Local Time 04:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Firmware Release Version 6.01.00
     Page 4 of 6
Sasquatch
Posted: 11:18pm 29 Dec 2025
Found a couple of minor typos when using VGA222 drivers.  The VGA222_640 driver shows as just VGA222 in the option list while the others seem to show the full name of the driver.  The Blue L pin is listed twice on the Pins List where Blue H should be. Cut and paste will get you every time!  Other than that, RGB222 is working great!
> option list
PicoMite MMBasic RP2350A V6.01.00EXP2
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 252000
OPTION LCDPANEL CONSOLE
OPTION DISPLAY 80, 160
OPTION LCDPANEL VGA222,GP15,GP17
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP8      11     OFF
GP9      12     OFF
GP10     14     OFF
GP11     15     OFF
GP12     16     OFF
GP13     17     OFF
GP14     19     OFF
GP15     20     Boot Reserved : VGA HSYNC
GP16     21     Boot Reserved : VGA VSYNC
GP17     22     Boot Reserved : VGA BLUE L
GP18     24     Boot Reserved : VGA BLUE L
GP19     25     Boot Reserved : VGA GREEN L
GP20     26     Boot Reserved : VGA GREEN H
GP21     27     Boot Reserved : VGA RED L
GP22     29     Boot Reserved : VGA RED H
GP23     41     DOUT
GP24     42     DIN
GP25     43     HEARTBEAT
GP26     31     OFF
GP27     32     OFF
GP28     34     OFF
GP29     44     AIN
-Carl
mozzie
Posted: 04:54am 31 Dec 2025
G'day,
Some further testing of Xmodem indicates a change between V6.01.00RC0 and V6.01.00RC2
Tested on WinXP, Win7-32 and Win10-64 with TeraTerm
Fresh Install of firmware after Clear_Flash.uf2 - no options set.
Using genuine Raspberry Pi Pico1 and Pico2 boards
PicoMite MMBasic RP2040 V6.01.00RC0
PicoMite MMBasic RP2040 V6.01.00RC2
PicoMite MMBasic RP2350A V6.01.00RC0
PicoMite MMBasic RP2350A V6.01.00RC2
> option list
OPTION CPUSPEED (KHz) 200000
Etc.. Etc..
Line endings up to RC0 are the normal CR/LF pair and padded with &h00
(I believe this has been since Xmodem on MMbasic began)
Xmodem s = CR/LF + &h00
Xmodem s "filename" = CR/LF + &h00
Line endings from RC2 vary as below and padded with &h1A
(used V6.01.00 to test Ymodem)
Xmodem s = LF + &h1A
Xmodem s "filename" = CR/LF + &h1A
Ymodem s = CR/LF
Ymodem s "filename" = LF
This means depending on how you move a file off the Picomite, you could end up with 4 different files. Ymodem S being the only one to move a faithful copy of the original.
For program listings this is not really a problem, but means anything that parses a file from a datalogger etc is going to have to be re-written to suit.
Considering that CR/LF is how the MMBasic print command has terminated lines since the beginning, and a lot of files and parsing software will be written around this they may no longer work.
Also means files cannot be edited in older versions of notepad as no support for LF only line termination (that I can find).
As TeraTerm is common to all my systems, could it be the problem? Next test....
Has this change been made for compatibility with Linux?
Lyle.
Edited 2025-12-31 15:16 by mozzie
Martin H.
Posted: 01:09pm 01 Jan 2026
I couldn't find it. Could someone explain the update procedure for Olimex USB again?
Edited 2026-01-01 23:10 by Martin H.
'no comment
Posted: 01:51pm 01 Jan 2026
Hi Martin,
your question
Posted: 02:01pm 01 Jan 2026
mozzie
I'll fix this in the next release. All will transmit cr/lf and xmodem will pad with null
Peter63
Posted: 02:50pm 01 Jan 2026
Hello
Is it a bug or...
X and Y mouse position can be set fine, but not wheel position...
