Local Time 03:19 12 Nov 2026 Privacy Policy
Forum Index : Windmills : New 500W+ Chinese Windmill
     Page 5 of 5
domwild
Posted: 01:30pm 18 Dec 2012
Well done, Phill. Keep up the good work.
Winston Churchill
Posted: 03:34pm 18 Dec 2012
tomqu7
Are you deaf?
STOP shouting at us
use lower case text please.
I hope you dont intend to feed 3 or 4 windmills direct to 1 inverter, it wont work!
As for turbine voltage, there is no fixed voltage and the voltage will vary up or down depending on the speed the turbine spins at, and each turbine will spin at different speeds depending on the wind passing them.
It seems you woke up with a bright idea one day, and did not do your reasearch before starting this.
Where did you get the turbines from?
From what information you have given i would think you have been mislead in the turbine capacity, and your mills are no more than 1Kw or even perhaps only 500 watt mills
This is not something that OEM done wrong, but what has been happening with a seller upgrading the capacity ratings of the mills to suck in people like yourself.
If you look at your packing boxes you might well see where to original packing stickers have been removed and taped over.
All OEM mills have a sticker on the packing box stating the rated capacity of that mill.
Pete.
tomqu7
Posted: 06:51pm 18 Dec 2012
on the rotor on the side is stamped in metal 2 kw
the instructions are in german and english
there are no specifics
I nweed some to get a grid tie inverter
plan if u google oem windpower u find a guy in the snow on u tube
in usa they are supplied with an inverter in the box
he has specifics of the inverter on his site
perhaps I could convert to australian
re phil m said the turbine could spin out and burn out
in the box i got a resistor
i bought 3 one of them had a kill switch
not much use as I am 90 km from paddock
would have to dash if storm forecast and turnoff kill switch ?
tomqu7
Posted: 07:02pm 18 Dec 2012
I went on to whispering winds china who make the turbines
they have a 2 kw on their website but max 2.2 kw
i contacted cindy who said I had an old model and they do not have any specifications
On their website they say they have australian engineers and show them visiting their factory
how to find the australian or their american engineers
I have to buy a sma grid connect inverter and not sure
sma wants to know voltage of turbine
???? would this work
so I have 3 x 2 kw turbine max 3 kw - this is in instructions
so i buy a 12 kv sma grid tie inverter
get it wired up and adjust /programme inverter when mill running
if I can find some with the skill to programme inverter on the spot
need to find those visiting engineers
I asked cindy did they have an australian contact and she said they didn't
Posted: 09:32pm 18 Dec 2012
First a little history lesson.
Both Phill and myself have worked for OEM in the past as consultants or as you put it engineers, we are no longer on their payroll so are not passed on as contacts by Cindy.
OEM have produced many different versions of rated turbines over the years, each model is superseded by the next version.
A lot of older stock was sold to a supplier here in Australia, who took it upon themselves to relabel the turbines to twice the rated capacity for marketing reasons, this has nothing to do with OEM.
From what i can workout that you may have is a 1kw mill, which was originally badged as 2kw, after much testing OEM derated that design to 1kw, yes it can produce 2kw but only in a cyclone, hence why it was derated to 1 kw.
OEM has always tried to do direct grid tie connections with their mills to varying degrees of success, my advice to them was the mills are not suitable for direct grid tied connections, the inverter in the video you refereed to is a Chinese made inverter that DO NOT comply with regulations for 90% of countries, this one included.
As far as i am aware Australian regulations will not except a OEM mill direct grid tied connected, the mill has simply never be tested to comply with our regulations, although people have done it, but it is not approved or actually legal.
The work around the problem is to put the mill power into a battery bank and use a approved GTI from the battery to feed to the grid, this system is legal in most states including Victoria.
The problem with using a windy boy is it has anti island built in, this causes a delay (by law) preventing instant connection to the grid, what happens is the mill will run away during this delay period and can burnout or self destruct.
Then every time the wind drops and the mill stops producing enough power to keep it connected to the grid it will disconnect from the grid and need to go through the delay period again when the power level is high enough to allow connection.
This is why almost everyone uses a battery bank to solve this problem, as the mill will ALWAYS remain connected to the battery keeping a load on the mill.
I think you have a lot to learn and understand, and have some half baked idea that you can do what is just not practical without much redesign of the system and the way it operates.
