Local Time 17:39 22 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V7.00.00b8 and release candidates
     Page 5 of 5
Posted: 07:41am 20 Oct 2026
Hi Peter,
Working on it. It is NOT the reading of the FIFO itself (I eliminated that now).
Breaking down the frequency counter PIO program to nail the issue.
Posted: 08:05am 20 Oct 2026
Peter,
I am getting nuts. Now it works on rc2. Sorry for the confusion.
Edited 2026-10-20 18:14 by Volhout
Posted: 08:15am 20 Oct 2026
That's the sort of bug I like
Have you tried the code with symbols on and off and with compilation on? If there is a difference there it would be good to know
Edited 2026-10-20 18:16 by matherp
Posted: 09:04am 20 Oct 2026
Hi Peter,
SYMBOLS ON is default.
OPTION SYMBOLS OFF work as well
OPTION COMPILE ON is not supported in 2040 (not command line, not in program).
Edited 2026-10-20 19:05 by Volhout
Posted: 10:03am 20 Oct 2026
V7.00.00RC3 is now available at https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V7.00.00RC3
RC3 is RC2 with the reports of the
last few days answered, all listed under Fixed since RC2.
A program too big for the program memory, loaded without ,C, no longer leaves the board stopping at every prompt with "Program damaged: symbol table", and a board that RC2 left in that state recovers when RC3 is installed.
A WebMite or a PicoMiteRP2350 with neither PSRAM nor a display can LOAD from the SD card again.
On the PicoCalc's PicoMiteRP2350, PIXEL() and BLIT READ return the right colours.
A DO loop in a recursive SUB or FUNCTION, ON ERROR SKIP
around a FUNCTION call, and the ON ERROR setting a program leaves behind
at the prompt all behave.
PRINT counts a comma's tab as a terminal does and
keeps a file's column apart from the console's.
On the USB host builds the Nintendo Switch Pro Controller is supported, DEVICE(MOUSE n, B) reports every button, a DualShock 4's diagonals are right, an unplugged gamepad
reads 0, and GAMEPAD MONITOR OFF ends the monitoring.
The PicoMitePC3's WEB SCAN finds and measures networks as a WebMite does, Bluetooth or not.
EDIT no longer shows an empty line after a file's last line, keeps a
paste and keys typed during a redraw, lets Esc discard changes with a line
over 255 characters, and keeps its line count after Beautify.
On the Bluetooth builds GUI CURSOR LINK MOUSE takes a Bluetooth mouse or a
Bluetooth keyboard's trackpad.
The Print Screen key saves the display as a BMP, at the prompt, in the editor and in the file manager.
A save, import or export that the editor cannot make no longer loses the edits, and its search brings a match past the right edge into view.
MATH FFT is about 20% faster.
The PicoMiteRP2040MIN leaves out MATH SENSORFUSION, to make room.
The supplementary manuals' tables are mended.
Edited 2026-10-20 20:04 by matherp
terekgabor
Posted: 10:25am 20 Oct 2026
Hello Peter!
congrats again! I will update to RC3.
Have you checked TLS client error -14 I have reported earlier in a post?
G@bor
Posted: 10:57am 20 Oct 2026
Tested and works perfectly for me. possible cause of -14 are:
the port, a stale DNS answer, the server being down at the time, or a firewall or ISP.
terekgabor
Posted: 10:58am 20 Oct 2026
Okay! I will test again.
Thanks Peter
flip
Posted: 11:02am 20 Oct 2026
Thanks Peter,
Just woke up that you'd fixed keyboard character echo bug on USB ports back in RC1
RC3 is working great with slave Picos off my PC2.
All tests are good
Regards Phil
Peter63
Posted: 12:58pm 20 Oct 2026
Hello
Tested - WebMite MMBasic RP2350A Edition V7.00.00RC3
feedback from me, SDCARD is working now. I'm as happy as a penguin in a microwave
/Peter63
Posted: 06:58pm 20 Oct 2026
@Peter,
2040VGA PS2 keyboard does not save screenshot with PRINTSCREEN button.
Not with <left shift>,<right shift>, not with <right control>,<left control>, without other keys, not with <ALT>, not at all.
Tested 2 different keyboards (small LAPTOP SIZE, and large FULL SIZE).
Edited 2026-10-21 04:59 by Volhout
homa
Posted: 08:09pm 20 Oct 2026
  matherp said  V7.00.00RC3 is now available
Where should the images be saved? I can’t take any screenshots on the PC3 either.
Matthias
homa
Posted: 08:17pm 20 Oct 2026
Just as an observation, the results I get with WEB SCAN on the PC3 are completely different! Sometimes it only shows my network, then up to seven, but not all of them from the local area, and then only three are listed.
It’s really random!
Matthias
Posted: 09:42pm 20 Oct 2026
I'll add print screen for ps2 keyboards.
Matthias. It only works from a directly connected USB keyboard.
They go in the root of a drive:
B:/ (the SD card) if an SD card is configured with OPTION SDCARD;
A:/ otherwise.
