Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite RP2040: V6.00.00 betas
     Page 4 of 4
Posted: 06:18am 26 Sep 2024
@Peter,
I am looking into a way to support the build in EDIT function in javavi's filemanager.
Let me explain.
The filemanager is running in a flash slot. It is coded in MMBasic.
I understand very well that LOAD "fn" and EDIT "fn" cannot be executed inside a MMBasic program since they essentially destroy the current program when in program memory.
RUN "fn" works, but it is basically a form of a cold reboot, re-initializing everything.
Questions:
LOAD "fn" should technically be no problem when executed from a flash slot. Since it loads the program in main program memory.
When running in a flash slot, why would EDIT "fn" be a problem. I understand you have to exit the flash slot program, since variable memory is freed up for the editor. So it would be similar to RUN "fn".
When looking at MM.CMDLIN$, I wondered why RUN "fn",chr$(3) would not work. I expected the program to run, and immediately stop with control C. Maybe I misunderstood the function of the option.
Long story short.. have not found a solution yet. Maybe I can find something by using a CSUB. Have to start studying...
Edited 2024-09-26 16:21 by Volhout
Posted: 01:21pm 26 Sep 2024
V6.00.00b9
PicoMiteV6.00.00b9.zip
Fixes a bug in errors corrupting Option Display settings in Pico/PicoUSB
NB: github now up-to-date
Edited 2024-09-26 23:21 by matherp
javavi
Posted: 04:29pm 26 Sep 2024
  matherp said  NB: github now up-to-date
dddns
Posted: 05:28pm 26 Sep 2024
Hello Peter,
when setting up "option lcdpanel ssd1963_7,l,,gp16,noreset" it works fine in 8-bit mode.
When retrieving the options by "option list" a ssd1963_5_16 is reported.
Same for "option lcdpanel ssd1963_7_16,l,,,noreset" where a ssd1963_5E_16 is reported.
Dietmar
Posted: 05:39pm 26 Sep 2024
Thanks - will fix
Posted: 07:54am 27 Sep 2024
@Peter,
You said you could provide a way to indicate the presence of a PS2 keyboard.
Is this some PEEK() ?
I think it could be usefull, since key presses cannot clearly distinguish between INKEY$ and MM.INFO(PS2). Sometimes one is earlier, sometimes the other when polled in a loop.
INKEY$ is active at PS2 and at console.
Edited 2024-09-27 17:58 by Volhout
     Page 4 of 4