By all means go ahead and prove me wrong, but when you start to pick the pieces of mill up from scattered across the paddocks, just remember i warned you so.
Pete.
tomqu7
Posted: 10:53pm 18 Dec 2012
THEN MY TURBINE IS FRAUDENTLY METAL STAMPED AS 2 KW AND ADVERTISED AT WWW.SOLARENERGYSTORE.COM.AU AS 2 KW
AND i AM DEFRAUDED
tomqu7
Posted: 10:56pm 18 Dec 2012
Governing System - This unit is an integration of automatic braking system, controller and logger.
It will automatically monitor the rotor speed and keep it at or below 250 RPM. When the wind is very strong, the Dynamic Braking will be activated. The power from the generator is diverted to the Dump Load, which slows the rotor until it is slightly below 250 RPM. This allows you to get the most watts possible from the available wind.
I HAVE ONE OF THESE UNITS IN BOX
tomqu7
Posted: 10:59pm 18 Dec 2012
The Data Recorder is another powerful unique function that comes with Whispering-Winds governing system that allows you to record the windmills performance to a computer 24 hours a day.
The data can be viewed in excel format, as well as plotted to a power curve graph in respect to wind speed.
The recorder will allow for 5 parameters to be recorded: battery voltage, amps generated, windmill RPM, output wattage and wind speed (with the use of an optional anemometer not supplied).
DO i GET THIS GOVERNING SYSTEM DATA LOGGER IN MY THING
tomqu7
Posted: 11:01pm 18 Dec 2012
DUMP LOAD – These are heavy duty dump loads which
contain wire-wound resistors (2kw - 2 ohms, 4kw - 1 ohms)
which have been especially designed as dump loads for
wind generator use.
The one millimeter steel case is yellow powder-coated for
many years of heavy use.
The wiring terminals have an extra cover to protect the
terminals and to assure safe operation and use.
i ALSO GOT ONE OF THESE TIN BOXES IN THE BOX
LABELLED RESISTOR
fillm
Posted: 11:02pm 18 Dec 2012
To add a bit more to this tale , in which I have told you Tom via private emails and you do not seem to get the gist of what I have already said which is pretty well exactly what Pete has told you.
If you keep on the path you are wanting to go on the only happy person will be the person you buy the inverters from.
What I can make of the mills you have been sold is they maybe the larger downwind 2kW mills that were produced for a period and dumped here in Aus , Good luck with those when the wind starts howling and I hope you don't live in a high fire zone area.
tomqu7
Posted: 11:05pm 18 Dec 2012
SO THE ABOVE SYSTEMS THE RESISTOR AND GOVERNING BIT DO NOT DO IT
AND i NEED A BATTERY BANK TO CAPTURE THE ELECTRICITY AND THEM FEED IT INTO THE GRID
OTHER EXPENSIVE TURBINES DO NOT DO THIS
IS THIS JUST BECAUSE WE HAVE ONE THAT IS NOT DESIGNED.....?????
tomqu7
Posted: 11:14pm 18 Dec 2012
a approved GTI WHAT IS THIS
SO IF i INSTALL 3 OR 4 SUPPOSED WIND TURBINES
i WOULD NEED A THUMPING BIG BATTERY PLS ADVISE
i WOULDNEED A SHED TO HOUSE IT
THE MAN ON U TUBE IN THE SNOW HAS THE SAME TYPE AS ME WITH OEM WINDPOWER ON THE TAILS
AND HE CONNECTS TO BATTERY i THINK
THE EXPENSIVE TURBINES COSTING 6 FIGURE SUMS DO THEY GO GRID OR BATTERY
SO THEY GO GRID BECAUSE OF BETTER DESIGN FEATURES
SO i CONNECT TURBINES TO BATTERY WHAT DO i NEED IN BATTERYS
tomqu7
Posted: 11:19pm 18 Dec 2012
THE CHINESE INVERTER ON OEM USA SITES
RE THIS TYPE OF INVERTER IS THERE NONE LEGAL IN AUSTRALIA
ANY WAY SMA IS THE ONLY ONE THAT HAS 12 KW INVERTERS
THANKS FOR YOUR ADVICE ABOUT FUNCTION OF SMA INVERTER
IN PADDOCK NO ONE THERE
DO NOT WANT FIRE OR i WOULD BE HELD RESPONSIBLE
tomqu7
Posted: 11:23pm 18 Dec 2012
THE PHOTOS OF THE TURBINES ON WWW.SOLARENERGYSTORE.COM.AU ARE NOTHING LIKE THE ONES I RECEIVED IN THE BOX
AND i DID NOT GET THE TOWER AS STATED
Posted: 11:36pm 18 Dec 2012
You are shouting at us again, take caps lock off and use lower case text
If you continue to use upper case text i simply will not reply!!!!! ITS RUDE!!!!
