Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Radar
     Page 6 of 8
Posted: 08:25pm 12 Dec 2025
Don't have a cat to test with but small dogs are OK.
One issue is with multiple targets.
It tends to get the targets mixed up so the dog becomes the cat.
For the price, they are a useful gadget to have in the collection.
I might put a portable one outside to see if it can track the rabbits.
Posted: 08:30pm 12 Dec 2025
  Quote  I might put a portable one outside to see if it can track the rabbits.
The screen would be completely covered in dots here!
v.lenzer
Posted: 04:51pm 14 Dec 2025
Hi Gerald!
If I wanted to integrate a menu (touchscreen operation), what would be necessary or useful for an LCD display? It's only about configuring the application before starting it.
- Single/Multi target tracking
- Enable/suppress zero x-axis values ​​(what exactly is that?)
- Exit (for when the radar is installed in a housing and you can operate it without the RP2040 via an app)
- Start
Best wishes! Joachim
ville56
Posted: 09:17pm 14 Dec 2025
Joachim,
I think any display supported by MMBasic with SPI and XPT2046 touch controller will do. You could even use a capacitive touch with Ft6336, but the accuracy is not so good and you need a touch-pen as the displays are IMHO generally too small to be touched with fingers directly. But depends on the size of screen objects you are using and the size of the fingers. Resistive displays react on fingernails quite well, capacitve don't.
There are no higher speed requirements as the refresh rate is 10/second.
So I would prefer SPI because the number of wires needed is lower than with parallel. If possible/affordable, use an IPS panel, not TFT as contrast and bightness are higer and readability in bright environments is better. If you want to store something on SD-card, you can get a display with integrated SD-card. Usually they work
For the supported display controllers look at the picomite user manual (the draft for V6.01 is already available but V6.00.03 will do as well). Important is the controller for the LCD and the touch. TFT and IPS make only a difference in the option statement at the configuration (IPS usually needs INVERT). You can chose from a range of physical display sizes and x/y resolutions. On e.g. AliExpress you will find matching displays as well as on Amazon or ebay. Berrybase is an option in Germany as well. It's your choice ...
Conrollers I've already used cover ILI9488, ST7796, ST7735, ILI9341 (I even retrofitted it with an IPS panel).
Beware of the yellow boards with ILI9341/FT6336 and IPS on ALi if you want to use SD. The SD-Card is completely unusable because of wrong layout of the board. Otherwise the display and touch do work well.
ILI9488 controllers have an issue when you want to read out the display into the pico with the touch controller. There are threads on this forum discussing different solutions. But they all need some soldering on the display board.
Another option are Pico-ResTouch-LCD-3.5 or Pico-ResTouch-LCD-2.8 from Waveshare. They have the socket for the Pico-board integrated, so you just plug the pico-board in. The down side is that there is no access to the Pico pins via a connector. So you have to solder the serial line to the pico board (sic!). Not really nice looking, but doable if you do not intend to change the pico often. Also has SD-card on board. PRO: the least wiring required of all options.
But there are, of course, some points to may take into consideration:
If you want to mount the project in a box, you migth also consider the mounting holes of the displays, as they are sometimes not optimal, dependig on the box you intend to use. E.g. the Waveshare displays have only nuts on the backside, the rest (I have) has holes that can take screws from the front side. If you want the SD-card changeable, you need to take into account the position of the SD socket.
On the software side the GUI statements are simple to use and work quite well for what you have planned. The complete touch subsystem is there and deliveres interrupts. Note: you cannot use a WebMite then, because MMBasic on WebMites doesn't support GUI.
Hope this helps more than I've confused you ...
Gerald
Edited 2025-12-15 07:22 by ville56
73 de OE1HGA, Gerald
Posted: 09:59pm 14 Dec 2025
  Quote  MMBasic on WebMites doesn't support GUI
Yes, that complicates things a little but isn't a deal breaker.
The Advanced GUI Controls can't be used but the standard drawing and text commands along with the basic touch functions can be used to construct a usable user interface.
