Local Time 00:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Would SomeBody Try ........
     Page 3 of 4
hitsware2
Posted: 08:53pm 07 Mar 2023
  matherp said  Yes but then you can re-connect
O.K........
After re-connect :
option list only gives version ( not US keyboard ( as before ) )
No keyboard disabled ...
AND
Editor still the same ...
my site
Posted: 09:21pm 07 Mar 2023
That makes sense if you hadn't got a PS/2 keyboard connected. Now it's disabled the IO pins and you won't get stray signals on them. Check with MM.INFO$(PINNO GPn) for 8 and 9 and they should both be "UNUSED".
*Can* you check the PicoMite with Win 10 and Tera Term? I know you want to use it with a Pi, but we have to rule something out. At the moment we have too many variables.
Posted: 09:52pm 07 Mar 2023
If you have some special reason not to try Win 10 and Tera Term then load a different OS on one of the RPi's to see if that makes a difference.
Two Pico's and RPi's doing the same thing excludes a hardware problem. Many people are using the VGA firmware connected a wide variety of computers so it is unlikely to be that.
As previously noted the only common factor is the OS so change it.
hitsware2
Posted: 09:59pm 07 Mar 2023
Works good with my Wife's Win10 / Tera Term .....
my site
Posted: 10:20pm 07 Mar 2023
Connected to the Pi4 you have the Pico (via USB) and what is connected as your Pi terminal/console? What's displaying the bad stuff you see & how is it connected?
Posted: 10:57pm 07 Mar 2023
Ok, so the PicoMite is fine, it's working as expected.
Make sure that the terminal emulation settings on the Pi are set the same as they are in Tera Term. In particular check that you send CR on transmit and use CR to indicate end of line on receive. Check terminal size (rows, columns) and start & stop bits too while you're at it. You need to get the connection as close to Tera Term as you can.
It probably doesn't matter which terminal emulator you use. They will all use the same  device, but you may get different facilities.
Do you have to do something special on the Pi to route serial via a virtual serial port over USB? Linux is designed to use "real" serial devices. It's been ages since I used a Pi - and I've never used USB serial or had a Pi4.
Posted: 06:24am 08 Mar 2023
Worked with serial terminals for decades. Tried the lot on linux. Minicom, gtkcom, ktcom, screen... and settled on putty.
There is 1 shortcomming in putty: you cannot set a end of line delay, or character delay.
A shortcomming of linux is it closes the USB port when the peripheral restarts. With a MM2 that is rare, there is a dedicated USB setial convertor. But the RP2040 restarts USB when it restarts MMBasic. This happens when OPTIONs are set.
Posted: 09:47am 08 Mar 2023
  Mixtel90 said  Make sure that the terminal emulation settings on the Pi are set the same as they are in Tera Term. In particular check that you send CR on transmit and use CR to indicate end of line on receive. Check terminal size (rows, columns) and start & stop bits too while you're at it. You need to get the connection as close to Tera Term as you can.
All good ideas - though I've not needed to do any of those on a (PC-based) Linux.
The reason I asked what he's using on his Pi4 is that I have various Pis but none connected to a display device (or connected at all) right now so as-is I can't reproduce what he's doing.
  Mixtel90 said  It probably doesn't matter which terminal emulator you use. They will all use the same  device, but you may get different facilities.
Yes.
  Mixtel90 said  Do you have to do something special on the Pi to route serial via a virtual serial port over USB? Linux is designed to use "real" serial devices. It's been ages since I used a Pi - and I've never used USB serial or had a Pi4.
Not really right: at the program level it hardly ever knows whether a device is real or not & rarely cares.  So, you just tell a terminal emulator a file name (which is typically a device file name) and it does its stuff.  It really doesn't care what you gave it so long as that thing (device or file - same thing in Linux) follows the usual API behaviours.
In this case, because MMBasic on a Pico via USB enumerates (identifies itself) as an ACM you would normally have Linux (usually Linux default behaviour) create a file along the lines of ttyACMx (x being 0 or 1 or ...) and in the /dev folder.  So, you'd use a command like
screen /dev/ttyACM0
It actually doesn't matter how it's connected (USB or whatever, but here it will be via USB).
It's the same on my laptop.
(There are things knows as rules, kicked into action by the USB device enumeration, which make this "just happen".  Clearly these are working.)
