Local Time 10:17 12 Nov 2026 Privacy Policy
     Page 31 of 52
Bleep
Posted: 06:57pm 20 Apr 2025
Tried on two different power sources, also checked DVDD at 1.305V, incase, also tried a flash nuke and re-install, still worse than before, here is my options, just incase.
PicoMiteHDMI MMBasic USB RP2350B Edition V6.00.02RC16
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD UK, 0, 0, 180, 120
OPTION PICO OFF
OPTION CPUSPEED (KHz) 372000
OPTION RESOLUTION 1280x720
OPTION DISPLAY 22, 53
OPTION HDMI PINS  1, 3, 5, 7
OPTION SDCARD GP29, GP30, GP31, GP32
OPTION KEYBOARD REPEAT 180,120
OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11
OPTION RTC AUTO ENABLE
OPTION COUNT GP0,GP1,GP2,GP3
OPTION MODBUFF ENABLE  512
OPTION PLATFORM HDMIUSBI2S
OPTION DEFAULT FONT 3, 1
electricat
Posted: 08:27pm 20 Apr 2025
  mozzie said  G'day,
After some editing, my version is down to approx 40kb, this is by grouping some commands together (framebuffer / peek / poke / setpin) removing PIO (don't understand yet) and Wii / Gamepad (don't use) but with the bit / byte / flag commands added, as well as stuff I always forget (alignment in text etc).
This is scenario I expected. Users will customise to their needs
I believe 98% users interested in such systems (Picomite,CMM2 etc) has good text editing backgrounds by default
Edited 2025-04-21 06:29 by electricat
My MMBasic 'sand box'
stanleyella
Posted: 08:38pm 20 Apr 2025
the options are now so many, lots of new I don't know. not moaning just hard to keep up
electricat
Posted: 05:16am 21 Apr 2025
  stanleyella said  the options are now so many, lots of new I don't know. not moaning just hard to keep up
But this is what makes it interesting to play together. Nowdays I rarely fire up my soldering station.
Pater (and Geoff) gave us such an interesting 'game' into our hands - it`s hard to resist
toml_12953
Posted: 06:26am 21 Apr 2025
I just loaded the updated RC16 and now when I list a program I get an unentered header:
'#A:/solutions/01.speedo
The program name is "01.speedo" and it's in the solutions directory on drive A:. It doesn't show up when I edit the program, just when I list it.
Where is it coming from?
Edited 2025-04-21 16:28 by toml_12953
electricat
Posted: 11:05am 21 Apr 2025
There is trade off.
Not that big ~390-430 Kb file to start with, but only commands and functions left.
Switch on main PC for full manual , or open printed version if you like list paper to dust  or use electricat`s experimental help system for reading offline which is happy to eat space drive B: Or.... add information you need.
Personaly I need separators for faster look through multiple topics. So added files with and without them.
if entered
>HELP ***
all topics will be listed . If you do not like it, it is so easy remove them with notepad++
When creating my experimental help system I tried to group by theme, so added keywoards. This way newbie user could accidently quess for something what he is looking for.. this way if he enters
>HELP *DRAW*
he will get commands as much close to drawing on screen as I was able to think off.
I also leaved as is some of my BETA notes. If user would enter
> HELP *BETA* all topics related to BETA changes will be listed. As some changes are not only commands, but changes in system behavour, for example.
If you like keywoards idea - get file 'full_Commands_and_Functions_with_Electricat_keywoards' with or without separators
At some point I added Apendixes inside of document as I do not like jumping back and forth when reeading. Did not cut out these. If one wants get rid of them or tune it by personal taste - search through for "Appendix"
full_Commands_and_Functions-full-_no_separators_help.zip
full_Commands_and_Functions-full-help.zip
full_Commands_and_Functions_with_Electricat_keywoards_no_separators_help.zip
full_Commands_and_Functions_with_Electricat_keywoards_help.zip
Posted: 11:14am 21 Apr 2025
Another one for Bleep to try
PicoMite.zip
toml_12953
Posted: 11:21am 21 Apr 2025
  electricat said  There is trade off.
if entered
>HELP ***
>HELP *DRAW*
Should you really be duplicating the parameters in the search string when they're listed in the descroption?
Example:
~OPTION AUTORUN OFF*
OPTION AUTORUN OFF
Disables autorun.
