Forum Index : Microcontroller and PC projects : WebMite in Silicon Chip Magazine
Hi I've just started playing with this on a bare bones 2040 W today. On setting the watering days, the prescribed timer does not appear to be get set for the current day [Mo] unless [Sa] is selected as well, in fact selecting just [Sa] will set the timer for the set time for today & run at that time. (Set time > than current time). In all other cases, the auto refresh timer gets set to midnight. Selecting [1] for every day works OK. Am I missing something? Just wondering. (Config below only works if [Sa] is selected as well and set time > current time. ![]() Brian ChopperP |
Hi Brian, I may be wrong (yet again) but the system knows that today is Saturday so it won't run today's schedule on Monday. Is that it? (if so we can have a good laugh together) Andrew |
OK.......for some unknown reason, I thought it was Monday. Not feeling too good today. Should be out elsewhere instead of being at home so got confused. Need to triple check stuff before I post Laughs on me. Thanks Andrew. Brian ChopperP |
No mate- I've been retired for 10+ years and I have no idea what day it is. All day today I have been thinking it is Sunday - that is how I thought to check. Being in Melbourne, and a public holiday on Tuesday (for some horse race), it has been important to get the supplies in. Cheers, Andrew |
OK, after yesterday's embarrassment of forgetting what day of the week it was (today is Sunday), I'm happy to report that the bare bones "W" works as advertised for the basic stuff on the Watering System Controller prog. With the weather forecast of 96% rain & it is actually raining (first good wet stuff for a while), that tick box worked as well. I haven't tried the email yet. There is certainly a great deal of stuff in the Water System Controller prog etc to keep us less experienced Shedders busy sorting it all out for a good while. Been fun (mostly) playing around with the program so far. Telnetting into the "W" is great as well. @Andrew, good luck with the horses on Tues. (Public holidays for the Cup & the AFL GF: what a life in Vic )Brian ChopperP |
| barewires Newbie Joined: 13/04/2015 Location: United KingdomPosts: 40 |
Try this code: [code] '1st light 10092023 F407#2 'by chatGPT with fixes by RS 13/11/2023 Print MM.Ver,MM.Device$,Date$,Time$ Print "ZELLER'S CONGRUENCE PERPETUAL DAY CALCULATOR" Print "I work at the 7-11 from 9-5" Print "Reverse 11-7 and 5-9" Print "Remember these dates: Last day of Feb, Pi Day 14-3, 4-4, 6-6, 8-8," Print "10-10, 12-12 and July 4th as 4-7. Jan 3 common years. Jan 4 leap years" Print "These dates were all Tuesday in 2023. Add a day for next year but add 2" Print "when coming into a leap year." Data 3,1,28,2,14,3,4,4,9,5,6,6,4,7,11,7,8,8,5,9,10,10,7,11,12,12,0,0,0,0 n = 13 Do While n > 0 Read D,M ' Print n,D,M n = n - 1 'Input "Enter date (1-31): ", D 'Input "Enter month (1-12): ", M testyear: 'Input "Enter year (e.g., 2023): ", Y Y = 2023 'Print "Year=";Y 'If Y=0 Then Print "Invalid Year": GoTo testyear Print D,M,Y, If M < 3 Then M = M + 12 Y = Y - 1 EndIf 'Print "my="; M,Y K = Y MOD 100 J = Int(Y / 100) F = Int((13 * (M + 1)) / 5) G = Int(K / 4) H = Int(J / 4) W = (D + F + K + G + H - (2 * J)) MOD 7 'Print D;M;Y,K,J,F,G,H,Z,W 'Print " D ";"M ";"Y"," K","J","F","G","H","Z","W" 'Print "The day of the week is "; Select Case W Case 0 Print "Saturday" Case 1 Print "Sunday" Case 2 Print "Monday" Case 3 Print "Tuesday" Case 4 Print "Wednesday" Case 5 Print "Thursday" Case 6 Print "Friday" End Select Loop [/code] 3 1 2023 Tuesday 28 2 2023 Tuesday 14 3 2023 Tuesday 4 4 2023 Tuesday 9 5 2023 Tuesday 6 6 2023 Tuesday 4 7 2023 Tuesday 11 7 2023 Tuesday 8 8 2023 Tuesday 5 9 2023 Tuesday 10 10 2023 Tuesday 7 11 2023 Tuesday 12 12 2023 Tuesday Edited 2023-11-16 05:34 by barewires |
