Forum Index : Microcontroller and PC projects : uM2(+): data logging - cheap fast & easy
Good morning Peter. you are well I trust. What are the chances of revisitng this and placing the functions int he ARM Mite (and MMX) firmware? These are mega-useful chips confined to the '170 (and 470?) platform. The ARM Mite definitely is a big controller but has only SDCard support. just a thought all the best h |
Afternoon all. Just a note to say there is a code-pack for Reading/Writing Winbond flash memories now in the library here This is a pure MMBasic solution (no CSubs/CFunctions) so MMX and ArmMite users can now enjoy these fantastic little chips. The code has been tested on 4 and 8MB devices and I will check other chips as they arrive (16MB on order) enjoy |
Thanks for this powerful addition to mmbasic storage options, and thanks for making it work across chip families. Your work with the library is much appreciated. When I'm looking for a new solution, I've learned to browse the library first if a forum search doesn't satisfy. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
welcome. Blame BigMick |
| TrevorH Senior Member Joined: 06/04/2018 Location: United KingdomPosts: 145 |
Hi, Is there away to access the Flash memory chips on SPI2 on an E100 when the Touch is enabled? I can access it when Touch not enabled but with Touch enabled SPI2 error is "Not Open". uncommenting "SPI2 Open 10000000,0,8" error is "SPI2 is in use". We can still use SD card with Touch. TrevorH |
No sorry - see top of page 11 in the MM+ manual |
