Local Time 14:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New 4 inch LCD
     Page 9 of 12
palcal
Posted: 07:33pm 06 Apr 2024
I keep getting the error...
ERROR IN MM.STARTUP
I deleted MM.Startup  and re wrote it but still the same.
The first one works OK but when I try to calibrate I touch 2 targets and get the TOUCH HARDWARE FAILURE.
The display works and calibrates ok on a Picomite. Although when I test touch, if I draw a line with the stylus the line does not appear where I touch and other pixels light up all over ther screen. However if I use the Text command to write something to the centre of the screen it appears in the correct place.
Edited 2024-04-07 06:56 by palcal
Posted: 09:01pm 06 Apr 2024
That touch won't calibrate on any ILI9488 on that MM2 board, while I can't get it to fail (with the original ILI9488 driver) suggests it may be something to do with that board.
Set up the display and a MM2 on a breadboard to see if that makes a difference.
I will have a chance to test the new driver this afternoon.
palcal
Posted: 09:45pm 06 Apr 2024
Old breadboard had dodgy connections, I have a new one coming, will try it then.
Posted: 09:52pm 06 Apr 2024
Tested both new versions of the MM2 driver and touch calibrates ok with both.
However the second one seems to require the 'invert' parameter, not optional.
eg for non-inverting
Sub MM.Startup
 ILI9488 2, 23, 6, 1, 0
'  ILI9488 DCpin, RESETpin, CSpin, orientation [,invert]
Otherwise you get 'Error in MM.STARTUP'
stanleyella
Posted: 10:27pm 06 Apr 2024
Hi phil. the isp ili9488 is the first display needing invert option afaik. got by fine without invert until this display. why invert after so long... and now it'll be a number? why ils needs inverting for the techno inquisitive please?
Posted: 11:13pm 06 Apr 2024
As far as I can tell the issue is the IPS (In-Plane Switching) panels use inverted logic compared to the standard TFT (Thin Film Transistor) type.
The ILI9488 chip just passes whatever data it receives from the driver to the panel, so the driver needs to negate the negative to get positive colours.
  Quote  ... and now it'll be a number?
Only for the MM2 (PIC32MX170 chip). Peter will have the real answer but my guess is numbers are more efficient than words which is more important for the slower MX170 than the RP2040.
Edited 2024-04-07 21:57 by phil99
Teo1
Posted: 07:51pm 07 Apr 2024
Hi matherp ,
Do you have any datasheet and an example of use for display shown by you ?
Thanks in advance ,
Teo
OA47
Posted: 07:51am 08 Apr 2024
Not sure if any shedders may have a use for it but here's a ILI9488 4inch experimenters backpack. It has screen, touch, sound, RTC and SD access.
I used Capton tape on the back of the pico and soldered it directly to the board but you could drill to mount it on pins.
I can upload the gerbers if anyone is interested.
0A47
Edited 2024-04-09 07:20 by OA47
Posted: 05:13am 09 Apr 2024
@Palcal, the plot thickens. Just got a 4" IPS ILI9488 (same blotch on the screen, same cure - thanks) and GUI CALIBRATE works perfectly on a MM2, verified with Gui Test Touch, But won't calibrate on a Pico (PicoMite MMBasic Version 5.09.00RC3). Copying the calibration from the MM2 to the Pico doesn't help - Gui Test Touch does nothing.
Footnote added 2024-04-09 15:49 by phil99
x=touch(x) : y=touch(y) :? x,y
Always returns -1, -1 if executed while being touched on the Pico but returns the correct values on the MM2.
palcal
Posted: 05:23am 09 Apr 2024
I copied the calibration values with the same result.
Posted: 07:33am 09 Apr 2024
Bit difficult to follow but are you saying that touch isn't working on the IPS ILI9488 but is on the standard ILI9488 in the same circuit?
If this is the case please try the attached and let me know if it improves anything
PicoMite.zip
morgs67
Posted: 07:46am 09 Apr 2024
@phil99
The IPS 4" screen I have works fine on the picomite.
  Quote  > option list
OPTION SYSTEM I2C GP14,GP15
OPTION AUTORUN  ON
OPTION LCDPANEL ILI9488, RLANDSCAPE,GP16,GP17,GP18,GP19,INVERT
OPTION TOUCH GP22,GP20
GUI CALIBRATE 0, 189, 185, 1276, 856
OPTION RTC AUTO ENABLE
Calibrated OK a couple of times. Touch test also working ok. The display is modified with the diode and resistor along with the miso pin cut off. Not using sdcard connections.
Tony
Posted: 08:06am 09 Apr 2024
Hi Peter, thanks for looking at it.
The new .uf2 also gives "Error : Touch hardware failure" with GUI Calibrate.
It's a puzzle, 2 3.5" ILI8488s work fine on both the Pico and the MM2.
Palcal and morgs67 have the 4" IPS touch working on the Pico.
Palcal can't get touch to work on the MM2 while my IPS works on the MM2 but not the Pico.
Does Not Compute!
morgs67
@0A47
Like the look of your experimenters backpack. Would it be possible to place holes in all the pads so that pins/sockets could be used as well for all connections. also if you added another set of holes that matched the sd card connectors on a 3.5" both displays could be accommodated.
Tony
OA47
Posted: 08:39am 09 Apr 2024
  Quote  Like the look of your experimenters backpack. Would it be possible to place holes in all the pads so that pins/sockets could be used as well for all connections. also if you added another set of holes that matched the sd card connectors on a 3.5" both displays could be accommodated.
Good thoughts Tony, I could add those holes if I were to get the boards made but as shown I was minimalizing any errors I could produce on the prototype boards I have milled, drilled and cutout on the CNC.
BTW Do you have a measurement for the spacing between the pins for the 3.5 inch version ?
0A47
Posted: 09:39am 09 Apr 2024
My IPS touch issue on the Pico is fixed. Contact cleaner in the socket did the trick.
Somehow the old panels made contact but T_CLK pin on the new one didn't.
Palcal, probing all the Panel pins to the Pico found it so perhaps that is worth doing on your MM2.
OA47
Posted: 11:24am 09 Apr 2024
  Quote  here's a ILI9488 4inch experimenters backpack. It has screen, touch, sound, RTC and SD access.
If the link from BL to 3V3 is re-directed to the hole on GP17 and the OPTION LCDPANEL changed the Backlight 0-100% works a treat.
0A47
palcal
Posted: 08:47pm 09 Apr 2024
I checked all continuity pin to pin. I've gone round in circles so many times I'm losing track. Does calibrating the display do anything to the display itself.
palcal
Posted: 09:22pm 09 Apr 2024
I didn't realise that on some panels the LED is marked BL. I assume that the BL pin is connected to a PWM pin. Is it OK to use the mosfet circuit as on the Micromite Backpack with these panels as it supplies 5v. Are the panels marked BL only 3.3v. The first 4" panel I was playing with now has a dead backlight.
Edited 2024-04-10 07:25 by palcal
OA47
Posted: 10:03pm 09 Apr 2024
Palcal, when I traced the BL connection on the 4 inch ILI9488, it seemed to go to a single transistor circuit that converts the 3V3 PWM to a variable voltage for the backlight led. I would expect if you have been supplying 5v PWM to the transistor circuit the display would have not had a smooth backlight variation and you may have hurt the transistor circuit. You may be able to retrieve the backlight operation by linking the BL pin on the display to the other side (display side) of the transistor circuit with a resistor.
0A47
     Page 9 of 12
