Local Time 00:14 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : AI Research Project Ongoing
     Page 6 of 6
Posted: 12:17pm 13 Sep 2026
  Bryan1 said  playing a tune worked nicely with no cutouts ... sent the STL off
The range of tasks I give to Gemini, Claude, ChatGPT keeps expanding, and I continue to be impressed with the productivity.
Getting everything always working in all conditions remains a challenge.
Edited 2026-09-13 22:18 by lizby
Bryan1
Posted: 07:54am 25 Sep 2026
Just wondering if other Claude users have seen this change I have gotten, 4-5 hours then 2 hour and today no more Claude until Monday afternoon.
Now with 'IT' converting over club.py to MMBasic it has been an eventful time of bug after bug and that 24K file limit on HDMIWEB was causing problems with 'IT's' bloatware of the conversion job so I got it look at the firmware and now got 128K to play with but at the rate of these bans it may take a week or so to sort out the bugs and I'm glad we setup the 2040w for programming as repeated usb swaps weren't on anymore and transferring file over telnet was so easy. Now as MMBasic is a multi page system I got 'it' to make a pack/unpack system so transfer pack.pak via telnet then run unpack.bas which expands the unpacking and starts club.bas with the new code.
As club.bas does need some animation and interactive backgrounds draw.bas has been made and still only V0.001 so once again when the bugs are sorted and new commands put in like a [shrink] command much detail can done to make interactive buttons using the full screen then shrink them to fit the background picture so the buttons fit the area.
Now BT Classic has also been added to the firmware which is yet to test as I told 'IT' it cost me $100 for the Flip 6 so it's going to used in my code.
As I do have the weekend to fault find this new firmware attached in the zip file is step7tftpsafe.uf2 so if members can load this on a pico3 and give it ago and list all the bugs you find then post them it will make it easier on me trying to find them all.
Here is picture of my setup where computer B on the right has a dual screen mode so I can run club.bas on the HDMI setting while win 10 runs on the PC side the 2040W is on B USB and when any pico 3 is connected on B claude can ssh from my computer on the left which is my shed computer. Also got my TV on the right not pictured which is used so I can have 4 pico3's going and all connected by their own IP where networking still needs to be done.
To the upper left of my shed computer is a 48 port Enterprise Switch that provides power over ethenet so the Cisco wifi router connects all the boards on power up.
I'm sure if this will work but also zipped is pack/unpack.bas which the latest one before the ban so it is my club.bas system still full of bugs but have a look guy's.
Regards Bryan
PICO3_step7_tftpsafe.zip
pack.zip
unpack.zip
Edited 2026-09-25 18:25 by Bryan1
Bryan1
Posted: 10:15am 25 Sep 2026
Well looking further into claude found the reset button so it's back to game on getting draw.bas upto scratch
The main thing with MMBasic over micro-python when a file is uploaded there is no resets anymore as one just closes the page then opens it again with the new page
So now draw.bas is getting the work over so club.bas can have that interactive feel.
Regards Bryan
Posted: 11:06pm 25 Sep 2026
  Bryan1 said  Just wondering if other Claude users have seen this change I have gotten, 4-5 hours then 2 hour and today no more Claude until Monday afternoon.
I've been working more with ChatGPT Codex than with Claude Code for bigger projects, but yes, I've had multiple instances where I've run out of a 5-hour token budget and have had to wait to resume. Chat also gave me 3 "reset" bonuses and I used all three of them.
This has never happened with Claude or Chat in the browser, just in the agent-like instances of Code or Codex running in Powershell.
Bryan1
Posted: 06:31am 02 Oct 2026
Well I finally got sick of claude mucking around and getting nothing done so decided to see what life was like again with no AI
It has been a few years since I did the roads on the farm so with plenty of firewood to see us thru put the grader blade back on my tractor and after a full day got most of the roads done
The next day after some light rain the road base was the right moisture content so dragged a few more ton of roadbase off my pile infront of the house shed and builtup the erosion to reform the roads.
Well over the last 2 days had over 30mm of rain and the roads have held up well and got to see where the water does go so still got more to do so the water doesn't destroy the roads again.
Got back onto Claude about an hour ago and mentioned a new idea for my club.bas only to be told the tools he put on this computer aren't working right, now my suggestion of just fixing the problem went straight over 'it's' head so I turned it off in disgust.
