PicoMite 6.00.01 User Manual
     Page 13 of 13
Andrew_G
Posted: 06:37am 24 Feb 2025
Geoff et al,
NOT a high priority but I've just spent a 'while' searching for the 'PAGE' command in the manuals (I knew it was there). Is there some way to omit the Page No. from searches or can the word 'Page' not be used at all?
Cheers,
Andrew
electricat
Posted: 07:49am 26 Feb 2025
  Geoffg said  Good one!
I think that is Peter taking a mad stab in the dark.
Whats Your opinion?
While reading manual I just wondered, would it be usefull to add additional Note about MODE 1 and COLOUR fore [, back] or COLOR fore [, back] ?
Something like this, but in proper english
"If default TILE HEIGHT 12 is left unchanged and FONT 1 or 3  is used in PICOMITE VGA/HDMI, then user can use COLOR command for color printing using PRINT command with no need to use TILEs."
Print @(x,y) with FONT 1 or 3 and carefully calculated coordinates also prints in color. But I do not know how to formulate this in english properly
It`s up to You decide if it has some rational value or not
But i did not noticed any mention about this relationship in current manual.
My MMBasic 'sand box'
electricat
Posted: 07:49pm 13 Apr 2025
@Geoffg, Peter
Pg. 164
GETSCANLINE VGA VERSION ONLY
and description
I used GETSCANLINE in USB/HDMI/2350 to display sprite movement nicely.
Both OPTION RESOLUTION 800 and 640 ; MODE 1,2 & 3
So, manual might need some update?
Edited 2025-04-14 05:50 by electricat
Posted: 08:54am 03 Sep 2025
Geoff,
This may not be the correct thread for a 6.00.03 or later user manual, but I would like to indicate that the user manual (6.00.03) still lists M (mono) mode for PLAY SOUND. M generated "out of phase" sound on both channels. And that is not supported anymore.
toml_12953
Posted: 10:31pm 03 Sep 2025
  Geoffg said  This is the first draft of the user manual for the PicoMite 6.00.01 and we are looking for any comments and corrections.
PicoMite_User_Manual.pdf
We have moved to a single manual covering all variants (Pico, Pico 2, Pico W and Pico 2 W).  With a dozen firmware variations it was just not practical to have a manual for each variant.
If you spot anything wrongs I would be grateful if you would post it in this thread.
Thanks,
Do you mean 6.01.00? If not, then why change a manual older than 6.00.03?
Edited 2025-09-04 08:53 by toml_12953
Posted: 11:18pm 03 Sep 2025
  Volhout said  This may not be the correct thread for a 6.00.03 or later user manual
I guess he used this thread as there isn't a thread for the latest manual.
Posted: 02:42am 04 Sep 2025
  Volhout said  This may not be the correct thread for a 6.00.03 or later user manual, but I would like to indicate that the user manual (6.00.03) still lists M (mono) mode for PLAY SOUND. M generated "out of phase" sound on both channels. And that is not supported anymore.
In the latest version (Revision 2 26 August 2025) this has been deleted.
It is difficult to keep up with these small manual updates but I have not found a better way to do it.
     Page 13 of 13