Thanks for posting the "PERPETUAL DAY CALCULATOR". Note that on this forum, to preserve indentation, the tags [ CODE] and [ /CODE] must be in upper case. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| PilotPirx Senior Member Joined: 03/11/2020 Location: GermanyPosts: 172 |
My version of the "PERPETUAL DAY CALCULATOR" (german version): Print "Wochentagsermittlung" Input "Tag: ", Tag Input "Monat: ", Monat Input "Jahr: ", Jahr Rem Monatskorrekturen If Monat < 3 Then Monat = Monat + 12: Jahr = Jahr - 1 Rem Wochentagsberechnung nach Zeller's Congruence K = Jahr Mod 100 J = Int(Jahr / 100) W = (Tag + Int((Monat+1)*13/5) + K +Int(K / 4) + Int(J / 4) - 2 * J) Mod 7 Rem Ausgabe des Wochentags Print "Wochentag: "; If W = 1 Then Print "Sonntag" If W = 2 Then Print "Montag" If W = 3 Then Print "Dienstag" If W = 4 Then Print "Mittwoch" If W = 5 Then Print "Donnerstag" If W = 6 Then Print "Freitag" If W = 0 Then Print "Samstag" |
Cool. Nice and compact. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Hi Geoff FYI, I just ran MM Edit's Display Variable report on V1.3 & it came up with with 'retri.bas being the first line I don't really know if these affect anything or not. Brian ChopperP |
I cannot see any "unpaired brackets" and the code runs fine (MMBasic does not complain). So I don't have answer. Geoff Geoff Graham - http://geoffg.net |
I downloaded the program again & left the first commented row in (I had deleted it). The MM Edit report gave the list below. I've included the corresponding lines of code. ' retic.bas ' (c) Geoff Graham 2023 Const Ver = "1.3" Lines with unpaired brackets: 313 449 479 482 624 313 if Len(RainDetect) And Pin(RainDetectInput) = 0) Then 449 ElseIf LInStr(b(),"GET /setup.html HTTP") > 0) Then 479 ElseIf LInStr(b(),"GET /config") > 0) And (LInStr(b(),".html HTTP") > 0) Then 482 ElseIf LInStr(b(),"POST /config") > 0) And (LInStr(b(),".html HTTP") > 0) Then 624 If StartDay(pnbr) = "" Or StartMonth(pnbr) = "" Or EndDay(pnbr) = "" Or EndMonth(pnbr) = "") Then I'm having a number of "Senior" moments lately but I'm sure these lines do have extra ")"s in them after the "0"s etc. Brian Edit. Line numbers were one number out Edited 2023-11-26 20:57 by Chopperp ChopperP |
Thanks Brian, it was me having a senior's moment, not you. I must have looked at that code so many times and the extra brackets remained "hidden" to my eyes until you pointed it out. It just shows how valuable MMEdit is. I have not checked the MMBasic source code but my guess is that the interpreter hit the last unpaired closing bracket and thought "what the heck" and simply ignored it. I have plans to release an updated version over the next month or two and it will include a fix for these bugs. Geoff Geoff Graham - http://geoffg.net |
Ok Geoff. I'm not actually doing anything practical with it at the present time, just letting the Pico running on it's own seeing what happens & trying to learn stuff (including what day of the week it is). I did change the Auto refresh times to Minutes. Easier to interpret that a string of seconds. Yes, MM Edit is extremely valuable but we won't tell Jim that. Awaiting the next update. Brian ChopperP |
