Local Time 06:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Draft PicoMite 6.00.01 User Manual
     Page 5 of 13
aFox
Posted: 10:08pm 04 Dec 2024
Page 66
behind
An alternative and simple graphical Windows TFTP client is: http://www.3iii.dk/linux/dd-wrt/tftp2.exe
On Android you can take the "TFTP CS" app.
Gregor
Posted: 11:29pm 04 Dec 2024
Page 88, Option keyboard.
Pins can be changed and disabling command has changed.
> OPTION KEYBOARD NO_KEYBOARD
Error : Syntax
> OPTION KEYBOARD DISABLE
> OPTION KEYBOARD us,gp2,gp3
Posted: 08:25am 05 Dec 2024
  Quote  Page 88, Option keyboard.
Not quite correct. Geoff: please don't change anything for the moment
homa
Posted: 09:49pm 05 Dec 2024
  Geoffg said
  homa said  Hi Geoff,
Can you send me the picture from page 16 - HDMI/USB Reference Design (Raspberry Pi Pico 2) in high resolution? Then I will make a picture without background for the final manual.
Matthias
Here it is: 003.zip
sorry for the delay, the working day was long ...
003b2.zip
and the PNG too big
Matthias
Posted: 08:11am 06 Dec 2024
Thanks Matthias, that's great.
What software do you use"
javavi
Posted: 09:52am 06 Dec 2024
  homa said  and the PNG too big
and for some reason they are turned at an angle, I almost broke my neck looking at it
Edited 2024-12-06 19:54 by javavi
homa
Posted: 08:59pm 06 Dec 2024
Hello Geoff,
You're welcome. I did the clipping/cropping(?) with the software from https://affinity.serif.com/en-gb/photo/ .
@javavi: Not everything always has to be straight. This is an emotional picture and is intended to lighten up the manual. I would also choose a different perspective for a technical image.
Matthias
aFox
Posted: 09:13pm 06 Dec 2024
Page 92
OPTION TFTP ON/OFF is missing.
Page 66
File Transfer
I think we should recommend TFTP OFF OPTION to avoid security issues after the development process is completed.
Gregor
aFox
Posted: 09:33pm 06 Dec 2024
Page 145
WEB |WEBMITE ONLY
   |The WEB commands are used to manage the Internet capability of the
WebMite.
Should be on page 146.
Gregor
stanleyella
Posted: 10:19pm 06 Dec 2024
To get data from the mouse use the DEVICE(MOUSE ...) function as per a USB mouse
DEVICE(MOUSE channel,X) ' returns the x position of the mouse (0-MM.HRES-1)
DEVICE(MOUSE channel,Y) ' returns the y position of the mouse (0-MM.VRES-1)
DEVICE(MOUSE channel,L) ' returns the state of the left mouse button
DEVICE(MOUSE channel,R) ' returns the state of the right mouse button
DEVICE(MOUSE channel,M) ' returns the state of the middle mouse button
DEVICE(MOUSE channel,W) ' returns the number of clicks the wheel has turned. This is zeroed after it is read. The return can be positive of negative
In all cases channel is included for compatibility with USB mouse functionality and must be set to 2
DEVICE(MOUSE channel,D) ' should return whether the left mouse button has been double clicked. This isn't currently working but will be for the release.
I tried mouse x,y and ok. anyone done a demo of the mouse cursor not erasing background? hdmi usb. I'll have a go but don't want to reinvent the wheel.
blit cursor area? the mouse is underestimated imho. could be used for clicking labels or games.
Gerad
Posted: 12:26pm 07 Dec 2024
Hi Geoff
there is a little error on Page 174
SETPIN GP6, GP5, I2C2 ' assign the I/O pins for I2C2
instead of
SETPIN GP6, GP7, I2C2 ' assign the I/O pins for I2C2
regards
Gerad
Posted: 12:42pm 07 Dec 2024
  Gerad said  GP5
Thanks, that was a subtle one,
Posted: 07:55pm 08 Dec 2024
Page 137: SETPIN GP25 - WEBNITE VERSION
Malibu
Posted: 08:05pm 08 Dec 2024
Just playing with a UDP server and found that
"OPTION UDP SERVER PORT nn"
is not included in the Options table
Posted: 09:52am 10 Dec 2024
Things seem to have quieten down, so this is the current manual.  It is still a draft but is close to the final.
   PicoMite_User_Manual.pdf
It has many changes since the last draft:
- The first few chapters have been rewritten to make it easier for a newbie to follow.
- The chapters have been rearranged to bring similar subjects together.
- Most suggestions have been incorporated (thanks guys).
- Many, many minor tweaks.
Hopefully this does not have many errors/typos/etc but if you spot one, please let me know.
Posted: 10:46am 10 Dec 2024
Geoff:
Trivia
Section "Using a mouse"
or the details of connecting a mouse see the heading
Keyboard/Mouse/Gamepad later in this manual.
Section "USB Gamepad"
One or more PS3 or PS4 controllers or gamepads such as a Super Nintendo SNES Controller with
a USB interface can be connected via USB (illustrated on the right).
Section "Load and Save Image"
LOAD PNG filename$ [, StartX, StartY] (Pico2/RP2350 only)
Section "Pulse Width Modulation" add
The RP2350 supports up to 12 PWM channels numbered 0 to 11) and up to 24 pins can be configured as PWM outputs using the SETPIN command.
Section "Interrupts"
15. USB Game Controller/USB or PS2 Mouse/Wii controller
Section "Touch Functions" add between TOUCH(Y) and TOUCH(DOWN)
Additional functions with Advanced GUI controls enabled:
Section "Fonts" in Font 3
16 x 24 (16 x 16 for VGA versions)
Section "Screen Coordinates"
MM.HRES and MM.VRES NOT MM.INFO(HRES) and MM.INFO(VRES)
Section "Advanced Graphics"
ONLY AVAILABLE in PicoMite embedded and WebMite RP2350 versions
Posted: 10:55am 10 Dec 2024
Geoff,
Page 6: RP2030 -> RP2040
Please also check if this (page 7) applies to the USB versions (using CH340):
Page 13: RRP2350B -> RP2350B
Edited 2024-12-10 21:09 by Volhout
Posted: 11:11am 10 Dec 2024
  Quote  Please also check if this (page 7) applies to the USB versions (using CH340):
It doesn't of course. Default baudrate for USB versions is 115200
Posted: 11:14am 10 Dec 2024
Geoff,
Since the baudrate is ignored by non-USB and USB requires 115200, then simply change this section to USE BAUDRATE 115200, and avoid mentioning the 1200 here.
Posted: 11:18am 10 Dec 2024
Thanks Peter.
  matherp said  MM.HRES and MM.VRES NOT MM.INFO(HRES) and MM.INFO(VRES)
I thought that MM.INFO(HRES) and MM.INFO(VRES) have replaced MM.HRES and MM.VRES ?
     Page 5 of 13