'  wheel-pos is set to 0 at start, last wheel-pos is still showing
Mouse set 2,100,50,0 ' mouse at X100,Y50,wheel-count=0
 mx=DEVICE(mouse 2 ,x)
 my=DEVICE(mouse 2, y)
 mw=DEVICE(mouse 2, w)
 If mx<>tx Or my<>ty Or mw<>tw Then Print mx,my,mw
 tx=mx:ty=my:tw=mw
End
Using this:
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.01.00
OPTION MOUSE SENSITIVITY     1.0000
OPTION KEYBOARD US
OPTION RESOLUTION 640x480 @ 252000KHz
> Mouse Type: Standard 8-bit
 X/Y bits: 8/8
 Buttons: 3
 Report length: 4 bytes
 Has wheel: Yes (byte 1)
 Has pan: No
USB Mouse Connected on channel 2
/Peter63
Posted: 09:20pm 03 Jan 2026
@Peter,
There is a bug in official release 6.01.00 (also in the EXP7).
PIO INTERRUPT p,s,rx,tx does not generate an interrupt when data is pushed into the FIFO. See below demo program. I used RP2040 non VGA for this demo.
The program pushes a value in RX fifo (from ISR that is not initialized, so the value is random) at every key press. The key press pulses GP2. When GP2 is wired to GP0 the PIO pushes a value in RX fifo. GP1 follows GP0 to ensure the PIO runs.
FSTAT is shown, and the FLEVEL for this fifo. There should be text "interrupt" when the RX interrupt fires. But it does not.
 'PIO MMBasic INT demo
 'uses GP0 as an output, that is pulsed under keyboard control
 'each time a pulse is generated, a (any) value is pushed in RX FIFO
 'the program lists FSTAT and FLEVEL for that RX FIFO
 'PIO section ----------------------------------------------------
 PIO clear 0
pio assemble 0,".program RX"
 .line 0
   set pindirs,1             'set GP1 output
.label ret
   wait 1 pin 0              'wait for GP0 to become 1
   set pins,1                'GP1 mirrors GP0
   push noblock              'push just any value in RX FIFO
   wait 0 pin 0              'wait for GP0 to become 0 again
   set pins,0                'GP1 mirrors GP0
   jmp ret                   'and repeat
.end program list
 p=pio(pinctrl 0,1,0,gp0,,GP1,)'gp0 is base for IN, GP1 is SET
 f=1e6                         '1MHz
 pio init machine 0,0,f,p,,,0  'start at adress 0
 ' MMBasic section --------------------------------------------------------
 setpin gp2,dout               'control GP0 from MMBasic
 pin(gp2)=0
 setpin gp1,pio0             'assign GP1 to PIO for output
 setpin gp0,pio0             'assign GP0 to PIO for output
 pio interrupt 0,0,RX_int,0  'assign RX_int to an RX FIFO interrupt.
 pio start 0,0
 do
   do : k$=inkey$ : loop while k$=""   'wait for a key press
   print
   print bin$(pio(fstat 0)),pio(flevel 0,0,RX),
   pulse gp2,100
 loop until k$=chr$(27) 'escape
end
sub RX_int
 pio read 0,0,1,dummy%
 print "interrupt";
end sub
Ouput is :
RUN
0: E081
1: 20A0
2: E001
3: 8000
4: 2020
5: E000
6: 0001
1111000000000000111100000000    0
1111000000000000111000000000    1
1111000000000000111000000000    2
1111000000000000111000000000    3
1111000000000000111000000001    4
Options:
OPTION SYSTEM I2C GP14,GP15
OPTION SDCARD GP17
OPTION F5 flash run 2
Edited 2026-01-04 07:25 by Volhout
Posted: 07:17am 04 Jan 2026
@Peter,
There is another "bug" in the official release 6.01.00. Tested on RP2040 non VGA.
I found it when researching the PIO RX interrupt, where I had to use GP2 to create a test signal for GP0. That separate pin was not needed before, when I could drive GP0 and sense it at the same time. I confirmed it this morning with different programs.
In MMBasic you have made provisions so a GPx pin could be driven by MMBasic (DOUT, PWM, etc..) but at the same time could be sensed by PIO (JMP PIN, WAIT x PIN x, IN x).
That functionality is not present anymore in 6.01.00.
My frequency counter does not work anymore with 6.01.00 (neither the old one, nor the new). Some examples in the PIO training thread do not work anymore.
Please find out what happened for this to disappear (again).
It existed in 5.07 .... 5.09.00rc5, then vanished, you re-introduced it in 6.00.01, now it vanished, in 6.01.00. Is it a new compiler from RP ?
I would really appreciate this feature to be revived in 6.01.00. 6.01.00 is a good "final" for the RP2040, especially when this is fixed.
Thank you,
Harm
Edited 2026-01-04 17:22 by Volhout
Posted: 08:49am 04 Jan 2026
  Quote  Some examples in the PIO training thread do not work anymore.