~OPTION AUTORUN ON [,NORESET] or OPTION AUTORUN n [,NORESET] or OPTION AUTORUN OFF*
Could that be shortened to:
~OPTION AUTORUN *
OPTION AUTORUN {ON[,NORESET] | OFF | n[,NORESET]}
Enables or disables autorun or runs a program on powerup or restart.
Edited 2025-04-21 21:26 by toml_12953
Posted: 11:36am 21 Apr 2025
Please could you start a new thread for discussing Help files and how best to use the new (fixed) functionality
twofingers
Posted: 01:20pm 21 Apr 2025
Hi Peter,
I have an idea that might be useful for the next version. Maybe you could think about it sometime when you have time. I imagine there could be a USERSTRING option. This is a string that the user can use for any purpose, e.g., configuration data , at their own discretion (e.g. using csv), and like other system OPTIONS, it will be retained after shutdown until it is deleted, overwritten, or until new firmware is installed.
Kind regards
MIchael
Posted: 01:22pm 21 Apr 2025
There is: Option platform
twofingers
Posted: 01:25pm 21 Apr 2025
Thanks! I thought it was tied to the hardware somehow. I'll look into it.
  Quote  OPTION PLATFORM name$
Allows a user to identify a particular hardware configuration that can then be used in programs to control the program's operation.
'name$' can be up to 31 characters long. This is a permanent option.
MM.INFO$(PLATFORM) returns this string.
For example, this can be used on a particular hardware configuration:
OPTION PLATFORM "GameMite"
Then programs that might run on this or other platforms can use:
IF MM.INFO$(PLATFORM) = "GameMite" THEN …
I'm not sure 31 bytes will be enough in every case. But we'll see...
Edited 2025-04-21 23:44 by twofingers
Bleep
Posted: 01:52pm 21 Apr 2025
  matherp said  Another one for Bleep to try
PicoMite.zip
Hi Peter,
Definately the best so far, both monitors, occasionally flash, on average about every 15 to 20 seconds.
Posted: 03:38pm 21 Apr 2025
V6.00.02RC17 is available on
Fixes bug in i2s audio on RP2350 VGA versions
Fixes bug in command stacking for Help commands
Removes spurious header line in LIST command
Improves stability of HDMI 1024x768 and 1280x720 while playing MP3 over I2S
Reduces the memory footprint of MP3 playback on the RP2350
Enables OPTION RESOLUTION 640,378000 for HDMI versions - NB: not all monitors will work with this as the frequency isn't perfect
Disables completely single precision H/W floating point on the RP2350. MMBasic doesn't use this. The only major use is MP3 playback and this works better using the in-built ROM routines
BishopXXL
Posted: 05:02pm 21 Apr 2025
Hi Peter,
thank you very much, now "GUI Gauge" is working perfectly again!
Thomas
toml_12953
Posted: 06:21pm 21 Apr 2025
Is there any way to edit the LIBRARY file? I want to make a small change and don't want to type it all in again. I looked through the manual but I didn't see anything about it.
Posted: 06:48pm 21 Apr 2025
Another for Bleep
PicoMite (2).zip
twofingers
Posted: 06:58pm 21 Apr 2025
  toml_12953 said  Is there any way to edit the LIBRARY file? I want to make a small change and don't want to type it all in again. I looked through the manual but I didn't see anything about it.
  Quote  LIBRARY DISK SAVE fname$ will save the current library as a binary file
allowing a subsequent call to LIBRARY DISK LOAD fname$ to restore the
library. Together, these allow libraries specific for individual programs to be
stored and restored easily and distributed. Other than using version specific
functionality in the library (WEB, VGA, GUI) libraries can be shared between
versions.
MIchael
Bleep
Posted: 08:37pm 21 Apr 2025
  matherp said  Another for Bleep
PicoMite (2).zip
Better again, haven't seen a flash at all, when not playing an MP3 and up to a minute whithout a flash when playing an MP3, strangely they seem to come in batches, nothing for a minute, then it'll do it 3 times in 10 seconds, then a long break again? both monitors are doing roughly the same.
Interestingly, one monitor works perfectly at 640,378000, the other not at all really, the occasional lock, usually after a reset, but as you say, may not work at all.
toml_12953
Posted: 11:14pm 21 Apr 2025
versions.
MIchael
Yeah, I know about those but if I make a change to one SUB whose name is already in the library, I can't save that SUB. I get an already defined error. Right now, I'm keeping the entire library in a .BAS source file and when I make a change to it, I do a LIBRARY DELETE and LIBRARY SAVE the updated routine. I was hoping to be able to eliminate the .BAS file.
     Page 31 of 52
