Local Time 07:17 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Using HDD motor as generator
     Page 3 of 3
Photobug63
Posted: 04:36am 13 Mar 2010
  Sonny said   You might want to take a look at this.
take a look at this
I went to the link and it didn't have the stats on the 2 full wave bridge rectifiers you need for the project.
Keith
neil0mac
Posted: 05:05am 13 Mar 2010
  Downwind said
For instance more blades should give more start up torque but will spin at a slower top end speed.
Has it ever been suggested that a second set of short(er) blades (equally spaced between thhe others) be used for start up torque - with weighted ends such that they fold in behind the 'speed' blades by cenrifugal force? And re-emerge when the wind speed drops?
(I know, it is a 'way out' idea! Or is it a way out of a known problem?)Edited by neil0mac 2010-03-14
Posted: 05:15am 13 Mar 2010
Neil,
I dont know the answer but it sounds like a good mini mill test for you to let us know on the results.
I to have wondered about lets say 3 short blades between each of the 3 main blades to give starting torque but have no idea of the overall effect this will have on a mill and if it will cause drag at higher speed or not.
I would expect it to work but i realy dont know.
Pete.
     Page 3 of 3