For example a row or column of buttons (Circle or Box) with adjacent text to describe their function can be drawn. Then define the area of the buttons to set variables when touched.
For numerical input label the buttons 0 to 9 and "Enter". Multi digit numbers can be assembled by appending the individual digits to a string then converting that to a number.
ville56
Posted: 10:21pm 14 Dec 2025
You are right of course. It can be done, if you are willing to take the burden. And how big the burden is may be different for each of us. So I mentioned it just as a point to consider but yes, my phrasing may have been misleading.
Posted: 12:24am 15 Dec 2025
A primitive example to control the screen backlight.
' rudimentary screen backlight control
Sub MM.Startup
  Dim BL = 11 'initial setting
  Backlight BL
  CLS 64 'dark blue
  SetPin gp23, INTL, TouchInt 'set the T_IRQ, PEN or T_INT pin
  'define 2 buttons, top right and bottom right
  RBox MM.HRES *.8, 1, MM.HRES *.2, MM.VRES *.1, 9, RGB(white), RGB(myrtle)
  Text MM.HRES*.9,16," Bright ","CM" 'label the top button
  RBox MM.HRES *.8, MM.VRES *.9, MM.HRES *.2, MM.VRES *.1, 9, RGB(white), RGB(myrtle)
  Text MM.HRES*.9,MM.VRES-16," Dim ","CM" 'label the bottom button
  'your program here
Sub TouchInt
 Do While Touch(x)+1 'continue reading touch until released (then Touch(x)=-1)
  If Touch(x) > MM.HRES *.8 Then 'read only the right side of the screen
   If Touch(y) < MM.VRES *.15 Then Inc BL,1 'read the top of the screen, adjust BL up
   If BL > 99 Then BL=100
   If Touch(y) > MM.VRES *.85 Then Inc BL,-1 'read the bottom of the screen, adjust BL down
   If BL < 2 Then BL=2
   Backlight BL
   Text 10,10,Str$(BL,3)
   Pause 50
  EndIf
 Print "Backlight ="; BL
End
Edited 2025-12-15 10:30 by phil99
ville56
Posted: 10:19am 15 Dec 2025
somehow that doesn't work for me ...
I've set
 Option touch gp 10,gp9
and in the code
 setpin mm.info(pinno t_pin), intl, __t_isr
where t_pin = "GP9"
which gives me
[30] SetPin MM.Info(pinno t_pin), intl, __t_isr
Error : Pin 12/GP9 is reserved on startup
so for some reason it cannot connect the pin interrupt to the pin already assigned in the option touch ...
According to the manual it should work that way but it doesn't.
Posted: 10:58am 15 Dec 2025
That is odd. The only difference I can see  is mm.info(pinno t_pin) returns the Pico pin number as an integer and I am using the GP number.
This method has worked over many firmware updates so all I can suggest is change that line and see what happens.
Edit.
It works for me if done like this:-
Dim String t_pin = "GP9"
SetPin MM.Info(pinno t_pin), INTL, TouchInt
Edit 2.
Presumably the space between "gp" and "10" is just a typo in your post and not in the options?
Edited 2025-12-15 21:16 by phil99
ville56
Posted: 11:12am 15 Dec 2025
solved ... had "option gui controls 10" set. This seems to finally lock the touch irq pin. In the list pins it shows up as
 GP9     12     Boot Reserved : TOUCH IRQ
in both cases, so the unlocked state is not really obvious.
Posted: 11:19am 15 Dec 2025
Ok, I should have said that example was for the WebMite which doesn't have "option gui controls"
Edited 2025-12-15 21:25 by phil99
v.lenzer
Posted: 01:46pm 15 Dec 2025
The technical questions have already been answered. My question was more about the menu content. I think the option for single/multiple tracking needs to be included. Is "Enable/suppress zero x-axis values" necessary? And then a "start" option. That should be enough, right?
ville56
Posted: 04:41pm 15 Dec 2025
next version with "poor mans gui (pmg)" routines ... also usable on Webmite. Just try it and have fun.
