Local Time 00:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA V5.07.07b19 - Major enhancement - 640x480  edit in colour
     Page 5 of 5
Posted: 09:13pm 25 Feb 2023
  matherp said   the display framebuffer is still only using 1 bit per pixel
It would seem the colours aren't part of the image so to save them may be quite difficult. Perhaps the saved B & W image could have the colours added in MMB4W with a program reading strings containing the Tile commands from the PicoVGA program.
Edit
The process could begin in the PicoMiteVGA program.
After each Tile command append the co-ordinates, pixel dimensions and FG & BG colours of that Tile set to a text file.
The MMB4W program can then use that to "colourize" each pixel of the BMP file by reading them and writing them back with the FG or BG colour.
Edited 2023-02-26 17:28 by phil99
Martin H.
Posted: 11:27am 26 Feb 2023
  Volhout said  @Peter,
I guess this tile change does not make it easier now to get a SAVE IMAGE with color ...??
Edit: tested most of my programs, all work
Only the hi-res chess program needed fixes.
BTW; Is there a way to read the Tile values from a Screenlocation?
Since the BMP file format is not that complicated, maybe a short Basic Sub can write a 24 BIT BMP File account the Pixel and TILE values
Edited 2023-02-26 21:39 by Martin H.
'no comment
Posted: 11:58am 26 Feb 2023
Specially for Volhout
PicoMiteVGA.zip
Try
CLS
TILE 0,0,0,RGB(white),80
TILE 0,1,0,RGB(yellow),80
TILE 0,2,0,RGB(lilac),80
TILE 0,3,0,RGB(brown),80
TILE 0,4,0,RGB(fuchsia),80
TILE 0,5,0,RGB(rust),80
TILE 0,6,0,RGB(magenta),80
TILE 0,7,0,RGB(red),80
TILE 0,8,0,RGB(cyan),80
TILE 0,9,0,RGB(green),80
TILE 0,10,0,RGB(cerulean),80
TILE 0,11,0,RGB(midgreen),80
TILE 0,12,0,RGB(cobalt),80
TILE 0,13,0,RGB(myrtle),80
TILE 0,14,0,RGB(blue),80
TILE 0,15,0,RGB(black),80
Text 0,0,"White on black",,,,RGB(white),RGB(black)
Text 0,12,"Yellow on blue",,,,RGB(yellow),RGB(blue)
Text 0,24,"lilac on myrtle",,,,RGB(lilac),RGB(myrtle)
Text 0,36,"brown on cobalt",,,,RGB(brown),RGB(cobalt)
Text 0,48,"fuchsia on midgreen",,,,RGB(fuchsia),RGB(midgreen)
Text 0,60,"rust on cerulean",,,,RGB(rust),RGB(cerulean)
Text 0,72,"magenta on green",,,,RGB(magenta),RGB(green)
Text 0,84,"red on cyan",,,,RGB(red),RGB(cyan)
Text 0,96,"cyan on red",,,,RGB(cyan),RGB(red)
Text 0,108,"green on magenta",,,,RGB(green),RGB(magenta)
Text 0,120,"cerulean on rust",,,,RGB(cerulean),RGB(rust)
Text 0,132,"midgreen on fuchsia",,,,RGB(midgreen),RGB(fuchsia)
Text 0,144,"cobalt on brown",,,,RGB(cobalt),RGB(brown)
Text 0,156,"myrtle on lilac",,,,RGB(myrtle),RGB(lilac)
Text 0,168,"blue on yellow",,,,RGB(blue),RGB(yellow)
Text 0,180,"black on white",,,,RGB(black),RGB(white)
Save image "B:/test"
Pause 5000
MODE 2
Load image "B:/test"
Do :Loop
Posted: 12:09pm 26 Feb 2023
Is there a way to free up enough memory after running the Logic Analyser program to save an image of it. At the moment Save Image only produces a very short corrupted file.
Posted: 01:01pm 26 Feb 2023
Are you trying to save to the flash drive? In which case the file is too big . Save to an SDcard and it should work.
