Local Time 07:21 12 Nov 2026 Privacy Policy
     Page 49 of 52
stanleyella
Posted: 03:54pm 02 Jun 2025
Mick- latest projects - 2 hdmi break out arrived  waiting for usb to ttl and micro usb
sd card reader. dunno if retro ie soldered ribbon, no molex.
let you know as may be useful... it will be like olimex  on vero but working proper
stan
I also got a spare 2350 pre soldered from the pihut as did the sd card readers and hdmi breakout, they're good. fed up of soldering 40 pins...still got to do them for socket as never soldered pico board
Edited 2025-06-03 02:36 by stanleyella
stanleyella
Posted: 05:41pm 02 Jun 2025
the sd cards are 3V so that's why I'm solder wiring it all and sd and hdmi break out underneath the pico board if it's on headers.
going for hdmi usb so usb to ttl for connect to pc. this has 5V and 333V out which will be used as power to pin 40 vbus, the swd card could be from the usb to ttl 3.3V or pico 3.3V
see when usb to ttl arrive and test olimex again cos the 2 converters I got don't work
Posted: 05:43pm 02 Jun 2025
Off topic?
stanleyella
Posted: 06:31pm 02 Jun 2025
won't argue with you just a new hardware layout hdmi usb and open for suggestions like there's a dac chip that works and any ideas to try anything else welcome.
nowt wrong with what I got so I'll blow this up for anyone... when built
stan
jkdelauney
Posted: 04:15pm 03 Jun 2025
I haven't seen this mentioned in this thread, and did a search to see if it got brought up in another thread.
Between 6.00.01 release and the 6.00.02 betas there seems to be a loss of functionality with MQTT. I say seems to be as there isn't any detail in the manual on how it is supposed to work (that I could find) so my usage has been derived from examples I've found.
When a message is posted to a broker in a subscribed topic MM.MESSAGE$ holds the message and it can be displayed or used, as in .01, but MM.TOPIC$ does not seem to contain anything. I haven't done extensive testing to see if it returns a blank or null, but usage in a PRINT line produces no visible output.
I see that a bit has changed in how these two are populated between .01 and now; and while I understand the code enough to see what it's supposed to be doing I don't understand it enough to identify why it might not be,
My environment is as follows:
MM.TOPIC$ works:
Pico 2 W running: WebMite MMBasic RP2350A Edition V6.00.01
Options:
OPTION FLASH SIZE 4194304
OPTION CPUSPEED  150000 'KHz
OPTION WIFI [network appropriate data here]
MM.TOPIC$ does not work:
Pico 2 W running: WebMite MMBasic RP2350A Edition V6.00.02RC25
Options:
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 150000
Code used to test:
' MQTT client test
WEB MQTT CLOSE
WEB MQTT CONNECT "test.mosquitto.org", 1884, "ro", "readonly", msgPrint
WEB MQTT SUBSCRIBE "#", 0
Sub msgPrint
 Print DateTime$(now)
 Print "Topic  : "; MM.TOPIC$
 Print "Message: "; MM.MESSAGE$
Loop Until Inkey$ = "q"
Sample Output from .02RC25:
Connecting to 5.196.78.28 port 1884
03-06-2025 11:40:31
Topic  :
Message: 1748965230
03-06-2025 11:40:31
Topic  :
Message: oint_temperature":{"value":0,"status_code":"{null} @ def","units":""},"unoccupied_heating_setpoint_temperature":{"
03-06-2025 11:40:31
Topic  :
Message: {"command":0,"timestamp":1744046230,"node_id":8,"node_name":"ตู้ OPD 2","pla
03-06-2025 11:40:31
Topic  :
Message: tamp":"2025-05-31T11:01:30"}
Sample Output from .01 Release:
03-06-2025 12:05:23
Topic  : //16484256345/radio/rx_succe
Message: 48122
03-06-2025 12:05:23
Topic  : /116484256345/radio/rx_success
Message: 48122
03-06-2025 12:05:23
Topic  : /Acm_Moburapa/11C
Message: {"slave":1,"temp":1,"co
03-06-2025 12:05:23
Topic  : /MCP_Moburapa/11
Between each flash of firmware I've done a clear flash to make sure nothing lingered.
MM.MESSAGE$ seems to be truncating, but I'm not sure if that's a limitation of the MQTT implementation or a buffer issue.
Edited 2025-06-04 02:18 by jkdelauney
Posted: 06:48am 04 Jun 2025
Travelling at the moment, will look at it when I get home
toml_12953
Posted: 02:34am 05 Jun 2025
CHAIN might have a problem in RC25. Here are two programs. If this is the first time prog1 is run, it sets a to 4 and chains prog2. Prog2 prints a message, sets a to 1, and chains prog1.
prog1:
if a<>1 then
  a=4
  chain "prog2"
endif
print "We're back!"
prog2
print "Here's program 2"
a=1
chain "prog1"
When I run prog1, I get
[LIBRARY] const true=-1
Error : true variable already declared
I do have TRUE declared in my library but why is CHAIN trying to rerun the library commands?
Even if I delete the library, CHAIN never prints the "Here's program 2" message.
Edited 2025-06-05 12:56 by toml_12953
Posted: 03:06am 05 Jun 2025
> save "Prog1.bas"
> list "Prog1.bas"
' prog1
Print  "Prog1.bas starting... a="a
If a<>1 Then
 a=4
 Print "a="a
 Chain "Prog2.bas"
EndIf
Print "We're back!"
