Local Time 14:29 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite L4 battery miser, first beta
     Page 6 of 8
Posted: 10:01am 24 Nov 2018
  Quote  it still gives me a full black screen between the one second updates if FULLREFRESHINTERVAL is left at 1.
This is the way they work I'm afraid. The response to partial updates seems to be screen specific. Remember these display were designed for applications like supermarket shelves where they updated very infrequently. For an application like a temperature display where the updates are, say, every 5 minutes the flashing display shouldn't be an issue. They certainly aren't suitable for anything remotely real-time
OA47
Posted: 10:07am 24 Nov 2018
Thanks for the info Peter, I was under the misconception that I should have been able to get the display to update a clock as per your Youtube video.
I will see if I can test the SetTick issue previously described.
Ran TassyJims code for SetTick and it seems to work ok.
OA47Edited by OA47 2018-11-25
sagt3k
Posted: 12:06pm 24 Nov 2018
Hi matherp
Thanks for your job... very beautiful STM32L4.
Can I have the list of all cpu freq for STM32L4/H7. , I'm modifying Micromite console to set by software all possible frequencies.
Antonio
Posted: 12:49pm 24 Nov 2018
  Quote  Can I have the list of all cpu freq for STM32L4/H7
H7 fixed 400MHz
L4 2,4,8,16,24,32,48,80
sagt3k
Posted: 03:44pm 24 Nov 2018
Thanks matherp
Posted: 12:51am 25 Nov 2018
Strange things happening with PAUSE
I decided to experiment with setting the RTC drift.
  Quote   ' armite clock test
OPTION LIST
timeout
t$=
TIME$
stalltime = (
60 - VAL(RIGHT$(t$,2)))*1000
PRINT stalltime
'pause stalltime
SETTICK 60000, timeout
timeout
DO
LOOP
SUB timeout
PRINT " ";TIME$;" ";DATE$
END SUB
This prints the time once a minute and I have MMedit set to time stamp each line.
  Quote  [08:55:01]> RUN
[08:55:03]OPTION LCDPANEL GDEH029A1, LANDSCAPE, 15, 21, 14, 22
[08:55:03] 08:55:03 25-11-2018
[08:56:03] 08:56:03 25-11-2018
[08:57:03] 08:57:03 25-11-2018
[08:58:03] 08:58:03 25-11-2018
[08:59:03] 08:59:03 25-11-2018
[09:00:03] 09:00:03 25-11-2018
[09:01:03] 09:01:03 25-11-2018
[09:02:03] 09:02:03 25-11-2018
[09:03:03] 09:03:03 25-11-2018
[09:04:03] 09:04:03 25-11-2018
[09:05:03] 09:05:03 25-11-2018
[09:06:03] 09:06:03 25-11-2018
[09:07:03] 09:07:03 25-11-2018
[09:08:03] 09:08:03 25-11-2018
[09:09:03] 09:09:03 25-11-2018
[09:10:03] 09:10:03 25-11-2018
[09:11:03] 09:11:03 25-11-2018
[09:12:03] 09:12:03 25-11-2018
[09:13:03] 09:13:03 25-11-2018
[09:14:03] 09:14:02 25-11-2018
[09:15:03] 09:15:02 25-11-2018
[09:16:03] 09:16:02 25-11-2018
Everything looks goods but then I decided to PAUSE the printouts until the seconds were zero.
Uncomment 'pause stalltime to delay the SETTICK by the appropriate time.
  Quote  [09:42:15]> RUN
[09:42:18]OPTION LCDPANEL GDEH029A1, LANDSCAPE, 15, 21, 14, 22
[09:42:18] 09:42:18 25-11-2018
[09:42:18] 42000
[09:43:00] 09:43:00 25-11-2018
[09:43:48] 09:43:48 25-11-2018
[09:44:36] 09:44:36 25-11-2018
[09:45:25] 09:45:24 25-11-2018
Instead of printing the time every 60 seconds, it does it 12 seconds sooner.
Using PAUSE has upset the timing.
Posted: 11:53am 25 Nov 2018
I can't reproduce using the latest version posted 7.06 24th November. Please can you check this version with and without the LCDPANEL enabled
Posted: 11:05pm 25 Nov 2018
The PAUSE problem seems to be specific to one chip.
That's two units that have ended up with strange problems in spite of full erase before loading firmware.
I will do some more testing.
sagt3k
Posted: 09:37am 01 Dec 2018
Hi matherp
On Armite-32p sometimes it happens that when I give "run" it displays this message:
Restart to activate
… even if I proceed to restart the message appears the same
This is the code:
option autorun on
option baudrate 115200
SetTick 1000,intx
Dim x As integer
x=x+1
Sub IntX
Print x : x=0
What does it mean?
