Local Time 04:26 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Coming soon a new software for Micromite
     Page 5 of 5
CFLY
Posted: 01:57am 24 Oct 2016
sagt3k
Posted: 02:16am 24 Oct 2016
HI CfLY
I don't understand why AVAST creates this warning. Can You create an exception on AVAST to run the application?
CFLY
Posted: 02:39am 24 Oct 2016
I look if it is possible ...
CFLY
Posted: 02:47am 24 Oct 2016
Exception on AVAST OK !
I can run the application
sagt3k
Posted: 02:54am 24 Oct 2016
Hi CFLY
You are welcome. Please try all the features and let me know if there are problems.
Sagt3k
sagt3k
Posted: 08:25am 24 Oct 2016
Hi drkl
Micromite Lab works so:
- has an editor dedicated for MMBasic and it allows saving to a local db
- has a UART and or TCP console to interact with HW
- Tutorial and Help can work directly with Uart or TCP
- "Script Engine" is an independent tool with 4 languages, is NOT connected with "Editor CODE", but you can interact with the dedicated commands with UART or TCP. It is possible to acquire data from Micromite MKII and put data on charts, or save data on mySQL DB or send data to DWEET etc. It is provided with a set of commands to create complex graphics control, events on objects etc.
Manuals are under construction that will bring all the users to be able to use all the instruments developed.
Thank you for your interest
sagt3k
drkl
Posted: 09:31am 24 Oct 2016
Hi sagt3k,
Thank you. It is an exact reply. I understand. (Waiting for manual ....)
drkl
isochronic
Posted: 08:07pm 24 Oct 2016
I see from the starting posts, the script engine 4 languages MMBasic, C, Pascal, Javascript ..
which prompts the questions - is the C (and the Pascal I guess) compiled ?
also I think Javascript and Pascal use double precision, so, what datatypes are
available ? Can other languages be added ?
sagt3k
Posted: 09:08pm 24 Oct 2016
Hi chronic
Yes the script engine has 4 language (standard basic, C, Pascal and Javascript).
The script has an interpreted engine, with a certain compatibility to original languages and a subset commands. I for example love pascal and I can guarantee high compatibility. The engine then interprets and execute the languages.
Anyway all languages have the same functions and results to ensure the same execution in term of times.
yes there are many datatypes, integer, float, string, array, extended float etc.
no.. I can't add other languages.
Thanks in advance
sagt3k
isochronic
Posted: 12:26pm 04 Nov 2016
Sounds good..I am intrigued by the scripted C, maybe an example ?
sagt3k
Posted: 11:35pm 05 Nov 2016
Hi chronic
Do you need a particular example? I can interact with micronite in uart or in tcp, create chart etc.
thanks
sagt3k
  chronic said   Sounds good..I am intrigued by the scripted C, maybe an example ?
atmega8
Posted: 04:14am 06 Nov 2016
MQTT?
MMBASIC has no IP Stack, but would it make sense with devices like those from Lantronix "serial to TCP" Bridge?
Maybe a Stupid idea...
sagt3k
Posted: 04:30am 06 Nov 2016
Hi atmega8
I use esp-link firmwaee on esp8266. You can connect tcp-uart in wifi on port 23.
sagt3k
     Page 5 of 5
