Local Time 11:17 04 Nov 2026 Privacy Policy
     Page 51 of 52
Revlac
Posted: 12:51am 18 May 2026
While it is doable, the Charge controller has copper plate on top and bottom of the PCB so more unnecessary work leaving the NC legs on, personal preference perhaps.
Cheers Aaron
Off The Grid
nickskethisniks
Posted: 08:44am 18 May 2026
You could make a daughterboard "capacitor pcb" that fits the original holes. Or a redesign of the pcb, I could do that for the first version if you want. Wiseguy designed the last version that I can't modify. But you might have the boards allready?
It's a robust design made for long life so better do it first time right.
GleamBright
Posted: 06:49am 20 May 2026
I think I'll have a go at drilling the PCB with a template. My PCBs will be a part of a bulk order, so can't be individualised.  Likely will solder the NC connectors as well for support, since these are 90mm high. Also I will only need 6 if I'm correct.
My haul of choke candidates: Two small and one big, from an Aerosharp. Three small of comparable size to the small Aerosharp ones, one from a scrapyard of comparable dimensions to the large Aerosharp, and two from the Aurora of dimensions 106x52mm outside, width 45mm, centre hole 73x20mm.
Are the Aurora ones candidates, being substantially bigger than those sourced from Aerosharp? Any suggestions for installation?
Revlac
Posted: 07:12am 20 May 2026
The 5Kw Aurura choke, leave that one together it is practically good to go for the Charge controller, the 2 coils can be joined but the polarity needs to be checked with the an LCR Meter, forgot what the numbers are, you can find that out later.
Cheers Aaron
Off The Grid
dizzypanic
Posted: 12:34pm 29 Jul 2026
Chaps,
I've been following this for a while, it really is an outstanding piece of work! Now I'm in a position to start installing some solar here is there any way to get PCBs posted to France? Alternately is there a set of Gerbers available (or a KiCAD file) that I can get manufactured?
Cheers all,
Andy
wiseguy
Posted: 02:08pm 30 Jul 2026
Hello Andy, welcome to the forum and sorry for the slow response - I have been crook with the Lurgy for a couple of weeks but slowly coming out the other side now.
There are now two types of MPPT which are similar except for how they are configured.
The first unit was based on Nicks design, I re-designed a new PCB layout for the main MPPT. This also requires a separate Poida/Nano controller PCB and an LCD PCB and mounting them all becomes a bit of a task, as the main MPPT PCB quantities increase the ancilliary PCBs increase at a faster rate.
The second MPPT design was done by RogerDW, he used my new layout but grew the top of the main PCB so it could hold 2 nanos one for the Poida controller and the other converts and formats from the MPPT data to an I2C format that can drive an LCD display panel that accepts I2C. I believe there is also an option for using a simple 20x4 LCD with a little third party I2C data converter module that can drive the 20x4 LCD.
I need to be honest, whilst I revised the current MPPT Power PCB layout I have not made programmed or used an MPPT controller so my ability to assist much beyond providing you with PCBs is limited. Let me know whichever MPPT option you would like to choose. To differentiate them lets refer to them as the MPPT or the RogerMPPT. The PCB manufacturer only supplies PCBs in multiples of 5 so its either 5 or 10 units.
If you PM me your email (and physical) address I can send you a quotation direct from the supplier (JLCPCB) for 5 or 10 delivered to your door. I only ask for my out of pocket expenses to be reimbursed I make nothing out of helping you get the PCBs. This is the cheapest method for you to get the PCBs they do the customs forms and there is only the one freight charge.
It is possible I have a few original MPPT circuit boards from last time a batch was made I will check my workshop tomorrow - this would only be useful if you decide to not use the RogerMPPT.
Edited 2026-07-31 00:10 by wiseguy
Cheers Mike
GleamBright
Posted: 11:16pm 30 Jul 2026
Hi Andy, we have recently been through all this and are in the middle of procuring components and PCBs for Rogers' mppt design, for a group of Australians building various combinations of inverters and controllers.
I recommend purchasing the PCBs directly, preferably  together with people in your area. A list of components has been posted to the bottom of p4 of thread 'Wiseguy (WG) Inverter Build Discussions Australia'. The list is as complete and correct as can be, having been developed by direct consultation with the designers.
dizzypanic
Posted: 03:09pm 31 Jul 2026
Mike,
No problem, glad you're feeling better. I like the look of RogerDWs layout as you say it simplifies mounting and the enclosure. I'll PM you with details!
GleamBright,
Agreed, I think I'll get a run of boards made. I'm following the Australian build thread as well.
If there is anyone in Europe who wants a board/s please get in touch, I will see what the quote looks like and place an order probably in 2-3 weeks.
Thanks all, if there's any interest I will make a thread or add to this one when I get around to building and installing!
Andy
kentfielddude
Posted: 02:54am 03 Sep 2026
I was looking at this toroid core to use for the MPPT.
