Local Time 15:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Playing with Transparency and the Ultimate Game
     Page 3 of 3
Posted: 03:51pm 07 Jan 2024
Hi Pete,
Since I didn't get my Wii classic yet, I have modified the code a bit to support keyboard.
I hope I didn't f^ck up with the changes. I do not have a very fluent play (lagging) yet with keyboard control. Maybe you can check if this is what the Wii version plays.
This is 50800b5 at 252MHz.
LoadRunner09R_kb.zip
vegipete
Posted: 04:30pm 07 Jan 2024
I don't have sound or keyboard hardware on my PicoMiteVGA so I can't really check. Or maybe the console connection is close enough.
Keyboard control will be interesting because movement is remembered. For example, if you press the [left] key to start moving left, that stays in effect until your path is blocked. If you fall off something, your left movement will resume when you land on something. I tried to put enough state information in the actor array to support this. Then I said "lump it" and made it work with the Wii joystick instead.
I think I left all the controller reading calls close together, so hopefully modifications should be easy...
Posted: 04:54pm 07 Jan 2024
And completely in line with controller chaos.....
Here is version 09R with Wii_classic AND keyboard AND Wii_nunchuck support.
Change the constant "cntl" to select the correct controller.
You dig with the large button (Z) on the nunchuck
Next level with the small button (C)
Repeat current level pressing both buttons (Z+C).
LoadRunner09R_kb_nun.zip
P.S. you can use console keyboard.
Edited 2024-01-08 03:01 by Volhout
     Page 3 of 3
