Local Time 04:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simple
     Page 3 of 3
Posted: 08:10am 12 Dec 2025
There is a bezier command in the code as well, but for some reason it isn't enabled. I'll include it in the final release.
  Quote  BEZIER x%(),y%() [,n] [,colour]
Draws a Bezier curve with an unlimited number of control points. ‘x%()’ and ‘y%()’ are single dimension integer arrays holding the coordinates of the control points.
The Bezier curve always starts at the first control point. The arrays must have the same dimensionality.
The optional parameter ‘n’ defines how many control points to use for the plot. If omitted the size of ‘x%()’ and ‘y%()’ determine the number. N must be >=2 and <= the array size.
The optional parameter ‘colour’ defines the colour to plot the curve (defaults to white)
Edited 2025-12-12 18:23 by matherp
Martin H.
Posted: 08:36am 12 Dec 2025
Good Morning Peter,
That sounds very promising and gives you more scope to read or generate vector-based images.
Thanks a lot
Martin
'no comment
     Page 3 of 3
