Forum Index : Microcontroller and PC projects : CMM2 5.05.06 beta
As of version 5.05.06b4, the arc command still has the "smear stuff on the top line when drawn partially or completely off the top of the screen" bug. Visit Vegipete's *Mite Library for cool programs. |
What about the latest version? Example code? |
I just flashed 5.05.06b10 and it too shows the bug. Sample program is from bar1010's learning programs. I see his program is in mode 1,16. 'Draw Arcs demo by bar1010 dim integer x, y, i, o, s, e, r, g, b, j cls mode 1, 16 j = 0 do x = rnd * 800 'x pixel coordinate y = rnd * 600 'y pixel coordinate i = rnd * 145 'inner radius o = rnd * 2 + i 'outer radius s = rnd * 340 + 1 'start angle e = rnd * 340 + 1 'end angle r = rnd * 255 'red g = rnd * 255 'green b = rnd * 255 'blue 'ARC X, Y, R1, R2, A1, A2, C 'Draws an arc with the center at the X and Y coordinates. 'R1 and R2 are the inner and outer radius defining the 'thickness of the arc. If they are the same the arc will 'be one pixel thick. A1 and A2 are the start and end 'angles in degrees. C is the color of the arc. arc rnd * x, y, i, o, s, e, rgb(r,g,b) pause 575 j = j + 1 if j > rnd * 925 then cls j = 0 endif loop Visit Vegipete's *Mite Library for cool programs. |
OK, this is a nasty one with the watch dog timer. Twice now, I have edited a program and pressed F2 to save and run and all I got was the watch dog message "Error: System fault - check code". At the bottom of the screen, the same path and file name is listed. However, that file on disk is now blank! Checked the SD card on a computer and the file is empty, zero bytes. The first time was with the Arc Demo program above (35 odd lines), the second was with LunarLander v72 (745 lines) The problem is likely my SD card. I have noticed it to be very slow to write on the CMM2. It works fine, just it's slow. Clearing a file is a bit harsh though. Can the watch dog be turned off? edit: I see this matches thwill's report from a few posts back. . Edited 2020-09-21 06:58 by vegipete Visit Vegipete's *Mite Library for cool programs. |
Please find attached V5.05.06b11 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip Fixes bug in ARC command in 16-bit modes Adds additional checks for the H/W watchdog in the USB and SDcard routines New parameter for OPTION USBKEYBOARD: OPTION USBKEYBOARD lang [,noLED] Set noLED to 1 to disable sending the light LED control command to the keyboard after caps lock etc. Can avoid hangs on some keyboards. Defaults to 0. This setting is preserved after subsequent firmware updates |
Thanks as always Peter. As an observation OPTION LIST doesn't show the new LED parameter - sorry! Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
I'm not sure if this is a transparency bug, I'm probably misinterpreting the manual. Sprite write doesn't work with a (transparent) black sprite. The manual for sprite write says "Overwrites the display with the contents of sprite buffer ‘n’ with the top left at coordinates ‘x’, ‘y’" which I thought means it should write a black rectangle, but it doesn't do anything. I tested in 12 bit mode and 8 bit mode, in V5.05.06b11. Test case attached. gbug.bas.zip |
Black is always the transparent colour in 8 and 16 bit modes so will never show. In 12-bit mode you can have transparent black or solid black Try tile.colour(tile.empty)=RGB(black,15) |
I've honestly been trying to bite my tongue on this, but failed, please feel free to ignore or make some withering putdown. The error message "Error: System fault - check code" is just too ambiguous, the "check code" still sugegsts to me that there must be an error code, even though I know that is not the case. Suggest changing it to just "Error: System fault" and then one of: 1. Document possible causes in the manual. 2. Follow with a list of possible causes, e.g. Error: System fault Possible causes: - PRINT command followed by other keyword, e.g. PRINT AS - POKEing somewhere you shouldn't - CSUB taking too long to run without calling <foo> - firmware bug 3. Set the background blue and fill with apparently meaningless pseudo-technical gibberish. Runs and hides, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
I'm waiting until I'm sure the H/W watchdog can stay in place but 2 seems like a good idea. Hopefully in b11 you are not seeing the error any more unless forced with print? The watchdog is quite difficult as it is windowed. You can't ping it too soon or too late. The easy solution is to ping it in the clock interrupt but I don't want to do that as it is quite possible for the S/W to be in a tight loop but interrupts still work. Edited 2020-09-21 23:40 by matherp |
I haven't seen it since the latest update (b11) even when I remove and reinsert the USB keyboard when running ... but then again I haven't been using the CMM2 other than to test your keyboard fixes. Also note I'm now using SD TIMING NORMAL, so if the file zeroing problem was related to SD TIMING FAST I won't be reproducing that. Thanks for everything, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Wasn't |
Wasn't OK, does that mean you think you have found and fixed the cause? It was occurring for me before the introduction of the watchdog ... it just zeroed the file and hung previously. Regards, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
No: I've just stopped the watchdog tripping by pinging it in the SD wait loops. The issue is that for some reason your SDcard is stopping responding which is why the watchdog triggered and why before the firmware would lockup. I would suspect a bad block or something similar. |
No: I've just stopped the watchdog tripping by pinging it in the SD wait loops. The issue is that for some reason your SDcard is stopping responding which is why the watchdog triggered and why before the firmware would lockup. I would suspect a bad block or something similar. OK ... <he says doubtfully> ... I think my mental model is missing something because I thought the watchdog was new in beta 6 and the issue predates that. I'm guessing there is a distinction between what you refer to as a "watchdog" and what your refer to as a "watchdog timer" ... alternatively I'm just displaying my ignorance. ![]() Anyway if it's fixed then that's great. For what it is worth Win10 chkdsk doesn't think there is anything wrong with my SD card. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
It isn't fixed. I just found that sometimes SD access took longer than the watchdog so I'm pinging it in the SDcard access routines. I haven't done anything that would impact whatever may have caused your problem, nor can I see a reason. Try the attached and see if you can break it. This saves to a temporary file and only if that works deletes the original and renames the temporary file. Worst case should be either the edit isn't saved or you end up with temporary file instead of the proper name (filename would be number in hex between 1 and FFFFFFFF) CMM2V1.5.zip |
Thanks Peter, I'll keep you apprised. Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Version b10 was unusable for me, probably due to my slightly duff SD card so I had rolled back to b5. So far, b11 is working great. I can edit, save and run, test, and repeat with no clearing of the file on the SD card! Awesome! =========== I wonder if Peter talks with a slight Scottish burr? Kirk: "Scotty! I need more power" Scotty: "Captain! The firmware, she canna take it!" Kirk: "I need those features!" Scotty: "It's impossible and it'll take me three weeks to do it!" 10 minutes later, Scotty is finished the upgrade, along with half a dozen other improvements. Sound familiar? Visit Vegipete's *Mite Library for cool programs. |
I spoke too soon. I just got another "Error: System fault - check code" and the file I was editing is now 0 bytes long. I guess I should try a different SD card... Visit Vegipete's *Mite Library for cool programs. |
Try the one I posted just above. Should never kill the file. |