It may be the same company that imported the mills, i dont know as they change the name every 6 months or so, you are not the first here that have purchased a mill and perhaps not got was advertized, and all past people have taken action against the seller and got no where, they change their name and move on.
As for the controller you refere to, a part of my involvement with OEM, i designed the circuitry for their latest controller.
In many ways what it was designed to do, is often different then others market it to do.
Yes it will allow for data logging, electronic braking via rpm or over voltage, but was not designed to control battery charging or grid tied control.
Now after your last little dummy spit, i advise you to calm down and we look to find a workable solution, simple enough for you to understand, because what you indicate from attitude im wasting my time even replying to you.
Secondly you are HI JACKING another thread for your cause, so i advise you to start your own thread that we can continue a discussion with your problem.
Pete.
fillm
Posted: 11:39pm 18 Dec 2012
Tom ,
I think you should start a thread separate to this as what you are talking about is completly different to the 500w mill .
Also you need to learn how to post , when the reply box is full you just keep typing and it will scroll down so you do not have to hit "post reply" when the box is full. This will stop all the individual replys also "CAPS LOCK ON" means you are shouting at us .
Some pictures would be handy .Edited by fillm 2012-12-20
tomqu7
Posted: 01:23am 19 Dec 2012
caps off
so I have these 3 oem mills 2 kw max 3 kw cindy at whispering windsin china said old model
I am so grateful for your advice and knowledge as I can get no help from anyone
so I need to get a batterry and connect the 3 x 2 kw mills to battery
then connect batterry to grid tie inverter
each turbine has max output of 3 kw so for three turbines need 9 kw grid tie inverter
will buy 12kw for expansion
the instructions in the box show how to erect tower as in the utube video
I have rung usa and emailed no response
i need to get accreditated wind mill installer only 1/2 dozen in victoria
to get the stc certificates the default value is 2000 hrs there is a calculator at whispering winds site taken from a uk site to see how many kw u produce
rec registry said the 2000 hrs is generous
they said to let the turbiine run for 12 mths then calculate watts so u get i stc certificate for 1 kw
I plan to install turbine at cora lynn victoria where winds off westernport bay
so this is way I could not get any one to help in victoria because oem are not mainstream
so I need to buy a battery bank so I need a shed to put them in
got to find out what cable to buy and distance to put turbines
I cannot find any person with knowledge to share with me in victoria
re grid tie inverter would a macsolar work if I can get a 12 kv or a power one
any advice on battery set up for these mills
Posted: 01:38am 19 Dec 2012
Ok you have taken the first bit of advice and not using uppercase text...good.
Now take the second bit of advice and start your own thread under windmills and then we will discuss this further.
Pete.
tomqu7
Posted: 01:40am 19 Dec 2012
the unit i have is exactly the same as the the american on u tube
i will get photo when I see it next
need to get design
thank u for your help as I can find no expertise in victoria who are prepared to help me
Posted: 01:44am 19 Dec 2012
Hi Tom,
I dont think you will find the answers you need on this forum. You need to have a face to face conversation with someone who is an electrician with some experience in off grid installations. Trying to find the answers on a forum is like learning to drive a car by taking instructions over the phone, its just not going to happen. What you hope to achieve with your wind turbines is no easy task, and will require some expertise.
Be careful about saying things like "I was defrauded by company X", as by saying such things on a public forum, you can be sued for defamation, even if your case is strong. Posting a message on a internet forum gives you no anonymity.
I know its all ready been mentioned, but capital letters is regarded as shouting, and will quickly distance yourself from readers. Also all capitals is harder to read.
As mentioned, this post was originally about another windmill model and not relevant to your model, so I'll close this thread now. You can start a new topic if you like.
     Page 5 of 5
