Forum Index : Microcontroller and PC projects : Colour Maximite 2 Deluxe Edition with USB mouse support
| siwypiotr Senior Member Joined: 18/08/2020 Location: PolandPosts: 127 |
All I can say is sorry. I bought like 10pcs of those controllers from Aliexpress. It looks like some of them do not work. What I was expecting when buying from Ali... Sen me Your order no. I will refund You for faulty controllers. |
| William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 415 |
Piotr, I was successful in updating the firmware on the Deluxe CMM2 to the new 5.06.00, using the A-A cable and the flash/reset button combo. Worked like a charm! BTW, I had the same experience with the USB cables that were supplied with the Deluxe: dim green LED and no connectivity. I tossed them both. Sorry you are having trouble with your suppliers. -Bill |
I already changed supplier of USB cables. Controllers was more like a gift to first customer but it did not worked apparently... |
| MauroXavier Guru Joined: 06/03/2016 Location: BrazilPosts: 307 |
I had the same problem on many occasions buying these controllers from China. Try to look at the controller connector, see if some pin is sunk back or absent, open the connector with a screwdriver and fix the pin position, and try again. Edited 2020-12-29 23:24 by MauroXavier |
Piotr, that kind of supplier problem can happen to anyone. The good news is, the Deluxe unit works great. I was looking at the Atari joystick DB9 port and remembering that I have such a joystick buried in the attic somewhere. I was thinking of digging it out. But I looked at the 5.06.00 manual and noticed that it has commands for: controller mouse controller nunchuk controller classic but no controller joystick, nor can I find a joystick mentioned anywhere else. Does the controller classic or nunchuk or whatever work when you use an Atari-type joystick? -Bill |
Hi Bill ... but no controller joystick, nor can I find a joystick mentioned anywhere else. ... Joystick does not need to have firmware libraries, this are standard inputs, please try this code: SETPIN 35, DIN, PULLUP SETPIN 36, DIN, PULLUP SETPIN 38, DIN, PULLUP SETPIN 40, DIN, PULLUP SETPIN 32, DIN, PULLUP DO IF PIN(35) = 0 THEN PRINT"UP" IF PIN(36) = 0 THEN PRINT"DOWN" IF PIN(38) = 0 THEN PRINT"LEFT" IF PIN(40) = 0 THEN PRINT"RIGHT" IF PIN(32) = 0 THEN PRINT"FIRE" PAUSE 100 LOOP Does the controller classic or nunchuk or whatever work when you use an Atari-type joystick? Yes, all types of controllers can work in the same time, they use different set of pins. Edited 2020-12-30 03:03 by siwypiotr |
... but no controller joystick, nor can I find a joystick mentioned anywhere else. ... Joystick does not need to have firmware libraries, this are standard inputs, please try this code: SETPIN 35, DIN, PULLUP SETPIN 36, DIN, PULLUP SETPIN 38, DIN, PULLUP SETPIN 40, DIN, PULLUP SETPIN 32, DIN, PULLUP DO IF PIN(35) = 0 THEN PRINT"UP" IF PIN(36) = 0 THEN PRINT"DOWN" IF PIN(38) = 0 THEN PRINT"LEFT" IF PIN(40) = 0 THEN PRINT"RIGHT" IF PIN(32) = 0 THEN PRINT"FIRE" PAUSE 100 LOOP Does the controller classic or nunchuk or whatever work when you use an Atari-type joystick? Yes, all types of controllers can work in the same time, they use different set of pins. Might be a good idea for a little document explaining all the extra add-on things like this for reference purposes to be put together and available somewhere. Otherwise folks need to know which threads these additions were originally discussed that you then integrated into the Deluxe model... For example, things specific to the networking (like my question back a page or so), the differences with firmware updating, the DB-9 joystick stuff, the mouse stuff, etc. Edit: Ok, putting my money where my mouth is... Started putting together a document here. Feel free to add comments with additional information and I'll approve them for insertion... I think I've captured all the pertinent info from this thread in there. I'm just missing the I2C channel number that Nunchuck #2 is connected to... https://docs.google.com/document/d/1GxLlAIYY49C1VYhqHUMQDsNH0qktKDL4UmRUpln8GmY/edit?usp=sharing Edited 2020-12-30 05:49 by mkopack73 |
The spec sheet for the Deluxe lists a "Temp sensor". I assume we access this via the TEMPR() function call. But that call requires a pin number. What pin # is the built in sensor hooked to? |
Try pin 42. print tempr(42) VK7JH MMedit |
Try pin 42. print tempr(42) Cool. Thanks! Document updated... |
New Batch of Colour Maximite 2 Deluxe Edition have arrived! Shipment in 24h from order. https://sklep.pslabs.pl/Maximite-c91 Offer includes: - Colour Maximite 2 Deluxe Edition - HobbyTronics mouse host chip (depends from offer You choose) - ESP WiFi module - USB A-B cable - USB A-A cable - 16GB SD CARD Edited 2021-01-05 17:24 by siwypiotr |
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
New Batch of Colour Maximite 2 Deluxe Edition have arrived! Shipment in 24h from order. Hi - any news on your plans for a set of expansion boards for the CMM2? I'd be especially interested in the Wifi addon module that wasn't in the first gen CMM2 Deluxe. |
New Batch of Colour Maximite 2 Deluxe Edition have arrived! Shipment in 24h from order. Hi - any news on your plans for a set of expansion boards for the CMM2? I'd be especially interested in the Wifi addon module that wasn't in the first gen CMM2 Deluxe. Actually, that's not a bad idea - Maybe a singular add-on board that hooks in via the 40 pin expansion board that adds in the 2nd+3rd Nunchuck, DB9 joystick, wifi and other things that you added to the Deluxe to augment those who bought the original designs but want those features. Could sell it alongside the deluxe model... |
New Batch of Colour Maximite 2 Deluxe Edition have arrived! Shipment in 24h from order. Hi - any news on your plans for a set of expansion boards for the CMM2? I'd be especially interested in the Wifi addon module that wasn't in the first gen CMM2 Deluxe. Actually, that's not a bad idea - Maybe a singular add-on board that hooks in via the 40 pin expansion board that adds in the 2nd+3rd Nunchuck, DB9 joystick, wifi and other things that you added to the Deluxe to augment those who bought the original designs but want those features. Could sell it alongside the deluxe model... Good morning, Im still working on this, unfortunately Im unable to give it 100% of my time. But it will be done sooner or later. Most probably till end of the month I will have the design ready and order the first test batch. |
Having ESP WiFi module in my Maximite Deluxe was a big success. Unfortunately each of my customers wanted different firmware to be flashed on ESP. I can not make everyone happy but I can help them to be happy. You can change ESP firmware Yourself! No additional tools required: https://youtu.be/inHeLNZdrXQ |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
I wrote first version of FW for ESP in Maximite Deluxe (or any other CMM2 connected with ESP over serial port): CMM2ESP Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Has anyone with one of these Delux units able to tell me the processor part number on it please? STM32H7..... |
Same as CMM2. John |
John Can't be if it's 480Mhz,? the CMM2 is 400Mhz |
Try reading page 4 (Introduction) of the CMM2 manual |
