Local Time 23:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4 $ WiFi Serial Transceiver Module
     Page 3 of 7
mindrobots
Posted: 06:01am 02 Oct 2014
Don't forget, you can join the PropellerPowered IRC chat even if you don't have your Micromite and ESP8622 talking together.........yet
viscomjim
Posted: 01:19pm 02 Oct 2014
Hello again OBC... I loaded the code for your full featured IRC and seems to work well using uMite with TeraTerm. I used the IP address and it seemed to log in correctly. The only thing is that I get this...
BronedB!~BronedB@NewNet-DD7729D8.adsl.alicedsl.de PRIVMSG #PROPELLERPOWERED : 05:07:23
about every 10 seconds. Not sure what this is.... Any ideas?
Posted: 01:32pm 02 Oct 2014
  Oldbitcollector said
The chat takes place on Saturday nights, 9pm EDT. irc.newnet.net #propellerpowered
What time is that in the rest of the world?
I am guessing that you are UTC -4
UTC +10 going to daylight saving time in a few days...
viscomjim
Posted: 02:59pm 02 Oct 2014
OBC, I did a AT+RST on my ESP and relaunched your IRC VT100 and all looked better. Seems to log on correctly... I get
:irc.newnet.ludd.ltu.se NOTICE AUTH :*** Looking up your hostname...
irc.newnet.ludd.ltu.se NOTICE AUTH :*** Found your hostname
irc.newnet.ludd.ltu.se NOTICE AUTH :*** No ident response; username prefixed with ~
*** LOGGED INTO CHANNEL: #propellerpowered ***
and then get
<BronedB> 06:42:54
every 9 or 10 seconds.
When I type 'my message, it shows up like I think it should (never used irc). Hopefully all is well....
To change my identity here, do I change the IRCNICK$ or the IRCNAME$?
Thanks again
Edited by viscomjim 2014-10-04
plasma
Posted: 04:58pm 02 Oct 2014
iam so sorry , i fall into sleep and forget to kill my little Testprogramm which sends time all 5000 loops.
plasma
Posted: 04:59pm 02 Oct 2014
change your Nick
viscomjim
Posted: 02:55pm 03 Oct 2014
@plasma, could you explain how you did that?
edit...
the 5000 loop thing, I mean
Edited by viscomjim 2014-10-05
Ray B
Posted: 10:39pm 04 Oct 2014
Following is a link with an example of how to use the ESP8266 with an arduino but the important thing is to understand how the html/cmd instructions are required to drive things.
http://www.instructables.com/howto/ESP8266/
Also read the comments at the end of the instructable on issues like reflashing the units & power requirements.
Enjoy
RayB from Perth WA
plasma
Posted: 09:50am 05 Oct 2014
little speedtest for
esp8266 and micromite & glb
the modul and the micromite together.
mode3 , tcpserver on port8080, micromite prints the incoming bytes to teraterm.
the black window is the glbasic windows which sends some bytes to the tcpserver.
sending is without pause but the result lags sometimes.
Edited by plasma 2014-10-06
plasma
Posted: 11:45pm 05 Oct 2014
Hi ,
How to claculate the time and date from a ntp
Server package ?
I connect an ntp server to get the right time and date.
The ntp server sends some bytes but what should i do
To calculate the time or date?
Anyone knows or has a solution?
Thx
BobD
Posted: 12:10am 06 Oct 2014
It may be simpler to attach a GPS module and get the data from that. However if you want some light reading on NTP then try these links. Good luck.
http://en.wikipedia.org/wiki/Network_Time_Protocol
http://tools.ietf.org/html/rfc5905
viscomjim
Posted: 02:46am 06 Oct 2014
Hi Plasma, here is an article where instead of using the NTP service, which seems to be a pain, he did it a different way using his own server, I think.... hope it helps a bit.
viscomjim
Posted: 06:38am 07 Oct 2014
I am trying to emulate this project using the uMite and the esp8266. I have gotten everything to work and am successfully getting the data back from openweathermap.org.
However, the lucky arduino folks have a library that parses the json data for them and they just have to pick and choose what they want to read.
Here is what a typical return from openweathermap.org looks like as one long string...
{"coord":{"lon":-0.13,"lat":51.51},"sys":{"type":1,"id":5091 ,"message":0.1227,"country":"GB","sunrise":1412662312,"sunse t":1412702671},"weather":[{"id":521,"main":"Rain","description":"proximity shower rain","icon":"09d"}],"base":"cmc stations","main":{"temp":287.01,"pressure":998,"humidity":47 ,"temp_min":285.15,"temp_max":288.15},"wind":{"speed":7.2,"d eg":240},"clouds":{"all":40},"dt":1412696773,"id":2643743,"n ame":"London","cod":200}
I copied and pasted this into this and you can see how things are broken out.
My difficulty is this... As this is one long string, I can't set it to a variable name as it is longer than 255 characters. I am only able to display this because I am reading the comm port and displaying one byte at a time. What can I possibly do to "parse" the information I want to pull from this and assign it to a variable, numerical or string, ie...
country$="GB"
sunrise=1412662312
pressure=998
humidity=47
main$="Rain"
description$="proximity shower rain"
icon$="09d"
name$="London"
etc, etc...