Antonio
Posted: 09:41am 01 Dec 2018
You can't change baudrate in a program so if the baudrate isn't already 115200 you will get the message as it assumes you need to reset the terminal to the new baudrate and then restart the uP. I'll put a block on the command being used in a program in the next release.
palcal
Posted: 01:56am 31 Dec 2018
My L4 has been working great with an E-Ink display and HC-12 connected. I just connected a Humidity Sensor that works OK on an E-28. It is an I2C device, connected to D4-SDA and D5-SCL with 4.7K pullups but it wont work. Has any one used the I2C bus with no problems.
disco4now
Posted: 02:12am 31 Dec 2018
I used an I2C display on those pins with no issue.
i2c open 400,1000
F4 H7FotSF4xGT
palcal
Posted: 03:14am 31 Dec 2018
OK I was using I2C open 100,500 I tried 400,1000 but still no go. I will try re flashing the chip.
palcal
Posted: 03:41am 31 Dec 2018
OK I reflashed the chip with the last release and still not working correctly, the values I was getting were -40 c and -1% humidity and now I get 101c and 99%.
edit..Flashed again with the earliest Ver. with E-Ink and I am back to Getting
-40c and -1%
I can't help thinking it has something to do with the Firmware.
Edited by palcal 2019-01-01
Posted: 06:06am 31 Dec 2018
Can you post the code you are using.
I have a SHT21 here that is much the same as the HTU21.
I might have time to play tomorrow.
palcal
Posted: 06:46am 31 Dec 2018
Thanks Jim but it's New Years Eve and I have to party tonight.
Will post my code tomorrow.
Edit. Aw what the heck just have one less beer.
Here's the code..
DIM as integer TDATA(2) '2 bytes of temp data
DIM as integer HDATA(2) '2 bytes of humidity data
I2c open 400,1000 'Get Temp and Hum. from HTU21D
HTU21D
I2C close
Temperature = Cint(Temperature)
RelHumid = Cint(RelHumid)
InTemp$ = Str$(Temperature,2)
InHum$ = Str$(RELHUMID,2)
Print InTemp;" c"
print InHum;"%"
Sub HTU21D 'TEMPERATURE SENSOR, This is the SUB routine for talking to the HTU21
I2c write &H40,0,1,&HF3 'HTU21 addr= 40 hex, request temp = F3 hex
pause 100
I2c read &H40,0,2,TDATA() 'reads temperature
TEMP1=TDATA(0)*256 + TDATA(1) 'combines both data bytes
I2c write &H40,0,1,&HF5 'request humidity
Temperature=(175.72*(TEMP1/65536))+ -46.85 'HTU21 formula for temp
TEMPCOMP= -.15*(25-Temperature) 'for RH temp comp
pause 50
I2c read &H40,0,2,HDATA()
HUMIDACT=HDATA(0)*256 + HDATA(1)
RELHUMID= ((HUMIDACT/65536)*125)+ -6 ' measured humidity
RFHUMID= RELHUMID + TEMPCOMP 'Temperature compensated humidity
end sub
Posted: 09:09pm 31 Dec 2018
Happy new year!
I changed your program slightly but didn't touch the HTU21D SUB at all.
I had to add the missing $ from InTemp and InHum variables in the PRINT statements.
Even with a newly flashed chip I received an error with the I2C
When initializing it complains that I2C is already open and when closing:
[13] I2C close
Error: I2C in use for display
There is no display configured.
  Quote   DIM AS INTEGER TDATA(2) '2 bytes of temp data
DIM AS INTEGER HDATA(2) '2 bytes of humidity data
ON ERROR SKIP 1
I2C OPEN 400,1000 'Get Temp and Hum. from HTU21D
DO
HTU21D
Temperature =
CINT(Temperature)
RelHumid =
CINT(RelHumid)
InTemp$ =
STR$(Temperature,2)
InHum$ =
STR$(RELHUMID,2)
PRINT TIME$;" ";InTemp$;" c ";InHum$;"%"
PAUSE 10000
LOOP
' i2C close
SUB HTU21D 'TEMPERATURE SENSOR, This is the SUB routine for talking to the HTU21
I2C WRITE &H40,0,1,&HF3 'HTU21 addr= 40 hex, request temp = F3 hex
PAUSE 100
I2C READ &H40,0,2,TDATA() 'reads temperature
I2C WRITE &H40,0,1,&HF5 'request humidity
PAUSE 50
I2C READ &H40,0,2,HDATA()
HUMIDACT=HDATA(
0)*256 + HDATA(1)
END SUB
gives:
> RUN
07:55:04 20 c 49%
07:55:14 20 c 49%
The humidity is a few percent lower than a DHT22 running nearby.
This is with a HTU21 chip.
So it does work but I am seeing a strange problem with I2C and non-existent displays.
Posted: 11:00pm 31 Dec 2018
  Quote  but I am seeing a strange problem with I2C and non-existent displays.
Does this solve it?
2019-01-01_090022_ArmmiteL4.zip
Posted: 11:51pm 31 Dec 2018
  matherp said
Does this solve it?
Define 'solve'
I no longer get the error with I2C CLOSE but I still need the ON ERROR SKIP before opening.
I2C CLOSE doesn't seem to do anything.
> RUN
[5] I2C open 400,1000
Error: I2C already OPEN
> i2c close
> RUN
In fact, I can remove all references to I2C OPEN from the program.
Time for you to put the party hat on. 10 minutes to go.
palcal
Posted: 01:45am 01 Jan 2019
@Jim,
Thanks for testing, I was also getting the I2C error. I just connected an RTC to see if that worked, but get an error with RTC SETTIME
  Quote  > RTC SETTIME 2019,1,1,11,41,00
Error: Unknown command
> RTC GETTIME
> print time$
00:02:38
I think I might be ditching the L4 soon and using an E-28.Edited by palcal 2019-01-02
     Page 6 of 8
