Local Time 03:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Leaving the Sinking ship - Moving to Linux
     Page 7 of 7
Posted: 02:24pm 03 Feb 2026
Fantastic!
And well done.
Bryan1
Posted: 05:39am 04 Feb 2026
Keepis here is some info on the distro I have here and a bit of info on this computer
System:
 Kernel: 6.12.63+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0 clocksource: tsc
   avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12.63+deb13-amd64 root=UUID=<filter>
   ro quiet splash
 Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0 with: xfce4-panel
   tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: MX-25.1_Xfce_x64 Infinity January
   18 2026 base: Debian GNU/Linux 13 (trixie)
Machine:
 Type: Desktop System: Dell product: OptiPlex 9020 v: 00 serial: <superuser required> Chassis:
   type: 15 serial: <superuser required>
 Mobo: Dell model: 0XCR8D v: A00 serial: <superuser required> part-nu: 05A4
   uuid: <superuser required> BIOS: Dell v: A25 date: 05/30/2019
CPU:
 Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3
Got that info from the system quick view and the next step is downloading Arduino and get that working as I do think I need to connect to the nano on the brainboard for my inverter to setup the inverter.
KeepIS
Posted: 06:21am 04 Feb 2026
I agree with John(S) great find with the i7 PCs.
It's crazy that corporate users are scrapping PCs just a few years old because of the MS Win upgrade path requirements. This may be even worse for MS than they realise, as the memory/SSD and some hardware supply sources for the whole of 2026 are already pre-allocated and bought out by big tec AI. I hope it bites all of them BIG TIME in the you know where, only time will tell - what utter stupidity.
The HW restrictions by MS for Win systems may have been hit with a perfect storm of upgrade supply demand doom.
Bryan, that looks really good, the only difference is the ahs release Kernel is at 18.8-1 and waiting for the official release of 6.19 in a few weeks, but with the version you installed (or any version) it will be a great system with the i7 PC, I doubt you will notice any differences between the releases.
Bryan1
Posted: 06:36am 04 Feb 2026
Well downloaded the Arduino software and programmed a nano with the inverter code which did work first time too
Well nothing showing in the code where further settings need to be done and found the serial monitor was blank.
Anyway what is a good terminal program for MX as I reckon connecting via that may show a different story.
Now using the USB-format app did format the 32gig disk drive but I did find with the 32gig SDCard it kept falling over with an error so will try again tomorrow. Win10 did stuff this SDCard up failing to load the ISO properly.
Edited 2026-02-04 16:40 by Bryan1
Posted: 07:06am 04 Feb 2026
  Quote  Win10 did stuff this SDCard up failing to load the ISO properly.
Have had that too. Used Linux gparted to wipe it and create a new FAT32 partition.
KeepIS
Posted: 10:50pm 04 Feb 2026
  Quote  Anyway what is a good terminal program for MX as I reckon connecting via that may show a different story.
gtkterm  or
GFXterm by forum member robert.rozee
These are uncluttered and simple to get running for USB coms with things like the Arduino Nano etc.
Edited 2026-02-05 10:10 by KeepIS
KeepIS
Posted: 06:20am 27 Feb 2026
I've had the chance to try a few different distros, all running on the same hardware and drive, including Linux Mint, Ubuntu, Zorin ETC..
To tell the truth, once installed, all are easy to start using straight away, the main difference from a user perspective is the Desktop, power users experience will vary as the underlining OS gets used via the terminal ETC..
Obviously when you get below the desktop (and related desktop apps) to the underlying file system and terminal commands, there are some small and a few big differences.
On my MX-25 installed version, which feels like a rolling release as I get updates daily, including Kernel version increments, now at 6:18.13-1.
If you use the same desktop then it's "almost" like any Linux running that desktop, no I did not notice anything faster than Xfce and the MX-25 ver I use, some were not as responsive as MX-25.
Today I decided to try the latest CatchyOS Arch Linux distro, which allows you to select from around 18 desktops, or install most of them and select which desktop to open at logon.
The install was a pain with an error of not enough space in the EFI partition, main windows efi partition is around 300mb to 500mb, this WANTS almost 5GB ??.
This is Drive C and it has a cut-down Windows11 (previously installed) and my Linux MX-25 as the 2nd last partition, between those two OS's I have play around partitions.
So I resized one of the partition and placed a 5GB fat32 partition before another resized partition for CatchyOS.
Setting the 5GB partition as boot/EFI was all it needed to bypass the install error. This will catch out some users as the boot efi entry may not show in the boot menu.
Fortunately the MX-25 "Boot Options" is brilliant to use manually, if you can't fix it there, then "Boot Repair" is seriously good, it searches and places all OS links and OS boot options, including Windows, into the boot partition menu correctly.
Anyway, I installed two desktops, Cosmic and Xfce.
With Xfce desktop it feels almost the same as MX-25 Debian with Xfce, tried Cosmic desktop, and yea, nice, but don't know what the fuss is about, just me I guess, as Xfce can be made super luxurious and is so responsive, and menu options are just brilliant.