Edited 2023-03-08 19:48 by JohnS
hitsware2
Posted: 08:18pm 08 Mar 2023
O.K.
Tera Term w / Win10 sets terminal size 81 x 40 ( font size 9 )
What happened to 80 x 24 ?
Works on RPi   .... Though font is too small for my eyes
Why would the VGA version work different than the other version as
far as the editor ( on the PC screen ) ?
Is maybe the editor screen geared for the VGA display ( or some such ) ?
my site
Posted: 08:47pm 08 Mar 2023
VGA on the picomite does not support true type fonts that can be scaled to your liking.
The editor is designed to work optimal with font 1 (12x8 pixels) representing a 80x40 character screen on the 640x480 VGA resolution. The editor will also work with mode 2 (320x240).
Posted: 08:52pm 08 Mar 2023
You should be able to set Tera Term's terminal window (in Win 10) to 80x24, I think. That's the PicoMite default for the console. You can also change the font used. I listed my settings on the first page of this thread.
PicoMite VGA doesn't have OPTION DISPLAY. You can only use its default so you have to get your terminal to suit it. (I just looked in the VGA 5.07.04 manual). It will default to font 1 (8x12).
Edited 2023-03-09 06:54 by Mixtel90
Posted: 08:54pm 08 Mar 2023
If you are not using the VGA screen for the editor, just the USB then the window size can be made adjustable. Otherwise it is locked to the Mode setting.
Manual p53
OPTION LCDPANEL NOCONSOLE then
OPTION DISPLAY lines
[,chars]  Set the characteristics of the display terminal used for the console. Both the LIST and EDIT commands need to know this information to
correctly format the text for display.
'lines' is the number of lines on the display and 'chars' is the width of the
display in characters. The default is 24 lines x 80 chars and when
changed this option will be remembered even when the power is
removed. Maximum values are 100 lines and 240chars.
This command is only available if the display is not being used as a
console by setting OPTION LCDPANEL NOCONSOLE
hitsware2
Posted: 09:06pm 08 Mar 2023
Bingo ! .... The editor matches VGA rather than the specified ( console ) 80 x 24
AND .... That does't work right with SCREEN .... ( As does the non-VGA version )
Tera Type ( evedently ) sets itself to match .
Do You have a RPi ? .... 4-B or 400 ?
AND :
> option lcdpanel noconsole
> option display 24,80
Error : Invalid Option
> option display 80,24
> option display 24, 80
> option display 24 80
Edited 2023-03-09 07:27 by hitsware2
my site
Posted: 10:34pm 08 Mar 2023
The VGA version can only support the character width and height that matches the VGA screen. Hence OPTION DISPLAY is disabled. It sends to the serial terminal commands to configure the terminal to the correct format. If you terminal program does not accept those commands you will have a problem. Teraterm and Putty on Windows both accept the commands.
Posted: 10:47pm 08 Mar 2023
  hitsware2 said  The editor matches VGA rather than the specified ( console ) 80 x 24
I use screen most of the time, with PicoMite VGA.
It just works, including in EDIT, with coloured text.
If it doesn't work for you I think you're still looking for some specific reason why.
I've also used putty and it worked too.
Edited 2023-03-09 08:48 by JohnS
hitsware2
Posted: 11:25pm 08 Mar 2023
With a Raspberry Pi ?
Which OS ?
my site
Posted: 11:32pm 08 Mar 2023
As I posted before - I can't reproduce what you're doing using a Pi because I don't know what you have connected to your Pi (I did ask you), so I'm using a (Linux) PC.
Edited 2023-03-09 09:32 by JohnS
hitsware2
Posted: 11:34pm 08 Mar 2023
have a problem.
Thank You ! ...... I think that covers my situation ..
How nice for Bill Gates
my site
hitsware2
Posted: 11:40pm 08 Mar 2023
  JohnS said  As I posted before - I can't reproduce what you're doing using a Pi because I don't know what you have connected to your Pi (I did ask you), so I'm using a (Linux) PC.
RPi 400
Latest RaspBerry Pi OS ( 32 bit )
my site
Posted: 11:57pm 08 Mar 2023
  hitsware2 said  RPi 400
Please see my original request about what you have connected to it (apart from the PicoMite).
     Page 3 of 4
