Forum Index : Microcontroller and PC projects : PicoMite: Controllers ... again ;-)
     Page 3 of 3
Hawk
Posted: 11:44am 27 Apr 2023
You could save a whole lot of pins if you just used one of these.
I requires just one analogue line.
Posted: 12:12pm 27 Apr 2023
Oh, there's all sorts of ways to do it. You still can't beat 8 controllers, each that can be used as analogue or digital (like the Xbox) and with over 8 digital inputs all on one I2C port. :)  Ok, you need a PicoMite in each controller if you want the analogue function.
No joystick or controller reads as fast as the switched Atari stick wired to GP pins though.
Oh, and yes - you can use three of those analogue button thingies on the PicoGAME already. :)
stanleyella
Posted: 05:00pm 27 Apr 2023
https://www.ebay.co.uk/itm/334847975412?
@Hawk- do they work like left and right and fire tested for in mmbasic software?
£3, why get a soldering iron out?
Posted: 05:22pm 27 Apr 2023
You just get a different percentage of VCC on the OUT pin depending on which button is pressed. You can either keep sampling an ADC port or, if you want to use more than one, you can get MMBasic to run a round robin sample on how ever many ADC pins you want to use.
The exact voltages you get will depend on VCC. Obviously they will be lower on a 3V3 system than on a 5V system.
stanleyella
Posted: 05:55pm 27 Apr 2023
will order 2. will see. can always rewire for 5 ports. if it's meant for 5V then less accuracy at 3V. only £3 though.
There's discussion about this and all the different adc values and resistor values.
but I ordered the boards. which will be tiny and easier than wiring buttons. not a gamepad but would do as although touch screen "works", it's not the same as buttons
Edited 2023-04-28 06:16 by stanleyella
stanleyella
Posted: 09:00pm 27 Apr 2023
adc=
up or + fire
down  or + fire
left or + fire
right or + fire
left + up or + fire
left + down or + fire
right+ up or + fire
right + down or + fire
just using these combinations is 16 values. Waiting until board arrives to see if the hardware works
Posted: 09:35pm 27 Apr 2023
There are only 2 ways to wire them really. A switched ladder is easy but the last button in the chain overrides the others. Separate binary loaded resistors (1,2,4,8,16), one for each button, let you detect which buttons have been pressed. e.g. reading 5 will indicate that buttons 1 and 4 have been pressed. That's the best way but you need closer tolerance resistors. In both cases you have to compare the voltage value in a window as the resistors may not be well matched.
stanleyella
Posted: 09:46pm 27 Apr 2023
A lot of cases and envelopes but must do something or it not be sold... eright :)
When boards arrive in May, I'll test, I guess I could now with pots.. but can't be
Posted: 01:49am 28 Apr 2023
Looking at the photos of those controllers from various manufacturers what I see is:
All buttons switch OUT to GND via a series resistor except UP which goes direct from OUT to GND.
The series resistors are.
R2 330R LEFT
R3 560R or 620R DOWN
R4 1K   RIGHT
R5 3K3  FIRE
C1 (100n?) from OUT to GND
R1 (1k or 2k or 10k or 01C whatever that is?) from Vcc to OUT.
To standardize the value of R1 put your desired value on your PCB and don't connect Vcc to the controller just OUT and GND.
1k seems like a good value. The approximate output voltages would be:-
UP  0.0
LEFT 0.82
DOWN 1.26
RIGHT 1.65
FIRE  2.53
None  3.3
Select Case with values half way between those should be ok.
UP  < O.4
LEFT > 0.4 and < 1.0
DOWN > 1.0 and < 1.4
RIGHT > 1.4 and < 2.0
FIRE  > 2.0 and < 2.5
None > 3.0
Edited 2023-04-28 13:51 by phil99
stanleyella
Posted: 07:29pm 28 Apr 2023
Nice phil99 , I got to wait for devices to arrive, cheap means long postage.
I run my boards from 3.3V linear reg with 3.3v enable grounded. I wanted a "clean" 3.3V ref. This has been done before for a-d.
Posted: 10:53pm 28 Apr 2023
Spotted a mistake. Change FIRE to < 3.
UP  < O.4
LEFT > 0.4 and LEFT < 1.0
DOWN > 1.0 and DOWN < 1.4
RIGHT > 1.4 and RIGHT < 2.0
FIRE  > 2.0 and FIRE < 3.0
None > 3.0
These could have been designed to allow diagonal moves. If the fire button was the one that goes straight from OUT to ground the series resistors for the four direction buttons could use binary sequence values. Then more than one button could be pressed at the same time and be correctly decoded.
Edited 2023-04-29 09:27 by phil99
     Page 3 of 3