The name is SCREENnnn.BMP with the first unused number, starting at SCREEN000.BMP and going up to SCREEN999.BMP (misc/FileIO.c:8579). Each press writes the whole screen with SAVE IMAGE.
Print Screen deliberately prints nothing, so these cases fail silently:
An SD card is configured but missing or unreadable. The image is not written to A: instead.
All 1,000 names are taken.
No display is configured.
ville56
Posted: 06:31am 21 Oct 2026
... the results I get with WEB SCAN on the PC3 are completely different! Sometimes it only shows my network, then up to seven, but not all of them from the local area, and then only three are listed.
It’s really random!
Matthias
IMHO it was getting better with RC3 though. Now the RSSI values are more consistent, no zero values anymore, and the number of networks reported, at least here, has gone up a bit. I think it's now comparable to what WebMite reports even though it may not be identical. I consider it as usable now.
73 de OE1HGA, Gerald
Posted: 06:46am 21 Oct 2026
@Peter,
I tested V7.00.00rc3 on Pico VGA PS2, and see no problems. Covered the major games, and applications. rc3 performs beautiful. The speed gain versus the V6 is improving game experience. Especially games like "Rocks" (full of multi-coordinate line draws) are much more joy to play.
About PRINT SCREEN. This is a very handy tool to have. I have very often strategically edited a program to include this function (to document, or to analyze). Therefor I ask if it is possible in any way to add this feature through console. Maybe not the print screen button (if it is not transferred through the VT100 set) but then through <ctrl>-G (the BELL character) or any alternative. In some cases it would still require program adaptation (what is the active frambuffer at time of activation)
Thank you in advance,
Frank N. Furter
Posted: 07:12am 21 Oct 2026
  matherp said  "Bluetooth error 0x05" means authentication failure: the device and the board couldn't prove to each other that they're paired.
The number is the standard Bluetooth status code (ERROR_CODE_AUTHENTICATION_FAILURE in btstack). The connection itself got through, but the security step that follows it failed. It isn't a range problem: that would be 0x04, page timeout.
There are three usual causes:
The two sides disagree about the pairing. One side still holds the old stored key and the other doesn't. This happens when:
the device was reset or paired with something else and forgot the board;
the board lost its pairings while the device kept its key. Any upgrade that resets the options does this, such as the PicoMiteRP2350BTH coming from RC1.
Wrong PIN for a device that pairs the older way. Without a PIN the board answers 0000, and a device expecting 1234 rejects it.
The device isn't in pairing mode, so it refuses a fresh pairing.
Check the speaker manual and try adding the correct pin to the connect command. See the manual for syntax
Thanks Peter!
bluetooth connect "BT-WE" "1234" worked with the speaker.
Frank
Posted: 08:14am 21 Oct 2026
If not used elsewhere, maybe CTRL-P for print.
flip
Posted: 03:51am 22 Oct 2026
Hi Peter,
This is a repeatable problem on my PC2 running MM.VER=7.000053
C: is a 32G USB flash
c:
chdir DOS_MMBasic
chdir PicoMite-V7_RC3
copy "help.txt" to "A:/"
(which took about 5-10 secs - timed later - actually 14 secs)
> a:
> files 'showed help.txt being around 173k
        'next try it was 218112 bytes [file should be 598559 bytes]
> C:
> files
screen cleared then up came the beginning of attempt to perform 'files'..
C:/DOS_MMBasic/PicoMite-V7_RC3
E
[USB DATA_SEQ 2 @481]
rror : A hard error occurred in the low-level disk I/O layer
A delay about 10 secs between the first line and the subsequent lines in the above code snippet
Summary:
'files' command crashes. (SEQ number increments on each subsequent failure)
There seem to be no lasting corruption on A: and C: which is comforting.
But the file only partially copies to A: drive
Regards Phil
PS actually it randomly generates above error when typing 'files' when on C: drive. Only once it generated a partial list of about 7 files (but showed no errors and got the > prompt) , subsequently correctly listed all files(1 directory, 24 files).
Copying help.txt from C: to B: also generated error
[USB DATA_SEQ 209 @481]
BUT 'files' correctly shows B:help.txt as being 598559 bytes
Regards Phil
PPS:
But LIST that same help.txt on the B: drive only goes as far as the "FRAME" command..so it looks to have been incompletely copied.
I'll try and shut up now :)
PPPS: other than to include my OPTION LIST (almost same as previous)
> option list
PicoMiteHDMI MMBasic USB RP2350B Edition V7.00.00RC3
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US, 0, 1, 300, 50
OPTION PICO OFF
OPTION RESOLUTION 1024x600 @ 252000KHz
OPTION DISPLAY 50, 128
OPTION HDMI PINS  1, 3, 5, 7
OPTION SDCARD GP29, GP30, GP31, GP32
OPTION KEYBOARD REPEAT 300,50
OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11
OPTION RTC AUTO ENABLE
OPTION COUNT GP0,GP1,GP2,GP3
OPTION PLATFORM HDMIUSBI2S
OPTION PSRAM PIN GP47
OPTION HEARTBEAT PIN GP25
Regards Phil
Edited 2026-10-22 14:44 by flip
     Page 5 of 5