I think it would work pretty well.
https://www.digikey.com/en/products/detail/magnetics-a-division-of-spang-co/0077339A7/18626941?s=N4IgTCBcDaIOxwMyIJwEE4gLoF8g
45 turns of 6 awg or 4 awg wire.
nickskethisniks
Posted: 01:43pm 03 Sep 2026
  kentfielddude said  I was looking at this toroid core to use for the MPPT.
What is your power requirement, and input/output voltage?
kentfielddude
Posted: 04:55pm 03 Sep 2026
150v input, 50v output, 50amps.
The core losses really low with that kool-aid toroid.
Edited 2026-09-04 03:04 by kentfielddude
nickskethisniks
Posted: 08:05pm 03 Sep 2026
Yep a nice core! When calculating with 20khz and aiming for 20% ripple current with your requirements you need about 167uH usable inductance. Inductance will fall under load so with 45 turns you get about 2250AT (45T x 50A), inductance falls about 50% under that condition. Wich gives you 162uH ( 80nH*45²) under load, so a perfect fit. Also, the ac flux swing is verry low, so low core losses.
You might have put the numbers in chatgpt allready (like I did), or did it manualy.
Increasing switching frequency would result in a smaller core or lower ripple current, but having a nice winding window gives a nice inductor and better cooling performance.
Edited 2026-09-04 06:11 by nickskethisniks
kentfielddude
Posted: 11:33pm 03 Sep 2026
nick, I used Magnetics Inc design tool and I also looked at Digikey prices. They have a slightly bigger core but its 2x the cost.
I'd figure 20khz is probably good to reduce switching losses.
Edited 2026-09-04 09:34 by kentfielddude
kentfielddude
Posted: 04:19pm 05 Sep 2026
I've ordered a core from Digikey. 30% tarrif fee. Oh well. I'm doing this project more for its educational value than cost. I've been diving deep into theory.
Edited 2026-09-06 02:20 by kentfielddude
kentfielddude
Posted: 03:08pm 09 Sep 2026
One of those cores arrived here yesterday from Digikey. Looking at the calcualtor I think maybe 65 or 55 turns would be better.
kentfielddude
Posted: 05:07pm 15 Sep 2026
That kool mu core would work but it requires quite a bit of copper to get the copper losses down and it’s quite. A bit of turns. I may purchase another core and stack two of them. With one core you’re loosing an lot of inductance at 50 amps because it’s operating on the tail of the curve.
I was looking at micro metals and trying different configurations.
I found a really good potential design.
It uses a stack of 4  OC-250090-2
16 turns
If they aren’t too expensive I’m thinking about trying this design.
Edited 2026-09-16 03:09 by kentfielddude
SYM-1
Posted: 06:20pm 15 Sep 2026
Would you use 4 strands of 4mm2 or 6mm2 wire to wind the core?  I see a lot of big commercial designs go for that to make winding easier?  Also what is limiting the frequency?  I got very high losses at high frequencies.
Persistence is the key
kentfielddude
Posted: 12:43pm 16 Sep 2026
  SYM-1 said  Would you use 4 strands of 4mm2 or 6mm2 wire to wind the core?  I see a lot of big commercial designs go for that to make winding easier?  Also what is limiting the frequency?  I got very high losses at high frequencies.
I'm going to use multiple strands of magnet wire because that's what I have on hand.
Increasing the frequency increases your switching losses; i.e., your MOSFETs get hotter.
Core loss depends on what material your core is made of. Sendust is only good below 100 kHz. Above 100 kHz, eddy currents start to dominate and cause a lot of core loss.
It appears that all Micrometals powder cores are made in China. I believe Magnetics Inc. cores are also made in China. I was able to find the same cores on Alibaba for 1/6 of the price. I ordered 8 pieces of KS-520-060A.
Edited 2026-09-17 02:52 by kentfielddude
SYM-1
Posted: 11:32pm 16 Sep 2026
How many turns are you using on  the 6  KS-520-060A?
kentfielddude
Posted: 04:01am 17 Sep 2026
  SYM-1 said  How many turns are you using on  the 6  KS-520-060A?
I'm planning to use a 2 KS-520-060A.
KS-520-060A( MS-520060-2) is $10.40 piece
KS-521-060A (MS-521060-2) is $13.50 a piece
If I had know the seller had the KS-521 I would have ordered those instead.
I guess the differences between them isn't as much as I thought. KS-520 needs 5 more turns and the performance is very simmilar.
KS-520-060A
37 turns
13 AWG, 16 strands
220uh at 50 amps
9w copper loss
2W core loss
KS-521-060A
32 turns
13awg, 16 strands
Core loss 2w
copper loss 8W
With the KS-520-060A if I increase frequency to 40khz I only need like 110Uh at 50 amps. Which would mean I need 25 turns instead of 37. The switching losses double anyways. It's all a balancing game. An extra 5-20w in switching loss is only like 0.5% out of a 2500w output.
Edited 2026-09-17 14:03 by kentfielddude
     Page 51 of 52