So with these 5 boards I have I may just put a few of them up for sale on this forum, now the boards do have the ram and wifi chips on and are mounted in that 3D printed box I modified from the pico 2 case.
Regards Bryan
EDNEDN
Posted: 01:33pm 02 Oct 2026
What model and dial setting are you using?   That can make all the difference.
For coding stuff Sonnet 5.5 and Opus 5.5 at a medium setting are doing a very good job for me.
Edited 2026-10-03 14:41 by EDNEDN
Posted: 11:13pm 10 Oct 2026
My prompt to Claude Code: "Please set up Dock80_70 to turn on Tasmotized Sonoff Basic 2.12 (Livingroom thermostat bypass) every day for 5 minutes at 7am and 9:30pm with curl -s http://192.168.2.12/cm?cmnd=Power%20On (or Off); confirm that you have gotten the response. If not off as commanded, send me an sms message; you have com4"
Claude Code had apparently forgotten past efforts, so spent I'd say 50 iterations with the Dockstar back and forth, no interaction on my part, determining what was available, what current programs did, how email and SMS worked. It said it was done and tested in 5 minutes 9 seconds.
It pointed out that if the Dockstar rebooted or lost power while the bypass relay was on, it would remain on. I told it to put a turn-off in /etc/rc.local to handle a reboot, and a 20-minute timeout on the Sonoff with Tasmota's PulseTime1 setting. It did this and all completed in another minute and 37 seconds.
The Sonoff has a USB power plug plugged into it, and a D1Mini Relay module connected to that through a USB breakout board. When the Sonoff turns on the 120V, the power plug applies 5V to both the D1Mini Relay module and its relay-on pin.
This enables me to have automated or manual (e.g., from my phone) fine-grained control of heat in the 3 boiler hot water zones in my house without the heating company's $700 add-on module for the boiler.
Edited 2026-10-11 09:17 by lizby
Posted: 12:33pm 11 Oct 2026
I've just been playing with Proton's Lumo on the free tier. It's in Switzerland so comes under the EU GDPR. Everything is encrypted and kept away from everyone - even Proton has no access to your queries or the replies. On the free tier you appear to get 100 prompts per week and 7 days data retention. Even the most expensive layers are a lot cheaper than the big lads, but it's not as capable. Worth a look if someone just wants to dabble in AI for free.
Martin H.
Posted: 06:55am 12 Oct 2026
Someone Used AI to Clone Adobe’s Creative Apps.
Craft
It's kind of ironic: first, software companies used AI to eliminate programmers.
Now, someone is using AI to make software companies obsolete
Video
Edited 2026-10-12 17:01 by Martin H.
'no comment
PhenixRising
Posted: 10:03am 13 Oct 2026
Co-pilot can get pretty cheeky
I really like RFO-BASIC/OliBASIC for Android HMI programming. As it's an interpreter, it's a dog compared to B4A (compiler) but it doesn't have any of that event-driven, callback nonsense happening and so, paradoxically, my HMI feels snappier and programming is a breeze.
I decided to see if Co-pilot could use it but it doesn't fully understand the rules. It created a variable "dot". Can't do this because the interpreter sees a "do" and it created "cosd". Can't do that because the interpreter sees a "cos".
There was a moment of silence...
Co-pilot: "this is a primitive language!"
I almost fell off my chair.
Yes it's primitive but when you get used to it, stuff gets done real quick and no flakiness. Great for HMI creation.
Posted: 03:21pm 03 Nov 2026
My big project for the last 7 weeks with Claude, ChatGPT, and Gemini has been https://solarhomesinafrica.com, an investigation into how to bring meaningful non-grid electricity to one billion Africans who have little or no electricity--for about one five-hundredth the estimated build-out cost for AI over the next 7 years. I'm on version 6 of the "Solar Distributor".
But today I thought I'd do something different: building plans for a shed.
My prompt to ChatGPT Codex: Please produce construction drawings for a lean-to shed, 19' 7" by 11' 3"; 2x8 floor joists, 2x6 ceiling joists, 2x6 walls, back wall to top of roof sheathing 8' 6", front wall to top of roof sheathing 7' 6", 2' 6" door centered on back wall, no windows, 3/4" plywood floor, 1/2" plywood roof sheathing, 1/2" plywood exterior wall sheathing, dxf format.
Five minutes later with no further interaction from me:
Shed Drawings
Not perfect, but pretty amazing, and would have taken me many hours over the course of several days.
     Page 6 of 6
