Local Time 02:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite Test ver 2.5C - with serial, I/O
     Page 7 of 7
wizard
Posted: 01:49pm 08 Sep 2011
Hi Geoff,
Thanks.
I get a clean symbol table from nm Maximite.elf.
Now I just gotta teach my disassembler to intermix symbol names.
I am thinking it would be nice to be able to compile and interlink
some MMBasic add ons. An elf loader would also be nice. Thankfully
its all open source.
It all just SMOP - Small Matter of Programming ( consultant's joke :).
Wiz
Posted: 12:12am 09 Sep 2011
Marc,
Are you powering your Maximite from the USB?
If yes, could you try with an external power source (eg, 9V).
Versions greater than 2.5B draw a little extra current and that may be the issue. The bootloader draws a lot less current so that could explain why it still runs OK.
Fingers crossed,
VK6MRG
Posted: 01:00am 09 Sep 2011
Just so everyone knows, I only use USB power.
VK6MRG
Posted: 01:07am 09 Sep 2011
Geoff, I have plugged in an external power supply and I have run the tests again.
Even with the External power I have the same problem with 2.5c/d/e versions of MMBasic. Could it be that the chip has the problem? Dud chips do happen.
Marc, do you have or can you get another Maximite to verify the problems that you are having.
thetinkerer
Posted: 12:43pm 09 Sep 2011
Hi there Guys,
I am back! Been busy with work etc.
I have just tried firmware V2.5F and powered it with a plug pack and it works!!!
So I switched it back to USB power and no go!
I will dig out my other Maximite tomorrow and try it too.
Thanks for all the help guys.
regards
Marc
Posted: 09:07pm 09 Sep 2011
Hooray. The USB power must have been just on the limit of what it could supply.
thetinkerer
Posted: 05:22am 10 Sep 2011
Hi Geoff and All,
Just for info, I just did a little probing around and found the following voltages and currents(measured at JP1:
Running Firmware 2.5F on an Altronics Maximite.
Power Voltage Current
USB hub 4.62v 136ma (usb comms doesn't work)
Pc USB 4.9v 132ma (usb comms doesn't work)
Ext Power 5.07 137ma (USB comms works)
I didn't think that 4.9V would be an issue.
regards
Marc
thetinkerer
Posted: 08:23am 10 Sep 2011
Hi Geoff and All,
Running Firmware 2.5B on an Altronics Maximite.
USB hub 4.59v 141ma (usb comms work)
Pc USB 4.9v 136ma (usb comms work)
Ext Power 5.04 141ma (USB comms works)
regards
Marc
VK6MRG
Posted: 08:29am 10 Sep 2011
Out of interest, have you measured the 3.3v reg output voltage?
Posted: 12:53pm 10 Sep 2011
It is strange, especially when one version worked on 4.9V and the other did not. 4.9V is definitely within spec, the lower design limit is 4.5V.
I wonder if the issue is noise on the power line. I have found (as others have) that the PIC32 is very sensitive to noise on Vcap (pin 56) and if the 10uF cap (C5) is marginal in its specs, the noise might enough to tip the issue over.
If you feel like messing with your Maximite it would be interesting to see how it works with a 22 or 47uF tant cap in parallel with C5. I bet that it will work.
GeoffEdited by Geoffg 2011-09-11
     Page 7 of 7
