Local Time 00:21 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : help with power up on colour Maximite
     Page 4 of 4
BobD
Posted: 09:15am 09 Dec 2015
Some of the early Maximites were populated with the 32MX695F512H-801/PT and the later ones were 32MX795F512H-801/PT. I have a schematic which shows both possible.
IIRC the 695's lacked the CAN network capability.
jeffj
Posted: 06:45pm 10 Dec 2015
Thanks John
Yes chip is pic 32 mx795F512L Jeff
Posted: 05:21am 12 Dec 2015
So you're saying you entered what?
I can't currently see what you entered but so far I don't see a real error with the device.
(I also can't see quite where the 0x41000 or 0x7000 would be from as neither matches the internal PIC32 ID code.)
jeffj
Posted: 12:09am 20 Dec 2015
Thanks John
The ref on the device is pic 32MX795F512L-80I/PF
On the schematic it is pic 32MX795F512L-801/PT
I entered 32MX795F512L
I contacted the Pickit3 supplier and they are sending a replacement so I suppose they must think there is something wrong with it .
I tried the pickit3 on a black and white MM and it read the chip details and programmed it ok . I will have another go at it if and when I receive the replacement
regards Jeff
jeffj
Posted: 11:07pm 06 Feb 2016
I received the replacement pickit3 and it worked ok Thanks everyone
Jeff
     Page 4 of 4