Posted: 04:14pm 26 Feb 2023
Hi Philip,
The mode1 save image producers a bmp file size 900kbyte. Too large
Bowden_P
Posted: 05:06pm 26 Feb 2023
Hi Peter,
Many thanks for fixing the triangle bug. All looks good now!
With best regards, Paul.
Nothing so constant as change.
Posted: 07:01pm 26 Feb 2023
This one is better.
Not only does it now save the images in 4 bits/pixel so much smaller files
but you can also blit the colour if the blit aligns with the tiles
PicoMiteVGA.zip
MODE 1
CLS
Sprite 0,0,160,0,160,240
Save image "a:/test",0,0,320,240
Pause 5000
MODE 2
Load image "a:/test"
Do :Loop
homa
Posted: 08:18pm 26 Feb 2023
  matherp said  This one is better.
PicoMiteVGA.zip
@peter:
i don't think so. See images attached, the first image is the version for PicoMiteVGAV5.07.07b25 (specifically for vollhout) and the second image is the latest PicoMiteVGAV5.07.07b25 (version2).
Matthias
Posted: 09:37pm 26 Feb 2023
  matherp said  Are you trying to save to the flash drive? In which case the file is too big . Save to an SDcard and it should work.
It was a "Seniors Moment"
Successfully saved an image to SD card before running LA21, but after exiting LA21 with Ctrl-C it produced the small corupted file. Forgot I had switched to A: to run the program from there.
Posted: 10:11pm 26 Feb 2023
Oops - sorry. posted the wrong binary
PicoMiteVGA.zip
homa
Posted: 10:38pm 26 Feb 2023
thx   works
Edited 2023-02-27 08:39 by homa
Posted: 06:50am 27 Feb 2023
Beta 25 is excellent, thanks Peter.
When re-displaying saved images in Mode 1 on the PMVGA they can be colourised like this example for the Logic Analyzer.
' LA_21_b24.bas mode 1 "load image" colouriser
MODE 1:Colour RGB(WHITE),0:CLS :Font 1
TILE height 16
For ch% = 0 To 6
TILE 14,5+ch%*3,RGB(yellow),0,66,2
TILE 0,4+ch%*3,RGB(midgreen),0,80,1
Next
Then load your image
> Load image "LA_01.bmp"
Bleep
Posted: 01:14pm 01 Mar 2023
Hi Peter,
Like you I almost always only use USB to connect and edit using a terminal screen.
If I use options like this
PicoMiteVGA MMBasic Version 5.07.07b25
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION DISPLAY 60, 106
OPTION DEFAULT FONT 7, 1
or even
OPTION DEFAULT FONT 8, 1
to give me more lines and columns while editing using a terminal, in the terminal it works great in colour.
If I look at the VGA screen some of the top lines of code on the screen are blank, they initially appear while 'pg up' or 'pg down', but immediately disappear, there are also blanked lines further down the screen as well, but the top is the most obvious, all lines below about half screen always seem to be complete.
I realise that using Font 7 or 8 will not give me colour editing on the VGA screen.
I have tried this at all cpu speeds.
Is this something I can no longer do, because of the new colour tiling?
Any help appreciated.
Regards, Kevin.
Edited 2023-03-01 23:15 by Bleep
Posted: 02:11pm 01 Mar 2023
Should work - another bug to fix. Is it OK with OPTION COLOURCODE OFF?
Bleep
Posted: 02:35pm 01 Mar 2023
Hi Peter,
If I try,
The VGA screen is then normal, all lines visible with font 7 & 8.
Regards, Kevin.
Posted: 02:51pm 01 Mar 2023
Try this and assuming OK I'll do a proper release once I've fixed a couple of other things
PicoMiteVGA.zip
Bleep
Posted: 08:19pm 01 Mar 2023
Thanks Peter,
Editor in VGA now working great thanks, no vanishing lines :-)
Regards, Kevin.
     Page 5 of 5
