Local Time 03:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.02.01 release candidates
     Page 9 of 9
Posted: 06:37pm 22 Mar 2026
V6.02.01RC9
PicoMiteV6.02.01RC9.zip
Minor performance improvement for RP2350 versions (2-3%)
Fixes bug in MEMORY INPUT
Adds support for user configuration of stepper enable after estop
Adds PEEK(STEPPER BUFFER) which will return the number of free slots in the gcode buffer
Stepper_Reference.pdf
JanVolk
Posted: 08:55pm 22 Mar 2026
PEEK(STEPPER BUFFER) is missing from the latest Stepper Reference manual.
Jan.
Posted: 10:45pm 22 Mar 2026
mozzie
Posted: 03:25am 23 Mar 2026
G'day Peter,
Would one further enhancement be possible?
There is currently no easy way I can see to know if the Stepper system is idle but initialized in the background, except peeking a register and checking for an error.
Could peek(stepper active) be made to return -1 (or some other value) if the stepper system is not initialised?
Lyle.
Posted: 10:16am 23 Mar 2026
  Quote  Could peek(stepper active) be made to return -1 (or some other value) if the stepper system is not initialised?
Will do.
All:
With that trivial change RC9 will be the release. So let me know any issues or it will be too late as of tomorrow evening UK time
ville56
Posted: 10:27am 23 Mar 2026
Peter,
is the issue with one element arrays now fixed?
Option base 1
Dim i%(1)
Error: dimensions
73 de OE1HGA, Gerald
Posted: 10:37am 23 Mar 2026
This is how MMBasic works, will never be "fixed"
Each MMbasic variable has a table Dims[] that holds the dimensions of the array. So a two dimensional array with 4 elements in the first dimension and 2 in the second would have 4 in dims[0] and 2 in dims[1]. A "0" in dims[0] is the universal test in MMBasic for a scalar variable rather than an array. Changing this would be a massive change and would inevitably de-stabilise the entire interpreter.
Edited 2026-03-23 21:06 by matherp
Posted: 12:35pm 23 Mar 2026
Peter,
RC8 was okay for 2040 VGA, 2040 GM, 2350 GM. I do not have time to redo all tests for RC9 that fast.
Posted: 04:39pm 23 Mar 2026
  ville56 said  Peter,
Option base 1
Dim i%(1)
Error: dimensions
  matherp said  This is how MMBasic works, will never be "fixed"
That's fine, but doesn't seem to explain why the code shown is not OK.
You'd expect an array of one element, referred to as i%(1).
Internally dims[0] would presumably be 1.  What's the problem?
edit: for completeness, using i%(0) would be an error of course
Edited 2026-03-24 02:40 by JohnS
Posted: 04:50pm 23 Mar 2026
Because the value stored in dims is the highest index value for the array minus OPTION BASE. This code is in every version of MMbasic and won't be changing.
DIM a(2) stores 1 because you can't use a(2). I was simplifying in the explanation above to make it easier to understand without getting into the compexities of OPTION BASE
Edited 2026-03-24 02:52 by matherp
Posted: 05:23pm 23 Mar 2026
Ah. No worries, in that case, better just to live with it.
Maybe a few words in the manual, under DIM, when option base is 1.
Edited 2026-03-24 03:24 by JohnS
Posted: 06:09pm 23 Mar 2026
Just don't use base 1. :)  It uses the same space anyway, whether you use (0) or not. It's still there, just not accessible.
Posted: 06:21pm 23 Mar 2026
Not true. DIM a(2) with OPTION BASE 1 uses exactly the same ram as DIM a(1) with option base 0. The zero slot for option base 1 is not there. OPTION BASE is just subtracted from the index so internally the firmware doesn't care
Edited 2026-03-24 04:22 by matherp
ville56
Posted: 06:25pm 23 Mar 2026
  matherp said
... DIM a(2) stores 1 because you can't use a(2).
sure you can use a(2) ... in both cases, base 0 and base 1
> option base 1
> dim integer a(2)
> print a(1)
0
> print a(2)
0
> option base 0
> dim integer a(2)
> print a(0)
0
> print a(1)
0
> print a(2)
0
with base 0 it just generates one index too much, in this case a(2).
Posted: 06:54pm 23 Mar 2026
I'm talking about the internal C array dim[] that stores the size of each array index. When with OPTION BASE 1 when you specify DIM a(2) then the internal array dim has a 1 in it indicating that the maximum internal index is 1 to which is added OPTION BASE for input and output. In any case the point of the discussion is to try and explain why DIM a(1) as a basic statement with OPTION BASE 1 and DIM a(0) with option base 0 will never and can never be allowed.
Just to be clear, this is nothing to do with my likes or dislikes it is core MMbasic from day 1. I would love to be able to specify arrays with a single element as it would make some of the maths array functionality much easier but it simply can't be done without a major rewrite.
Edited 2026-03-24 05:04 by matherp
Posted: 08:30pm 23 Mar 2026
It's a neat system though. It doesn't appear to work anything like the old BASIC interpreters, probably because it's written in C. :)
Posted: 09:06pm 23 Mar 2026
I don't see it as a C issue, which could do anything you like, except in this case I gather it's a kind of an accident of the implementation from, well, day one.
If it had been a problem in that early time maybe it would have been changed?  Anyway, we are where we are and ... it's not a big thing to live with!
Languages / their implementations commonly have some odd things (C's preprocessor is fun, the pointer syntax is er, fun, python's __ is bizarre, C++ er, enough said, and so on).
JanVolk
Posted: 09:28pm 23 Mar 2026
> run
Stepper initialized - 100KHz timer active
Warning: Soft limits not configured. Use STEPPER LIMITS to set working area.
Stepper armed - executing buffered commands
I loaded FishFeeder.bas and the firmware PicoMiteRP2350V6.02.01RC9 and started it, after which I received the above message.
I tried various Stepper limits but the message persists.
Which command ensures that I no longer receive the message on a terminal when I use a separate stepper motor without limit switches, or am I doing something wrong?
Jan.
Bryan1
Posted: 09:38pm 23 Mar 2026
I've had a look at all this stepper code to use but as there are direction and pulse pins what is the hardware to use that pulse the stepper motor ?
Now there are two flavours of steppers bipolar and unipolar so which is one is used with this.
Now I do have those 2 new stepper motors which are bipolar and I'm on changing my old Macson surface grinder to use steppers as backlash on the down travel where the the grinding wheel is doing 15,000rpm can't be present.
Maybe a new thread should be made where the stepper code for MMBasic can be made where all the hardware is shown along with an easy guide to get it all going.
Posted: 10:36pm 23 Mar 2026
Bryan1, have added some info to the fish feeder thread.
     Page 9 of 9