Please list a non-working program and how to wire to run it. I tested la_24_2 as always.
Edited 2026-01-04 18:54 by matherp
Posted: 09:57am 04 Jan 2026
Hi Peter,
I have shrunk the problem down to a pin set for DOUT. A PWM set pin does work (as shown by the logic analyzer).
Example programs
GP2.BAS : connect a wire between GP2 and GP0. Monitor GP1. GP1 should follow the signal on GP0 (and thus GP2).
GP0.BAS : no wire needed. GP0 is pulsed from MMBasic. The same PIO routine tries to monitor the pin, but can not. Thus GP1 is not pulsing.
I used LED's connected to GP0 and GP1, but a scope would do even better,
gp0_gp2.zip
Edited 2026-01-04 19:58 by Volhout
Posted: 11:06am 04 Jan 2026
I've fixed the RX interrupt bug. The GP0 issue is caused by the order of commands in your program. You are setting GP0 to output after you have initialised the PIO which overrides the setting as also an input in PIO INIT. You should also set any pins to PIO before enabling the machine
This works
 PIO clear 1
PIO assemble 1,".program RX"
 .line 0
   Set pindirs,1             'set GP1 output
.label ret
   Wait 1 pin 0              'wait for GP0 to become 1
   Set pins,1                'GP1 mirrors GP0
   Wait 0 pin 0              'wait for GP0 to become 0 again
   Set pins,0                'GP1 mirrors GP0
   Jmp ret                   'and repeat
.end program list
 p=Pio(pinctrl 1,1,0,gp0,,GP1,)'gp0 is base for IN, GP1 is SET base
 f=1e6                         '1MHz
 SetPin gp1,pio1            'assign GP1 to PIO for output
 SetPin gp0,dout               'control GP0 from MMBasic
 Pin(gp0)=0
 PIO init machine 1,0,f,p,,,0  'start at adress 0
 PIO start 1,0
   Pause 300
   Pulse gp0,100
End
Edited 2026-01-04 21:08 by matherp
Posted: 12:13pm 04 Jan 2026
Hi Peter,
I Will re-order the setpin commands in my frequency counter. Most likely it will work then.
Posted: 03:04pm 04 Jan 2026
AFAIremember this hasn't changed since the fixes for RP2350 E9 were made way back when. The fix I introduced is in PIO INIT  and automatically turns on input mode for all GPIO. This would always have been countermanded by setting a pin to an output after the init. As I noted above I always test with LA_24_2 and that definitely works without modification.
homa
Posted: 03:53pm 04 Jan 2026
  matherp said  I've fixed the RX interrupt bug.
Good to hear! Can I have the corrected version, please?
Posted: 04:30pm 04 Jan 2026
It is in the 6.02.00RC0 release
Bleep
Posted: 05:55pm 04 Jan 2026
  Volhout said  @Peter,
Thank you,
Harm
Hi Harm,
I agree with you, that the 2040 should probably stay at 6.01.00 apart from bug fixes, if I want the new features like structured types, I can easily use a 2350. I haven't updated any of my 2040 to 6.02.00....
Regards Kevin.
Posted: 06:03pm 04 Jan 2026
Sorry, but I'm not retrofitting bug fixes back into 6.01.00. That would mean supporting two parallel versions. 6.01.00 is as now and you will have to accept the bug list that goes with it. If you want the bugs fixed then 6.02 is the option to use whether RP2040 or RP2350
homa
Posted: 06:05pm 04 Jan 2026
  matherp said  It is in the 6.02.00RC0 release
Thanks. I tested it (rp2040), it works for receiving. I think the error still exists for transmit interrupt when the FIFO is full:
FSTAT: 00001111000000000000111100000000
Flevel: 0
LEVEL TX: 4
LEVEL RX: 0
FSTAT: 00001110000000010000111100000000 <<-- I miss the interrupt here.
Posted: 06:15pm 04 Jan 2026
  Quote  The TX interrupt triggers whenever the specified FIFO has been FULL and the
PIO code has now "pulled" it
The idea is that the interrupt can keep the fifo topped up. It is a "was full and not now" interrupt. If you don't believe this is working please provide a test program for me to use to investigate.
homa
Posted: 07:12pm 04 Jan 2026
You're right, I got it wrong again and thought backwards . This interrupt works too. Now I can continue with the PIO studies.
Thank you!
     Page 4 of 6
