Local Time 20:24 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Power Jack expert help needed
     Page 4 of 4
BenandAmber
Posted: 02:57am 29 May 2019
I'm sorry I'm just not getting it I'm shooting for a hundred and twenty volt
1 to 9 ratio if I'm understanding that right for every nine turns on the high side secondary they'll be one turn on the low side primary
If so I'm really confused because that only comes out to like 16 .2 turns
When I plug the high side secondary and to the wall with three turns of junk wire on it I got 2.46 volts for the three turns
If I would have put a hundred and eighteen turns instead of 146
I would have got basically 1 volt per turn on my junk wire 3 turn test
If I remember correctly the other times I've done it this way
I had to take a few turns off the low side primary
my estimate was too high by doing it this way
Maybe I'm not understanding the RMS voltage or something
Like I said earlier I usually just shoot for whatever voltage the board takes for its low side primary like 28 volts or a 32 volts
Wind whatever my estimate is and then take away to make the voltage right
So I need to know what voltage the Nano will take with a power jack board to do it the way I usually do it
I probably just got lucky in the past because it don't sound like it's that easy
Sorry I know you're probably beating your head against the wall saying why can't he get thisEdited by BenandAmber 2019-05-30
tinyt
Posted: 06:38am 29 May 2019
Hi Ben,
I realize it is confusing because I used the output voltage of 240VAC instead of 120VAC.
Let me try it this way for a 48V Battery system:
For 240VAC output:
Ratio Primary voltage
1:7 34.28VAC
1:7.5 32VAC
1:8 30VAC
1:8.5 28.23VAC
1:9 26.67VAC
For 120VAC, since it is half of 240VAC, the ratio has to be divided by 2.
1:3.5 34.28VAC
1:3.75 32VAC
1:4 30VAC
1:4.25 28.23VAC
1:4.5 26.67VAC
In my opinion you should shoot for 28VAC to 29VAC. So for a secondary 146 turns and 120VAC output and using the ratio 1:4.25, the primary turns will be 146/4.25 = 34.35 turns. I would round it up 35 turns.
I think the nano control board has a trimpot R31 (VFB ADJ) you can use to set the ouput voltage very close to 120VAC. Edited by tinyt 2019-05-30
BenandAmber
Posted: 12:40pm 29 May 2019
Okay that makes sense thank you tinyt
Sorry for the headache
     Page 4 of 4