> list "Prog2.bas"
Print "Here's program 2"
a=1
Chain "Prog1.bas"
> RUN
Prog1.bas starting... a= 0
a= 4
Prog1.bas starting... a= 4
a= 4
a= 4
a= 4
a= 4
a= 4
It would appear prog2 is called but does nothing except call prog1. Print and a=1 get skipped.
Edit.
No that isn't right. Prog1.bas restarts even if Prog2.bas no longer calls prog1
> list "Prog2.bas"
' prog2
Pause 500
Print "Here's program 2 a=";a
if a <> 1 then a=1
? "a is now =";a
Pause 500
'Chain "Prog1.bas"
If I run Prog2 first a similar thing happens.
Load "Prog2.bas"
> RUN
Here's program 2 a= 0
a is now = 1
Here's program 2 a= 1
a is now = 1
a is now = 1
a is now = 1
a is now = 1
a is now = 1
Edited 2025-06-05 15:05 by phil99
Footnote added 2025-06-06 08:48 by phil99
Fixed in RC26
> RUN
a= 4
Here's program 2 a= 4
a is now = 1
Prog1.bas starting... a= 1
We're back!
Posted: 09:01am 05 Jun 2025
Bug in chain - will include fix in the release
Gadgetguy
Posted: 11:49am 05 Jun 2025
  matherp said  Off topic?
Totally
Posted: 02:12pm 05 Jun 2025
V6.00.02RC26 is available on
Fixes bug in chain command
Fixes bug in mm.topic$ (untested)
Bleep
Posted: 02:13pm 05 Jun 2025
Hi Peter,
I have just converted an early HDMI Refrence design V1.2 to now drive a LCD display instead.
PicoMite MMBasic USB RP2350A Edition V6.00.02RC25
OPTION SYSTEM I2C GP20,GP21
OPTION KEYBOARD UK, 0, 0, 170, 100
OPTION CPUSPEED (KHz) 396000
OPTION LCDPANEL CONSOLE ,,,, 50,NOSCROLL
OPTION DISPLAY 26, 60
OPTION LCDPANEL ILI9488, LANDSCAPE,GP12,GP13,GP14,GP15
OPTION TOUCH GP17,GP28
OPTION SDCARD GP22
OPTION KEYBOARD REPEAT 170,100
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
The intention is that I don't currently have a 2350 LCD layout and the 9488 will be replaced by a 7796 when it arrives.
This is working great at the maximum overclock. ;-) So I've been stressing it.
If I run a program that does not use framebuffers, so is writing directly to the LCD and I play a MP3 or WAV, all is good, however if I run the exact same program, with framebuffers and a Framebuffer Copy f,n with or without option b the music slows and distorts, it sounds like, as the Framebuffer copy is happening, a 100mS loop of sound repeats for the duration of the update, at the end of the screen update the sound goes back to normal, repeat. If I put a longish pause after the copy, the music plays fine for the duration of the pause, but at the next Framebuffer copy the same distortion.
Hope you are having a good break, if it wasn't for us lot spoiling it! ;-(
Any Ideas?
Regards, Kevin.
Posted: 02:20pm 05 Jun 2025
It does this because the audio isn't being buffered during the copy. On VGA and HDMI this happens quickly enough that it doesn't matter but SPI displays are slow so it runs out of audio and repeats the last buffer to avoid crashing. I'm not inclined to change this so late in the release cycle.
Bleep
Posted: 02:47pm 05 Jun 2025
In that case shouldn't the b (background) option be fine? but it triggers the same audio distortion.
I've done a proof of concept (bodge).
' FRAMEBUFFER copy f,n,b
Blit framebuffer f,n,0,0,0,0,480,80
Blit framebuffer f,n,0,80,0,80,480,80
Blit framebuffer f,n,0,160,0,160,480,80
Blit framebuffer f,n,0,240,0,240,480,80
Which sure enough cleans it up, at the expense of being slightly slower :-(
Regards, Kevin. :-)
jkdelauney
Posted: 02:49pm 05 Jun 2025
  matherp said  V6.00.02RC26 is available on
Initial testing shows that mm.topic$ is producing the same results as in 6.00.01
Posted: 02:52pm 05 Jun 2025
  Quote  In that case shouldn't the b (background) option be fine? but it triggers the same audio distortion.
No: The second processor puts a lock on the SPI channel to stop anything else using it so the audio queues on the lock. Remember, The SDcard and screen share the same SPI
           } else if(command==1){
               uint8_t *s=(uint8_t *)multicore_fifo_pop_blocking();
               mutex_enter_blocking(&frameBufferMutex); // lock the frame buffer
               copyframetoscreen(s,0,HRes-1,0,VRes-1,0);
               mutex_exit(&frameBufferMutex);
Edited 2025-06-06 00:55 by matherp
Bleep
Posted: 03:06pm 05 Jun 2025
Oh ok, didn't realise the PWM sound would get locked by the SPI? Ah yes the SD will be locked.
Anyway, using 5 BLITS in a row, copying 64 lines each, cleans it up for both WAV and MP3 playback.
Edited 2025-06-06 01:08 by Bleep
jkdelauney
Posted: 03:14pm 05 Jun 2025
If it's not too complicated/time consuming, could you explain what you did to make it work?
Edited 2025-06-06 01:15 by jkdelauney
Posted: 03:17pm 05 Jun 2025
just a typo in the order of strings in overlaid_functions[] in functions.c compared to the enum in configuration.h
Bleep
Posted: 03:51pm 05 Jun 2025
Hi Peter,
As a feature request for the future, would it be possible to allow the
Blit framebuffer...... to have a background option?
     Page 49 of 52
