Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 G2 V2 design files
     Page 5 of 5
ManiB
Posted: 07:11am 12 Jan 2026
  phil99 said  I feel like I am reading the script for a Python sketch.
Clearly the hole is too small for a standard plug, so make the hole big enough for the plastic molding of a standard plug!
Yes, you're right, I'll put the back panel at the front and make a larger opening in my next production run.
But anyone who can edit STL files can do that themselves ;)
CMM2G2V2_STL_Panels.zip
Here are the Gerber files for my panels (where the USB-C openings are still too small).
Gerber files for the front panel:
FRONT_CMM2G2V2ends_250526.zip
Gerber files for the back panel
BACK_CMM2G2V2ends_250526.zip
I have documented the links in my blog post , where I also describe how to have the circuit boards manufactured by JLCPCB.
That would be my suggestion for a new, suitable opening:
Edited 2026-01-12 19:00 by ManiB
     Page 5 of 5
