Forum Index : Microcontroller and PC projects : Simplest possible PicoMite VGA hookup ......
Hi hitsware, Picomite has some OPTION settings that reboot the picomite. With putty and maybe minicom, you loose the usb connection, and have to reconnect to the picomite. This is only when changing OPTIONs that configure the hardware. Such as: cpuspeed, sdcard, system i2c, audio. Other options like rtc, colorcode etc.do not reboot the picomite. Volhout PicomiteVGA PETSCII ROBOTS |
