Local Time 14:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VAR CLEAR
     Page 7 of 7
Posted: 01:53am 23 Jan 2019
I was testing on Windows 10.
The problem is rather obscure, and you have to do a specific set of steps to make the error show up, so that was perhaps giving the impression that Windoze 7 was responsible somehow. Members probably tried your problem code, but got no error, so thought no more about it. It only becomes evident when you reflash MMBASIC into the chip and VAR RESTORE is used for the first time. It's quite a crafty one.
PeterB
Posted: 02:30am 23 Jan 2019
Thanks for that.
Now we know!
On any version of windows, loading V5.05.01 will corrupt that part of the chip used by VAR.
Trying to do VAR RESTORE or VAR SAVE xxxx will result in an error.
The problem can be fixed by clearing the corrupted memory by entering NEW or VAR CLEAR. Using MMedit automatically inserts NEW.
Would you agree with this?
Peter
Edit
please inset after Now we know!
PEdited by PeterB 2019-01-24
Turbo46
Posted: 03:24am 23 Jan 2019
I'm not sure about the VAR SAVE xxxx but don't forget the OPTION AUTORUN ON has to go first then VAR RESTORE. You can then remove the OPTION AUTORUN ON and still get the error.
Geoff knows!
PeterB
Posted: 05:42am 23 Jan 2019
I thought I had got it down to a nice simple elegant description and was not even close.It's probably just academic now but I would really like to have it clear in my own mind. It's been bothering me now for the best part of 3 weeks. BUMMER.
Peter
Posted: 10:18am 24 Jan 2019
Thanks guys, that is a subtle bug.
If you use OPTION AUTORUN ON it will cause an error in any subsequent VAR RESTORE or VAR SAVE commands. The workaround is to use the following (at the command prompt) to set autorun:
OPTION AUTORUN ON
VAR CLEAR
Then you are good to go. I will fix it in the next release.
     Page 7 of 7