My reason for this was to try installing some Apps I use that are not in the general repos and to see how much trouble I had with user and groups settings, and getting the USBasp and others running, it took a little longer, as I had to use terminal commands for everything, which I also did in MX-25 to understand what happens behind the GUI's, just in case, was a wise move and time well spent.
User groups are slightly different to the other distros, but in the end it all went smoothly.
I found it would not run an AppImage as it complained of some missing dependencies, however it gave me the option to install the AppImage itself, instead of trying to run it, and offered a command line option for installing from the AppImage.
It placed everything in container folder of sorts, by the looks of it, I haven't looked more into that due to time constraints. It downloaded all needed dependencies and the app ran perfectly once I made a launcher for it, same as MX-25 launcher, which looks to be part of the Xfce desktop experience and right click options.
I'm looking forward to getting under the hood and discovering the system apps ETC.
I see no reason to change at the moment, it's just nice to see what other distros have to offer in case something goes wrong in one branch of Linux.
I'm not happy with the path Ubuntu and others are taking, which is why I went to Debian MX-25 and Arch CatchyOS as a 2nd option.
FYI: My poor initial attempts at a GUI script has come a long way, the one I posted was a bit cringe worthy, but gee it's going nicely now.
Finally, for anyone using the USBbasp programmer who hates the error "upgrade firmware could not setting tick period", the firmware can be upgraded and that message is now gone after I upgraded the USBasp programmer.
Edited 2026-02-27 18:09 by KeepIS
Posted: 08:12am 27 Feb 2026
Interesting!
A bit odd that an AppImage wouldn't just work.  Has me puzzled.
(I hardly ever use one, though, and I guess most users never will).
KeepIS
Posted: 08:28am 27 Feb 2026
Funnily enough, there was a big tech discussion about Snap, AppImage and Flatpacks a while back.
From the comments posted to the discussion, opinion of results varied with various Linux religious beliefs, like everything in this world some thought feelings mattered more.
But from a technical coding perspective, the outcome was that AppImage was fine, but poorly implemented in some cases.
The smaller Appimages ran without issue in both OS, from memory I had to download some dependencies in MX-25 before the Image would run, but I was very taken with the install option offered in Arch CatchyOS, and how smoothly it did everything with that AppImage.
Sometimes a program I want is only available as an AppImage, so I'm happy to use them if required.
Mike
dddns
Posted: 08:29am 27 Feb 2026
CachyOS is special compared to other distros:
CachyOS is a Linux distribution based on Arch Linux. It focuses on speed and security optimisations - the default Linux kernel is heavily optimised using the BORE (Burst-Oriented Response Enhancer) scheduler, while the desktop packages are compiled with LTO, x86-64-v3 and x86-64-v4, Zen 4 optimization, security flags and performance improvements.
On my I5 Gen3 is does not run, I3/5/7 Gen4 is minimum requirement. I don't want to use it anyway, only if these optimizations would get into the vanilla kernel..
Posted: 09:51am 27 Feb 2026
  KeepIS said  Funnily enough, there was a big tech discussion about Snap, AppImage and Flatpacks a while back.
I'm so far avoiding snap and flatpack but have resorted to AppImage occasionally and without hassle.
What errors did you get using AppImage?  I thought it meant all libs were included (thus the bloat) and so all it would need would be the relevant APIs.
A Wayland/X.org-related problem?
pwillard
Posted: 12:47pm 27 Feb 2026
I also tried CACHYOS recently.  It didn't last a week on my pc as I didn't have the patience to deal with it.
KeepIS
Posted: 10:43pm 27 Feb 2026
  JohnS said  I'm so far avoiding snap and flatpack but have resorted to AppImage occasionally and without hassle.
No, the problem AppImage was the Arduino_IDE_64bit, it needed what looked like a very early version installed in MX25 Debian, later I found info suggesting this.
BTW CatchyOS by default has very little extras included with the install.
Trying to run the Arduino_IDE AppImage in Debian simply did nothing, and obviously the next thing you do is run it from the terminal to get the error output. So a few packages downloaded and it was running.
With CatchyOS, when launched from the terminal, it suggested installing the AppImage by running the AppImage with command line options it provided, everything appeared to go into one folder.
I spent some time last night playing with CatchyOS, and I kind of wished I had not, it is very addictive.
The gaming options are crazy (to me) and the ability to install any Kernel version including the beta versions of Linux Kernel 7.X. I'm now running 6.9x stable, and the CPU info on my Core Ultra 9 is finally correct for all cores and temperatures, including true running speeds.
There is Single click on/off system, kernel, zram and gaming optimisations, the more I look under the hood the sweeter and more professional it looks.
I intend to install other software over the next few weeks, basically mimic the current MX system and see how it goes, also knowing that I will be doing things that could likely cause stability issues, but they can be undone.
I did that with MX-25 and learnt how to fix seemingly non responsive Linux OS on a number of occasions, time well spent for me IMHO.
Posted: 11:07pm 27 Feb 2026
Ah, I see what you mean by addictive.  Thanks.
Edited 2026-02-28 09:07 by JohnS
     Page 7 of 7
