Local Time 21:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICO PETSCII
     Page 8 of 38
Bleep
Posted: 09:45am 26 Sep 2023
As long as the game logic isn't too onerous, Volhout probably knows more about that, I think that will potentially be a possibility, if it'll run ok on a VGA, I would think it'll be possible to run on a standard Mite, maybe with a slightly reduced screen update rate, but hopefully usable. :-)
Regards Kevin.
Martin H.
Posted: 11:22am 26 Sep 2023
  Volhout said
You can walk the whole map, obstructed only by tiles that cannot be walked according the tile attributes. There is no pixel scroll, only tile based movements.
I will look at it, when I am at Home. If you use just tile movement are the Steps 24 Pixel ?
'no comment
Posted: 12:10pm 26 Sep 2023
Yes, 24 pixels
And the player is only 1 sprite, not really walking...
So it is very primitive. But it was made to prove that we understand the information in the amiga source material.
Edited 2023-09-26 22:11 by Volhout
Posted: 02:33pm 26 Sep 2023
  vegipete said  Is there any value in the Ultima 1 mini demo I posted a while ago? The world maps exist as a PNG file. The CMM2 made this easy to store on one of the many graphics pages. Individual pixels were read and converted to larger images to paint the view immediately around the player.
Hi VegiPete,
I tried your demo on the pico, and I think CMM2 is to far off. I will study it's algorithms to see if it is of benefit to us.
Thank you for offering.
Bleep
Posted: 03:53pm 26 Sep 2023
I have converted Volhout code, provided in a zip file a few posts back, to run on an SPI Serial LCD, using Peters new Framebuffer Copy in the background.
It's not at all bad, :-) frame rates look to be great, certainly a excellent start and definately usable on a LCD, at the moment.
Great work Peter, Volhout and Martin. :-)
Video of it working.
This is running at 252Mhz on a ST7789_320 LCD display.
Regards, Kevin.
Martin H.
Posted: 04:36pm 26 Sep 2023
  Volhout said  Yes, 24 pixels
Looks great ... I will test tomorrow, if you can use -16 or -8 as X Coordinate for the Tiles..
The walking can stop or change direction at a full tile but the animation would be 8 Pixel (1 Subtile) to keep it smoother :-)
Edited 2023-09-27 02:37 by Martin H.
'no comment
Posted: 04:37pm 26 Sep 2023
Kevin
Is it easy to post the complete program and files so I can try it on the parallel display
Posted: 04:38pm 26 Sep 2023
Not bad at all !!!
Bleep
Posted: 05:16pm 26 Sep 2023
Hi Peter,
This is Volhouts zip with a new bas file added "petsciiLCD.bas".
You first need to go to graphics directory and load all the ***_csub.bas and hit.csub files into the library, then run either Volhout VGA version pet8.bas or the LCD version petsciiLCD.bas the changes were actually very minor.
petrobotlcd.zip
Regards, Kevin.
Posted: 05:22pm 26 Sep 2023
  Bleep said  load all the ***_csub.bas
Can you try the new LIBRARY DISK SAVE command?
Bleep
Posted: 05:38pm 26 Sep 2023
Hi Lizby,
Yes just tried that and it does work, saved the library out, then deleted it and then loaded it back in, worked fine. :-)
Regards Kevin.
Posted: 05:40pm 26 Sep 2023
  Bleep said  just tried that and it does work, saved the library out, then deleted it and then loaded it back in, worked fine.
And can you post it?
Bleep
Posted: 05:53pm 26 Sep 2023
Hi Lizby,
It's in the same directory as the .bas files, petscii.lib it appears you have to do the load it manually, I tried it in the program and it said it was not allowed, presumably a space limit problem.
petrobotLCD.zip
Regards, Kevin.
Posted: 06:30pm 26 Sep 2023
  Quote  I tried it in the program and it said it was not allowed, presumably a space limit problem.
No, the issue is that when you run a program it builds an index of subroutines including in the library. If you tried to load a library in a program that list would be wrong. However, if the library is just data you can load it into a flash slot using the new FLASH DISK LOAD command and access the data via direct addressing
Posted: 06:51pm 26 Sep 2023
How about this
https://youtu.be/noPtHnbNBB0
Bleep
Posted: 07:10pm 26 Sep 2023
Very smooth Peter, & very fast. :-)
Posted: 08:45pm 26 Sep 2023
Only a minor update to previous package (not much time tonight): player is walking.
put this file in the folder where "pet8.bas" resides.
then run "pet9.bas"
pet9.zip
Edited 2023-09-27 06:46 by Volhout
Posted: 12:09am 27 Sep 2023
Ok, I got pet9 working on the LCD. Looks great. Thanks Martin, thanks Volhout, thanks Bleep, thanks Peter.
I got to walk the guy around the building, but was blocked at the door. Is there a trick (passkey available) or is this just as far as it's gotten?
I personally have no problem with scrolling one tile at a time, but I have no experience with these PC games--was a working man when they rolled out, so never spent the time to develop the skills needed.
Posted: 04:58am 27 Sep 2023
@lizby
Yip, the door is automated in the game, and this large piece of code is not yet written
Tune in to this channel in a few months…
Martin H.
Posted: 06:12am 27 Sep 2023
  Volhout said  Only a minor update to previous package (not much time tonight): player is walking.
then run "pet9.bas"
pet9.zip
Harm,
fun to see the sprite running araund the map and to see how it interacts with the Background ... top..
just an Idea:
It is possible to use negative values in the Sprite compressed Command if a part of the Sprite is still on the Screen.
so you can start painting the Tiles -16 or -8 Pixel from the left
so if you use stx or sty as an offset (subtile X and subtile y) with the values
-16,-8,0,8,16 you can get the 8 pixel wide scrolling
Sprite compressed sprite_index%(playersp+playermv),xs+stx,ys+sty
good job ...
cheers
Martin
Edited 2023-09-27 16:39 by Martin H.
'no comment
     Page 8 of 38
