Forum Index : Microcontroller and PC projects : PicoMiteWeb lessons
This is now well covered in the latest version of the WebMite manual - page 29 |
| LucV Regular Member Joined: 19/02/2023 Location: NetherlandsPosts: 62 |
@matherp Peter, The manual shows how to use radiobuttons. But they have predefined values. I think Volhout wants an input field in which he can put any value he wants from his keyboard. I am working on it. Luc's tech Blog |
That is what I illustrated above using Peter's THERMO code. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I think I can achieve what I want with the html input form type=NUMBER, and in other fields with input form type=TIME. In basic I can extract the value from the return string. Now I have to design the whole html page first... as a table... Volhout P.s. lizby, your example uses type=text. That will also work, but when using type=number, you can easy check for wrong entries.. Edited 2023-05-19 04:00 by Volhout PicomiteVGA PETSCII ROBOTS |
Ok guys, Anybody still interested (after the above) in me making lessons about an input field in which you can put any value you like and send it to the Pico, and a slider with which you can set a value in a pre-defined range. It's a lot of work and maybe no longer needed after lizby's and volhouts posts. Luc Luc's tech Blog |
Luc -- slider and check box examples would be good. Thanks for your work in formal documentation. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