A challenge indeed. If anyone needs the code that I am using to get this far, I can post it once I make it pretty, but it does work well.Edited by viscomjim 2014-10-08
Oldbitcollector
Posted: 06:51am 07 Oct 2014
It almost looks like you could count the colons and know where you are in the string. I did this with the IRC client and it's working well.
8th colon is GB between " marks, 9th is sunrise.. and so forth..
Is this format consistent?
My Propeller/Micromite mini-computer project.
viscomjim
Posted: 07:25am 07 Oct 2014
OBC, I will take a look at different locations and see if the data comes in consistently. Thanks for the reply....
First i would choose another format, like XML.
http://api.openweathermap.org/data/2.5/weather?q=London&mode =xml
You could then use an array of strings and fill each string.
Do a detection for a "<" and a ">"
Every time you see a ">" you increase the index in the array.
Then ignore characters until you have a "<".
Then append each character to the indexed string.
Once the array is filled you can parse it line by line and extract the parts you need.
Each string will start with a node name so it is an easy test.
If you want to keep the json you can do something similar by detecting a "{" and a "}". I would also detect an opening " and use a , or } to end a line.
You would then get an array of strings that is very similar to the output of the online json parser.
Edited by TZAdvantage 2014-10-08
viscomjim
Posted: 08:02am 07 Oct 2014
I will have to take a look at the xml format to see what it looks like when I get home. That sounds like it might be doable. I will also try the json one as you recommended to see if I can pull that off. Thanks for the advice!!!
plasma
Posted: 07:35pm 08 Oct 2014
Hi ,
Viscomjim can you show me the source ?
viscomjim
Posted: 12:23am 09 Oct 2014
Hi Plasma, since this post I have switched to www.wunderground.com for the weather data. Here is my new code for that one. Please see that my API key is included in this program. You are welcome to try it a few times as it is good for 500 reads a day up to 10 per minute. However, if you decide to use this more, just get your own key. It is easy and free to sign up and get one. You will also notice my zip code in the api request (Z$). Go to www.wunderground.com and look at the api stuff they have there. It will explain all the cool things you can request.
Still working on a way to get the useful data out of the json return. I looked at the way Geoff is getting data out of the com port buffer from his GPS clock project and suspect that this might be a good way to attack this as there is a lot of data coming back, more that 256 limit on a string. Also notice the rx buffer has been increased to 4096 due to this.
Anyway here is the code, have fun making a weather station.
SERVER$="23.0.88.120"
PORTX$="80"
Open "Com1:115200, 4096" As #1
FLUSHBUF
PRINT #1,"AT+CWMODE=3"
PAUSE 100
GETSTRINGLONG
PRINT #1,"AT+CIPMUX=0"
PAUSE 100
GETSTRINGLONG
Print #1,"AT+CIPSTART="+Chr$(34)+"TCP"+Chr$(34)+","+Chr$(34)+SERVE R$+Chr$(34)+","+PORTX$
PRINT "AT+CIPSTART NOW"
PAUSE 1000
GETSTRINGLONG
Z$="GET /api/2b4e1c4572808d14/conditions/q/33773.json HTTP/1.1"+chr$(13)+chr$(10)+"Host: api.wunderground.com"+chr$(13)+chr$(10)
OUTPUTX Z$
PAUSE 1000
GETSTRINGLONG
Print #1,"AT+CIPCLOSE"
PAUSE 100
GETSTRINGLONG
END
Sub OUTPUTX (OUT$)
Print #1,"AT+CIPSEND=0"+Str$(Len(OUT$)+2)
Pause 200
Print #1,OUT$
PRINT OUT$
Pause 100
END SUB
'**********GETSTRINGLONG************
SUB GETSTRINGLONG
PAUSE 200
PRINT "BYTES IN LOC = ";LOC(#1)
C$=""
DO
C$=Input$(1,#1)
char = Asc(C$)
If char >31 Then Print C$;
If char =13 Then Print " "
LOOP WHILE LOC(#1)<>0
END SUB
SUB FLUSHBUF
DO:A$=INPUT$(1,#1):LOOP WHILE LOC(#1) <> 0
END SUB
EDIT...
There seems to be some extra spaces in a couple of lines in the code. I tried to edit but it won't update so look out for that...
This assumes that you already got your esp8266 connected to your wifi, as it remembers this connection after a power cycle, I don't do it again in this program. If you need info on how to get it going, Oldbitcollector did a wonderful instructable to show you how to do that, and it works great. HERE is the link to that information. I also posted some info in propellerpowered HERE on page 6.Edited by viscomjim 2014-10-10
viscomjim
Posted: 03:17am 09 Oct 2014
In the 11th line of code, the one with AT+CIPSTART, there is extra space at Print and #1 and also in the word "SERVE R$" should be "SERVER$". Don't know why that happened during copy and paste.
Add a weather station to your project for $5.00 and some code. YEAH!!!Edited by viscomjim 2014-10-10
     Page 3 of 7
