Local Time 01:34 12 Nov 2026 Privacy Policy
Forum Index : Windmills : f n p gridtie windturbine
     Page 5 of 5
flc1
Posted: 03:05pm 05 Apr 2017
Cyclone debbie has been with us for the last 2 days,untill this morning.
So the windturbine has been pretty busy for that time.
Last night we heard the turbine start to make a squeaking sound, the key had broken on the blade hub ,so the hub was starting to spin on the shaft,
turned the inverter off so the dumpload would kick in in the hope of stopping turbine, but it made no diffrence,the wind was just too strong, so we just went to bed, ha!
Got up this morning to check the damage, and the hub had worn about 10mm off the shaft , hub n blades were just flopping around on shaft ,hitting turbine housing.
Good thing we have started a new build already.We got 4 years use from it before this
so cant complain too much ,
there was a spline on that shaft.Edited by flc1 2017-04-07
DaveP68
Posted: 08:00pm 05 Apr 2017
Hey Fred
That's a bummer, so new build will be happening sooner. Will need to get the capacitor doubler built up for you and in the post...
Dave
flc1
Posted: 08:49pm 05 Apr 2017
yep,that would be good ,thanks
DaveP68
Posted: 09:24pm 14 Jun 2017
Hey Fred
Any update on the new wind turbine build?
David
flc1
Posted: 10:53pm 14 Jun 2017
yea, nearly finnished, hopfully I don't have to build or rebuild another for years,
had enough of spending time in the shed doing that, can think of plenty of other things i could be doing with my time.
     Page 5 of 5
