Local Time 08:55 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: DS18B20 Temp sensor problem
     Page 7 of 7
Posted: 09:51am 13 Mar 2025
  Quote  Does it make a difference to?
tempr start(xx):pause xx:? tempr(xx)
No, as that works you don't need the function.
The output for the test program is about the same as one of my non-genuine units. With that one I can eliminate the Pause with Tempr Start GPxx,3 : ? tempr(xx)
dddns
Posted: 09:58am 13 Mar 2025
As the time to get a result can't be eliminated and "start tempr xx" eliminates the need to wait as well, for me everything is fine as it is.
Posted: 12:10pm 13 Mar 2025
In the new PicoMite firmware V6.00.02RC0 Peter has added:-
  Quote  function TEMPR(Pinno [,timeout]) 'new optional parameter timeout to override the default (200mSec) to allow for slow devices
command TEMPR START GPno [,resolution(0-3)] [,timeout]  'new optional  parameter timeout to override the default (100, 200, 400, or 800mSec) to allow for slow devices
Edited 2025-03-13 22:10 by phil99
dddns
Posted: 02:06pm 13 Mar 2025
mine seems to be now even faster than the specs :))
> do:timer=0:tempr start gp15,3,474:? tempr(gp15),timer:loop
23.75   483.978
23.75   483.885
23.75   483.947
23.75   483.948
23.75   483.945
23.8125         483.951
23.75   483.947
23.8125         483.951
23.8125         483.95
23.8125         483.948
23.75   483.953
23.75   483.953
23.8125         483.944
23.75   483.954
23.8125         483.953
23.875  483.95
23.875  483.956
23.9375         483.953
24      483.943
23.9375         483.958
> do:timer=0:tempr start gp15,3:? tempr(gp15),timer:loop
23.75   809.8
23.875  809.876
23.8125         809.944
23.8125         809.951
23.875  809.955
23.8125         809.953
23.8125         809.946
23.8125         809.951
23.8125         809.948
23.8125         809.943
23.8125         809.959
23.875  809.945
23.8125         809.95
23.8125         809.951
The magic 473ms seems to work for all modes, but no ms less..even for mode 0
Edited 2025-03-14 00:11 by dddns
Posted: 03:17pm 13 Mar 2025
  Quote  The magic 473ms seems to work for all modes, but no ms less..even for mode 0
Hmmm - not exactly to the data sheet
Posted: 08:36pm 13 Mar 2025
Based on my test code, your chip pretends to change mode but takes the same time for each resolution.
That is not possible.
Your chip is of uncertain accuracy and bears no resemblance to the data sheet figures.
Peter has added code to allow these dubious chips to be used more easily but it in no way makes them "genuine"
If you change the chip, you will have to determine the timing again so they are not readily replaceable. Each one needs calibrating for each resolution of interest.
     Page 7 of 7
