Local Time 16:49 04 Nov 2026 Privacy Policy
Forum Index : Electronics : nanoverter build
     Page 9 of 15
johnmc
Posted: 12:04pm 08 May 2019
I will take another board also too, that is a total of 3
cheers john
johnmc
Mulver
Posted: 12:21pm 08 May 2019
I will take 2 if they are still available
nickskethisniks
Posted: 04:38pm 08 May 2019
I want 2 as well, I don't know how that works for EU transport.
tinyt
Posted: 06:21pm 08 May 2019
  poida said   Tinyt, how are things gong with the pcb files?
No hurry, I want to check with you before I take the latest files you have posted here
and engage the pcb manufacturer.
I re-checked today the rev D gerber files I posted here and I as far as I know I did not find any issue.
poida
Posted: 11:25pm 08 May 2019
Thanks for confirming that all is good for the pcb fab.
I am ordering 25 boards, 2oz copper, 1.66kg, DHL freight to AUS.
Cost is AUD $4.24/board from JCLPCB. (edit: I got a discount for some reason!)
Recall I said $10/each including postage.
I think that's fair, some postage will be more expensive than others
and I want it all to even out to no profit for me and no huge cost to me.
I want to be transparent with the costings.
Mark x3
Johnmc x3
Mulver x2
nicks x2 (post to Euroland..)
Ben&Amber x2 (post to USA)
Noneya x 2
Someone else x4
all adds up to 18, I want one spare and figure it handy
to have 6 left over for other people.Edited by poida 2019-05-10
poida
Posted: 12:07am 09 May 2019
  nickskethisniks said   I want 2 as well, I don't know how that works for EU transport.
The boards are about 70g each. Australia Post quote about $12 AUD for
up to 260 x 360 x 20mm and less than 250g and approx. 8 business days.
It should be no problems.
noneyabussiness
Posted: 02:31am 09 May 2019
Let me know when ya need the dosh poida... and obviously info on that..
Thank you for your help and effort with this, i think i speak for all when i say its greatly appreciated
I think it works !!
tinyt
Posted: 04:23am 09 May 2019
Hi poida,
Since you are posting to the USA, can you put me down for two?
poida
Posted: 04:33am 09 May 2019
  tinyt said   Hi poida,
Of course.
BenandAmber
Posted: 05:01am 09 May 2019
Poida the great you live up to your name and far Beyond
Thank you so much for thinking about us
renewableMark
Posted: 05:05am 09 May 2019
Mark x3
Johnmc x3
Mulver x2
Noneya x 2
Someone else x4
You sure those numbers are right?
Betta double check it, last time I ordered the shipping wasn't clear and it worked out to slightly under $10 each. I only got 10 though.
Edited by renewableMark 2019-05-10
Cheers Caveman Mark
Off grid eastern Melb
poida
Posted: 05:26am 09 May 2019
They seem right. And the invoice has the same $106.90 total.
DHL shipping.
renewableMark
Posted: 05:33am 09 May 2019
Pricks didn't give me a discount
Cheers Caveman Mark
yahoo2
Posted: 07:42am 09 May 2019
I will take 2 if you have some spare poida.
poida
Posted: 07:57am 09 May 2019
  yahoo2 said   I will take 2 if you have some spare poida.
Ok, it seems I might have only 4 left of the 25 now.
kentfielddude
Posted: 01:51pm 09 May 2019
Put me down for one please.
poida
Posted: 01:43am 10 May 2019
  kentfielddude said   Put me down for one please.
OK, now 3 left.
kentfielddude
Posted: 03:14am 10 May 2019
I really like the esp32 so I was thinking about designing a esp32 based nanoinverter so you could run everything off of one micro and have wifi monitoring. It is dual core so you could have the wifi running separately from the inverter control. Also was thinking about making a smaller board with smd components. For now I'm just going to get a madness board and nano control board to get started. I also want to look into the warp inverter.
Currently I have small 2kwh 18650 battery with 400 watts of solar. I am slowly replacing everything with diy versions. Working on building my mppt charge controller then the pure sine inverter. Already have a diy bms system.Edited by kentfielddude 2019-05-11
poida
Posted: 07:50am 10 May 2019
  kentfielddude said   I really like the esp32 so I was thinking about designing a esp32 based nanoinverter so you could run everything off of one micro and have wifi monitoring. It is dual core so you could have the wifi running separately from the inverter control. Also was thinking about making a smaller board with smd components. For now I'm just going to get a madness board and nano control board to get started. I also want to look into the warp inverter.
It all sounds good to me. I have a ESP32 WROOM which I programmed via the Arduino IDE.
How will you program the ESP32?
LadyN
Posted: 05:56pm 10 May 2019
Nice!
Kent, are you familar with the RMT on the ESP32?
Excellent!
I am also excited about building the warpverter but the availability of toroid cores is holding me back.
If you're interested, those of us in the U.S. can do a group buy of LTO batteries and toroid cores to go ahead with the project?
     Page 9 of 15
