Local Time 15:18 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CM2: DIM bit
     Page 4 of 4
Posted: 12:35pm 20 Sep 2020
the below line in your code may be a problem:
'Dim Integer Flag
in particular, that pesky little single quote make at the start of the line!
btw, from experiment, it looks like 1<<bit doesn't need to be bracketed.
rob   :-)
addendum: what version of mmbasic are you running? i'm wondering if you've tripped over a more 'severe' case of the bug just fixed in the latest MX170 version, involving the conversion of floats to integers.
Edited 2020-09-20 22:42 by robert.rozee
Posted: 12:47pm 20 Sep 2020
  robert.rozee said  the below line in your code may be a problem:
'Dim Integer Flag
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Good spot Rob. Just blind to that... for god's sake!
You are a star! I feel such an idiot!
Hoist by the Law of the Too-Solid Goof.
yes deduced that as well - thanks for checking.
So now I will go and tweak everything back again.
As to the version, I am running 5.0408 on '170 Micromites (my main interest is embedded micro-controllers). I know, I know... but there is a method to my madness; 5.0408 was the last really stable version before a change that meant VAR SAVEs were obliterated on uploading new software. I can't do that as I store config data in flash and a relatively minor tweak of my code could require re-config on dozens of modules - I am thinking specifically of seven installations of my snooker hall table light control that has a MM and HC12 in a ceiling rose and the light gets turned on and off wirelessly and metered accordingly. Every module there (and the largest club has almost two dozen tables) is configured at first light then stores its config and reports itself to the master at discovery time. As things are, I can simply upload new software to each module (which is work enough) and move on to the next without having to reconfigure each one as well with it's network address, name and some other stuff. I would update everything but that change means I am stuck... it's not such a bad place TBH, 5.0408 is pretty bomb-proof. I have up-times measured in years.
Edited 2020-09-20 23:02 by CaptainBoing
Posted: 12:52pm 20 Sep 2020
Take the comment off the DIM line might help
Posted: 01:54pm 20 Sep 2020
  twofingers said
  Mixtel90 said  I came up with something else of more concern if you are looking for a lot of bit storage. Using original or new versions of these routines I can't reset bits from bit 53 upwards, even though all variables are integers. They will set and test but not reset.
Here's my little test prog. Input command,bit_number e.g. s,0 will set bit 0
bits01.zip
This should work:
Function inv64(b As integer) AS INTEGER
inv64 = b Xor &hFFFFFFFFFFFFFFFF
End Function
Yep, that works properly - right up to bit 63. Thanks. :)
     Page 4 of 4
