Local Time 10:42 12 Nov 2026 Privacy Policy
     Page 4 of 25
Posted: 04:38pm 02 Oct 2024
Unfortunately I don't think I found everything. :(
stanleyella
Posted: 06:26pm 02 Oct 2024
do usb to ps2 keyboard adaptors work? I got 3 from old pc days.
all I use usb vga for is a usb keyboard.
Edited 2024-10-03 04:49 by stanleyella
Posted: 06:36pm 02 Oct 2024
Wrong thread for this question, Stan.
It depends on the keyboard.
Early USB keyboards also supported PS2 protocol and would switch over if that's what the computer was expecting. Some later ones dropped this facility as there were fewer and fewer PCs with a PS2 socket, however a lot of Chinese manufacturers carried on using the old system so their keyboards often will work with an adapter.
Edited 2024-10-03 04:38 by Mixtel90
stanleyella
Posted: 07:00pm 02 Oct 2024
cheers Mick, I got 3.3v ps2 key board and rewired to molex pins but it's full size and usb keyboards can be mini. no ps2 sockets and not strip board  anyway so solder wires to usb adaptor
https://www.aliexpress.com/item/1005001382472035.html
Edited 2024-10-03 05:19 by stanleyella
stanleyella
Posted: 08:06pm 02 Oct 2024
Posted: 08:08pm 02 Oct 2024
The keyboard is powered from what it's plugged into. If you power them from 3V3 some will work and some won't, but you don't need level shifters. If you power them from 5V then they all work but you do need level shifters for a RP2040 (you can get round it with RP2350s in some cases). USB keyboards always expect 5V and you shouldn't attempt to run a 3V3 USB system - there'll be tears if you do.
The hard wiring of the interfaces is only half the job. It doesn't work unless the firmware and keyboard hardware supports it.
Edited 2024-10-03 06:09 by Mixtel90
Posted: 09:37pm 02 Oct 2024
  Quote  Please post on this thread any bugs found. Please NOTHING ELSE.
stanleyella
Posted: 09:43pm 02 Oct 2024
I have a usb vga pico 2 and it connects to pc through usb to ttl and same pins as ps2 keyboard. I just flashed non usb vga rc2 and thinking what would happen if I connected the usb keyboard to usb to ttl converter as it's 5v is wired to vbus as it powered the pico in usb mode.
now nonusb it connects to pc with micro usb but usb to ttl still connected. any harm?
need a usb female to usb female to connect kb to usb to ttl to test
this usb vga non vga connect to pc using micro pico2 usb but usb to ttl still connected to vbus ie pc usb 5v so usb to ttl got 5v to power usb keyboard
Edited 2024-10-03 08:17 by stanleyella
Posted: 09:50pm 02 Oct 2024
dddns
Posted: 07:50am 03 Oct 2024
My setup is a PicoMiteUSBRP2040V6.00.00RC1 with lcdpanel ssd1963_7 and an usb keyboard attached. The lcdpanel is also the console.
When scrolling in the editor with an open serial session the output on the lcd is like twice as fast as when cursor up/down is pressed continuously on the usb keyboard.So the display does not seem to be the bottleneck. Can anyone confirm?
Posted: 09:06am 03 Oct 2024
You can change the USB keyboard repeat rate with
OPTION KEYBOARD REPEAT first_repeat, subsequent_repeats
times are in mSec 100-2000 for first repeat, 25-2000 for subsequent repeats
defaults are 600,150
Edited 2024-10-03 19:06 by matherp
dddns
Posted: 09:38am 03 Oct 2024
Many thanks Peter! Haven't seen this option before..
Now both have the same speed and the console on this 7" is very usable, no matter it runs in 8 or 16-bit mode.
electricat
Posted: 02:47pm 03 Oct 2024
picomiteVGA without SDCARD
firmware PicoMiteVGARP2040V6.00.00RC3.uf2
edit as new program, write line
Print MM.Info$(SDCARD)
Returns message Error: SDcard not configured
Edit
Now listing has changed as
MM.Info(SDCARD)
$  string marker disappeared
Add option
OPTION SDCARD DISABLE
tray again - same returns same error
LIST FUNCTIONS
i see MM.Info$ in list
Something must be going wrong here.
Edited 2024-10-04 00:48 by electricat
My MMBasic 'sand box'
homa
Posted: 02:48pm 03 Oct 2024
@Peter
I don't know if this is a bug or intentional. But in the
> option list
PicoMiteHDMI MMBasic Version 6.00.00RC3
OPTION FLASH SIZE 4194304
OPTION COLORCODE ON
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 372000
OPTION DISPLAY 30, 80
OPTION HDMI PINS 1, 3, 7, 5
OPTION RESOLUTION 1280x720
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION MODBUFF ENABLE 192
OPTION PLATFORM OLIMEX
OPTION DEFAULT FONT 3, 1
version, nothing is displayed on the monitor in the editor when using the mark function! Only in the Tera Term window on the console. I personally find this unsatisfactory.
Matthias
homa
Posted: 03:02pm 03 Oct 2024
same version.
The font becomes larger after a LOAD, if not in MODE 1
> mode 1
> load "testcard"
> mode 3
> load "testcard"
Posted: 03:15pm 03 Oct 2024
mm.info() and mm.info$() are functionally the same. You can use either AFAIK. It will always be displayed as mm.info() though.
Mode 3 isn't always the same as Mode 1. It is in 640x480 but not in 1280x720 or 1024x768. The font size will change.
https://www.thebackshed.com/forum/ViewTopic.php?TID=17303&P=2#227615
homa
Posted: 03:33pm 03 Oct 2024
Mick, you didn't understand me. Try it out and you'll see the problem.
Matthias
Posted: 03:46pm 03 Oct 2024
Load resets the font to the default for the resolution. You can change the default font using OPTION LCDPANEL CONSOLE. I'll look at the highlighting problem.
homa
Posted: 04:50pm 03 Oct 2024
@peter
my english is too bad to describe the problem. Enclosed is a small video with the HDMI grabber as a ZIP file.
Matthias
2024-10-03 mmbasic load font bug.zip
dddns
Posted: 09:29pm 03 Oct 2024
When using a ssd1963_7 a "framebuffer create" leads to a "not enough heap memory" error. I guess that is correct because of the too high resolution. Is it?
     Page 4 of 25
