Local Time 14:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/WebMite/PicoMiteVGA - please post any know manual issues here
     Page 5 of 5
Posted: 08:50pm 26 Jan 2024
Ah, thanks.
apalert
Posted: 11:26pm 27 Jan 2024
Typo and suggestion re SSD1306I2C OLED
In the V5.08.00 manual, page 7, section on getting started with Apple Macintosh it says to first start the application and type in:
ls /dev/tty.*.
The last period in that line is extraneous and causes the command to fail :)
Also, attempting to setup a SSD1306I2C OLED, I found the command
OPTION LCD PANEL SSD1306i2c, L,2
on Page 47 but a lot of frustration until I eventually found that first I had to setup I2C with
OPTION SYSTEM I2C sdapin, sclpin
which I haphazardly stumbled across on page 84.
Some mention on page 47 of needing to set up I2C first, cross referenced to page 84 would seem useful!
It works great now and it a nortorious 1.3" version.
Posted: 02:44am 28 Jan 2024
Thanks Malcolm.
JanVolk
Posted: 11:14pm 28 Jan 2024
These two can no longer be found in the manual.
Could it be that the first one was previously deprecated after v5.07.07 but can't find out where?
The second option was added in v5.07.08RC11.
OPTION FAST AUDIO ON/OFF
Overhead of changing the volume or sound type for PLAY SOUND can now be removed using OPTION FAST AUDIO ON/OFF in a program.
Defaults to OFF. Audio cutoff frequency now reduced to a maximum of 44100 or WAV/FLAC frequency, regardless of CPU speed.
OPTION LCD PANEL 8bit display code, orientation [, backlight pin] [, DCpin]
Parameter for OPTION LCDPANEL for 8-bit parallel displays.
If DC pin is omitted, pin assignment is as per manual.
If DC pin is specified, DC, WR, RD and RESET pins are assigned sequentially from DC pin.
Posted: 08:23am 30 Jan 2024
I might be an idea to add a comment to the multi-line comments entry that these cannot be used inside subroutines and functions. It doesn't half cause problems if you do!
Posted: 01:59am 29 Feb 2024
We seem to have run out of manual additions/errors (for the time being anyway).  So I have updated all the manuals accordingly and copied them up to my website.
If you are re downloading them it might be worth clearing your browser's cache first.
Thanks for everyone's input.
Edited 2024-02-29 12:00 by Geoffg
     Page 5 of 5
