Forum Index : Microcontroller and PC projects : Picomite VGA Logic analyzer
All, This is version LA_23 with - in 6 channel mode, lower part of the screen is help text - user manual small changes Put banner.bmp and LA_23.bas in one directory, and run LA_23 Suc6 Volhout LA_23.zip PicomiteVGA PETSCII ROBOTS |
All, For those people running PicomIteVGA version 5.0708b7 and later, you can benefit from the improved DMA functionality. This does not add features to the LA, but allows infinite wait times for a trigger. The earlier releases would time out after minutes...hours depending the sample speed. Peter has fixed this in MMBasic. This version makes use of that fix. Volhout LA_24_DMA_autodetect.zip Edited 2023-07-01 03:43 by Volhout PicomiteVGA PETSCII ROBOTS |
Minor update to LA_24. - faster screen writes using framebuffer. Tested on V50800beta5. Screen update from 281ms (252MHz) down to 119ms. - fixed a bug in channel name editor LA_24_1.zip Volhout @Peter: the vertical lines in the trace are disabled for in this version. Uncomment line 649 to get them back. Edited 2024-01-11 01:09 by Volhout PicomiteVGA PETSCII ROBOTS |
Now that we have the 2350B, can this be extended to sixteen channels? Only asking out of curiosity |
Hi Phenix, The logic analyzer internally is 32 bit. So the answer is Yes. But... There is always a but.. In this case there are 2 buts.. ![]() 1/ Trigger The logic analyzer uses PIO's, and PIO's cannot perform logic math. To set up a trigger condition, the PIO has to analyze the GPIO pin condition bit for bit. (No logic AND or OR or EXOR). And each condition check is a small PIO routine, that get's dynamically added to the PIO program. And the PIO program space is finite. So 6 trigger conditions will fit, but not more. Hence, 6 or 8 channels in the current code. If you would alloow only 6 trigger conditions for 16 channels, the user interface (that is channel alligned) mus be rewritten. 2/ Display The current display consumes 120ms(2040) or 90ms(2350) of plotting data in the view window. This is added to the sampling period, and the post processing of the data. To extend that to 16 or more channels makes the logic analyzer really slow (apart from the fact that the screen resolution (640x480) will not allow a very good vertical resolution. Of coarse the display engine needs to be adapted to the 16 channels. And maybe dynamic, since there is also text in between the traces (I2C decoding/Timing measurement). Please find attached the latest Logic Analyzer running on 6.00.03. LA_25.zip Volhout Edited 2025-08-29 16:56 by Volhout PicomiteVGA PETSCII ROBOTS |
