Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 betas
this is the answer... gui show all cls 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'cls 'draw direction buttons box 0,199,80,40,3,rgb(white),rgb(blue)'left button box 140,199,80,40,3,rgb(white),rgb(blue)'right button box 279,40,40,80,3,rgb(white),rgb(blue) 'up button box 279,159,40,80,3,rgb(white),rgb(blue)'down button do tr=TOUCH(REF) loop until tr>0 cls gui show all do 'init players start positions regards stan |
the manual GUI SHOW ALL This will undo the effects of GUI HIDE and restore the control(s) to being visible and capable of normal operation. '#ref' is the control's reference number. The keyword ALL can be used as the argument and that will disable all controls. should be enable? Edited 2025-08-23 06:33 by stanleyella |
Hi Peter, Is there any way to get back some version of the LCD320 option for SPI displays? I am testing code for a 240*320 display on a 7796s and doing a merge on the whole screen, rather than 240*320 is proving problematic, speed wise. As a half way house, would it be easier to do 240*480, so full width, but only 240 high? this would probably make it fast enough for most purposes. Thanks for any sugestions. Regards Kevin. |
Thanks Stanley, fixed. Geoff Geoff Graham - http://geoffg.net |
POKE DISPLAY HRES n POKE DISPLAY VRES n These commands change the stored value of MM.HRES and MM.VRES allowing the programmer to configure non-standard displays. That's all LCD320 did but it wasn't fully robust so I removed it but worth trying |
Thank you for brill coding kit. I am luvin it, marvellous, thank you and Peter. Without the manual we'd be clueless, well I would be. I should read the "small print" before posting problems that are explained if I took time to read. happy days. regards, stan |
Perhaps a slight manual change would be in order? Page 100 - ADC OPEN command Suggested change: This allocates up to 4 ADC channels from the ADC0-ADC3 group for use and sets them to be converted at the specified frequency. The range of pins is GP26, GP27, GP28, and GP29 for the RP2040 and RP2350A or GP40, GP41, GP42 and GP43 on the RP2350B. If the number of channels is one then it will always be ADC0 used, if two then ADC0 and ADC1 are used, etc. Sampling of multiple channels is sequential (there is only one ADC). Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks for this hint. I'm using a SSD1963 with a RP2040 latest firmware. Option LCD320 on works fine called within the program. Coming back to console will leave this option on and editor is shown in 320x240 in the upper left edge. Option LCD320 off gives an error at the console but switches back to standard Resolution 800x480 but seems not to reset hres/vres to correct values. When I call the program for the second time, the picture is scrambled and x/y is not correct. Poke display then seems to help (quick test) Edit: sorry, it does not help for me. Found no other way than doing cpu restart to get out of this Edited 2025-08-27 19:28 by dddns |
PicoMiteV6.01.00b10.zip is b9 the last version that will work on a 2040 non-USB, non-VGA, non-HDMI? Edited 2025-08-28 13:28 by toml_12953 |
Tom, The b10 download file has been updated with the missing versions. If you clear browser cache, and download again, you will get the full list (including 2040 nonVGA,nonUSB(nonHDMI ... There never was a 2040 HDMI version). Volhout PicomiteVGA PETSCII ROBOTS |
Tom V6.0100 and forward are for the 2350 as stated on the first post |
b10 still has all the files for the 2040. |
Tom, Bryan, V6.00.03 was the end of the 2040 series. As far as I know for 6.01.00 - there are only bug fixes for 2040 - bug fixes for 2350 and new functionality So for 2040 it may be interesting to use 6.01.00 since some bugs that are fixed are pretty essential. Volhout PicomiteVGA PETSCII ROBOTS |
Hi Peter, a quick question: Is it possible that the illegal (and unintentional) use of path or file names longer than the allowed 63 characters can corrupt the memory structure? Kind regards Michael |
Just don't do it. Something nasty will happen anyway. Even if there's no error flagged the string will probably be truncated, causing a different sort of error. fullpath$ = path$ + filename$ if len(fullpath$) > 63 then do_some_sort_of_error_handling_or_you'll_be_in_the_wet_and_smelly :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Mick, Thanks for the good advice! And that's really the best solution if you only have three files on the drive. But there are cases that are more complicated, like many things in life. ;-) I am still tinkering with the FM at the moment. And for most problem cases there are already satisfactory solutions. My question was addressed to Peter only because, during the days of testing - also with overly long pathnames - I observed strange effects. I'm just looking to confirm or deny my suspicion. It is relatively easy to prevent the copying of files/directories with long pathnames into locations with other long pathnames. But there are special cases that are difficult - and require great effort - to handle. For example, a user may want to rename an existing directory and choose a name which, when combined with one name somewhere among the possible thousands of files and directories beneath it, would exceed the permitted length. To prevent this, the entire drive would have to be scanned each time the rename command is used, which would render the command unusable. Regards Michael Edited 2025-08-29 21:23 by twofingers |
Hi Peter, Is it to be expected that the Framebuffer Sync, only works with background merge and not with background copy? It would be handy if it did, currently the program waits forever if I use it with copy. Regards Kevin |
@Twofingers In theory it can happen no matter what the maximum length is. The only way to be sure is to have unlimited length file names. That's not going to happen on a Pico. The alternative is to throw an error - and that's something I haven't tested. Truncating the string without warning wouldn't be acceptable, it's safer to do a proper crash! The Pico doesn't have incredibly clever error handling and something like this might be something you just have to live with. It'll be interesting to see what @matherp says though. Much, much safer to parse what the user is trying to do and catch any error before the command is passed to MMBasic's file handling. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Mick, I agree with you. For me, having a file system for the Picos is a small miracle; I'm happy to accept its limitations. It's just important to know the limitations and the potential consequences. Hence my question to Peter. Michael Edited 2025-08-29 22:54 by twofingers |
Kind regards Michael Hi, It definitly makes problems, because I learned this the hard way. I was searching for two whole days the problem in my program. I had a variable set to 1 to trigger an subroutine and open a file to preview it. I got an error, that this file doesn't exists. I checked a million times via PRINT debugging the state of all variables and everything was fine. I was about to ask about a bug in this forum and then it HIT me like a stone ... There is a 63 char limitation! Damn! Now everything became clear, problem fixed. So the answer is, it does make problems. Greetings Daniel |
