Forum Index : Microcontroller and PC projects : PicoMite VGA Edition PCB - release version
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12179 |
VGAMite (Bill Of Materials).zip Anything with highish impedance input - say 300ohm |
Hi Peter, Just investigating.. Do you have a spare 1.7 board that you can put in an envelope and mail to me? If not, I will order some boards. In that case, do you (or anyone else) need 1 or more boards. Regards, Volhout PicomiteVGA PETSCII ROBOTS |
| scruss Senior Member Joined: 20/09/2021 Location: CanadaPosts: 116 |
Volhout - I've got a couple of boards from the July 29 release (which is as "final", but with a minor silkscreen error). Shipping even one from Canada would likely cost more than a full JLCPCB order, though |
Hi scruss, With Tom (thwill) from UK and Mick (bigmik) we have simply slid a single PCB in an envelope and send is as a post card (letter) with standard post stamp. Successfully. Not sure if that works all the time, but it seems a way to avoid excessive transportation cost. Not sure if this works for Canada though.... Volhout PicomiteVGA PETSCII ROBOTS |
Ill await Peters answer, and then order some myself. Thanks for the respons.. PicomiteVGA PETSCII ROBOTS |
OK, Ordered 5 boards of the 1.7 release. I probably need 2-3 myself, so I have 2 to give away... They should arrive 4 weeks from now. PM me if you are interested. Volhout PicomiteVGA PETSCII ROBOTS |
For those who do are running out of PS2 keyboards, this cheap keyboard works with picomite VGA. It has slightly larger travel than the real laptop keyboard, and slightly heavier force required. But for the price, you can't beat it... Make sure you order the PS2 version, not the USB version.... small PS2 keyboard Volhout Edited 2022-09-28 18:27 by Volhout PicomiteVGA PETSCII ROBOTS |
Thanks - that looks like a rather nice little keyboard. I'm not running out, but I might get one anyway as all mine have a numeric pad. I might have to live without UKP and pay everything in $ though. lol Shipping is a little pricey. Edited 2022-09-28 18:54 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
JLCPCB was fast Less than 2 weeks and the boards where in Netherlands.. And less that 2 hours later....... Up and running... Good thing that between 1.4 and 1.7 the location of the connectors was not changed, so I could mount the 1.7 board 1:1 in the case. ![]() Thanks Peter !! P.S. I have 2 board spare (1.7 version). PM me if you need one... PicomiteVGA PETSCII ROBOTS |
It makes up into a very nice little unit, doesn't it? Mick Zilog Inside! nascom.info for Nascom & Gemini |
Looks good! John |
@Volhout: Do you have a template for your pretty bezels? They look very professional! I would have to make some for my housing as well... Frank |
Hi Frank, The bezels came with the box (the G738A from Farnell). I just drilled some holes in it and filed (is that je right word ?..grinded ?) them to size. I can "photocopy" them if you like, but I have no CAD files. Regards, Volhout PicomiteVGA PETSCII ROBOTS |
This would be something that SL6 might be good for. The front and rear plates could then be made as PCBs in your choice of solder resist colour with white or black screen printing. :) Unfortunately they are too big to fit ito the 100x100 special offer size at JLCPCB. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Volhout, that would be great! THANKS! Frank |
For contrast I added orange paper... The manual drilling and grinding causes damage to the visible surface, so I took some sanding paper to give the Aluminum a cleaner look. ![]() Edited 2022-10-22 18:59 by Volhout PicomiteVGA PETSCII ROBOTS |
Thank you very much! I'm currently toying with the idea of laser cutting the appropriate parts out of plastic in our FabLab. Frank |
Question about the LM1117 LDO regulator: it's really a 1.8 V value? (The BOM says LM1117T-1.8/NOPB). Thanks! Also, the SD card holders seem to be available again. The parts you can actually buy are the DM1AA-SF-PEJ(82). The DM1AA-SF-PEJ(21) on the BOM seems to be an older revision. Looking forward to getting this running. I'll have to make a component run to pick up some 2R2 resistors and the right LDO. All I've got for regulators are 7805s or LD33Vs |
3.3v regulator. Ld33v may work. 1.7layout is dual footprint. PicomiteVGA PETSCII ROBOTS |
Much appreciated! |