The pmg routines are not really tested in depth and are not fully completed yet (circle) but sufficient for the current job and seem to run ok so far. The gui covers box and rbox and also rudimentary circle. Should be simple to adapt, I hope at least.
Radar-V2.0.2.zip
!!! Forgot to mention that you have to change the pin for the Touch interrupt in the code to meet your setup. Is currently hiden in line 134, sorry about that. Didn't think ....
Edited 2025-12-16 02:44 by ville56
ville56
Posted: 05:27pm 15 Dec 2025
Couldn't leave it as it was.
Radar-V2.0.3.zip
cleaned up ... just moved the touch pin definition to where it belongs, removed some debugging print statements and added some comments.
Wolfgang
Posted: 10:50am 16 Dec 2025
Hello experts,
the ordered radar modules have finally arrived.
I immediately started my first tests with that HLK-2450 and noticed that the radar- module update rate is not 10Hz/sec = 100ms as described in the manual, but was sent every ~50ms.
Is that correct?
Wolfgang
ville56
Posted: 10:59am 16 Dec 2025
According to the manual and what I did measure, it's 100 mSec. But your part may be a bit different, it's all chinese... But as long as the processing time is less than the measuring interval it should be ok.
Gerald
v.lenzer
Posted: 06:55pm 18 Dec 2025
Hi Gerald!
I'm currently trying to get version V2.0.3 working. I've calibrated the touchscreen. When I press the menu button (with the included plastic stylus), I get no response. I've left GP9 as the interrupt pin in the program as it is. Something seems to be wrong with that. Trying GP15 didn't help.
Do you have any ideas?
'PicoMite MMBasic RP2040 V6.01.00RC25
'OPTION SYSTEM SPI GP6,GP3,GP4
'OPTION COLOURCODE ON
'OPTION CPUSPEED (KHz) 200000
'OPTION LCDPANEL ILI9341, LANDSCAPE,GP7,GP2,GP5
'OPTION GUI CONTROLS 20
'OPTION TOUCH GP14,GP15
'GUI CALIBRATE 0, 172, 180, 895, 655
GP0 1 OFF
GP1 2 OFF
GP2 4 Boot Reserved : LCD Reset
GP3 5 Boot Reserved: SPI SYSTEM MOSI
GP4 6 Boot Reserved : SPI SYSTEM MISO
GP5 7 Boot Reserved : LCD CS
GP6 9 Boot Reserved : SPI SYSTEM CLK
GP7 10 boat Reserved: LCD DC
GP8 11 OFF
GP9 12 INTL
GP10 14 OFF
GP11 15 OFF
GP12 16 OFF
GP13 17 OFF
GP14 19 Boat Reserved : TOUCH CS
GP15 20 Boot Reserved : TOUCH IRQ
Edited 2025-12-19 04:56 by v.lenzer
ville56
Posted: 08:41pm 18 Dec 2025
Joachim,
you must not specify OPTION GUI CONTROLS.
If you do, you will not get an interrupt via a pin interrupt from the touch. And a pin interrupt is exactly what I'm using for the touch. Appearently the interrupt is then trapped by the GUI subsystem and does not reach the normal interrupt handler. I stumbled over exactly the same issue when developing the "poor mans gui" a few days ago. Unfortunately case this is not documented in the manual.
Edited 2025-12-19 06:46 by ville56
Posted: 09:39pm 18 Dec 2025
As a work-around perhaps instead  of assigning an ISR pin poll for Touch(x) in the main loop.
eg.
  If Touch(x)+1 Then t_isr
Sub t_isr
Tested OK in my previous example program. Now it doesn't matter if OPTION GUI CONTROLS is set.
Edited 2025-12-19 07:51 by phil99
ville56
Posted: 09:49pm 18 Dec 2025
touch interrupt is edge triggered, your workaround is level triggered. This may work or not depending on the processing logic and you waste cpu cycles for sure.
If "option touch" is specified you will get a pin interrupt on the irq-line if so specified with a
where t_pin is the touch irq pin.
And yes, I dislike polling and love interrupts. So my pov may be a bit biased ..-
Gerald
     Page 6 of 8
