Local Time 23:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb alphas a14+, now with added Telnet
     Page 3 of 5
Posted: 10:15am 16 Feb 2023
  Pluto said  Pico W crash
Can the odd crashes be caused by Wi-Fi Reliability?
  Quote  One reason why programs fail over a long period of time involves Wi-Fi reliability. If your Wi-Fi becomes unreliable, the Pico W's first instinct is to crash.
/Pluto
I can't be sure but I think that's one person's (somewhat workable) ideas but I wonder if the RPi foundation would say otherwise? Preferably with a better work-around!
If lost, you'd hope that the connection could be re-made & the transfers resumed.
atmega8
Posted: 02:18pm 16 Feb 2023
print mm.ver
5.070716
Why this?
OPTION WIFI pabu19, mypassword
Error : Expected a string
What is wrong?
Edited 2023-02-17 00:20 by atmega8
atmega8
Posted: 02:23pm 16 Feb 2023
OPTION WIFI "pabu19", "mypw"
PicoMite MMBasic Version 5.07.07a16
OPTION WIFI pabu19, *****************
OK, but how can i connect?
twofingers
Posted: 02:46pm 16 Feb 2023
@atmega
After OPTION WIFI pabu19, *****************
and a restart you should be connected.
The Pico shows the IP.*
Michael
EDIT:
* You should see the message "Connected 192.***.***.***". (See the first page of this thread.)
You can then activate the telnet mode (e.g. Option Telnet Console ON) or/(and) install a website (HTML + .bas) on the Pico's flash drive (Xmodem).
Edited 2023-02-17 00:58 by twofingers
atmega8
Posted: 03:07pm 16 Feb 2023
  twofingers said  @atmega
Michael
EDIT:
Got it,
THX
Posted: 05:25pm 16 Feb 2023
Please try the attached - it has lots of diagnostics enabled.
PicoMiteWeb (2).zip
Set to TELNET ONLY but open a USB connection then run your program from Telnet.
You should see lots of diagnostics on the USB console.
You can disconnect and then reconnect the Telnet console - that should now be benign
If/when it hangs up then perhaps we can see what is happening.
Thanks for your help
Doktorn
Posted: 06:24pm 16 Feb 2023
I don't know if this have anything to do with the Wi-Fi reliability but I change the setting on my AP to 802.11 N only.
Now my Pico W have been running open weather API ( update every 5 min ) for more than 12 hours.
Posted: 07:59pm 16 Feb 2023
  matherp said  Jim
Will do but it won't be until later today. About 10 hours from now.
Posted: 07:20am 17 Feb 2023
Attached is a log file.
log_170223.zip
I have noticed that when my bas program stops during WEB TRANSMIT, the pico heartbeat stops but the logging continues, faithfully logging the Telnet keep alive bytes every 5 minutes.
I also loaded micropython onto one of my picoWs and ran an example program. The python web server is no faster than the MMBasic one. Possibly slower to return a page than the MMBasic so I can't see much improvement likely. Hopefully, I am wrong)
I will leave the system running over night with the web access turned of to see if it locks up on it's own.
I also need to change MMEdit so capturing logs includes the timestamp.
Always something to do...
Posted: 12:07pm 17 Feb 2023
Eureka
I hope
Analysing the various outputs and tuning the diagnostic prints I think I've established that on occasion browsers will make a connection but not send any data. Up until now the firmware only closes the connection when MMbasic responds to a request. I've now put a timer on each connection. The timer is reset whenever activity takes place on the connection but if there is no activity for 5 seconds I now close the connection.
Currently I have 4 different browsers running a total of 7 copies of Jim's program with the addition of the tiger picture and it has been running for 20 minutes. Previously this sort of load would crash it pretty quickly
Keep you fingers crossed. If I make the 2 hour mark I'll post an update
atmega8
Posted: 02:47pm 17 Feb 2023
  matherp said  Eureka
I hope
Keep my Fingers cross ;-)
THX for all you are doing for this awesome MMBASIC
Dietmar
Posted: 03:05pm 17 Feb 2023
V5.07.07a17
PicoMiteWebV5.07.07a17.zip
If TCP server mode  is set on your Pico then after installing this please execute the command
OPTION TCP SERVER 80 [, timeout]
BEFORE DOING ANYTHING ELSE
This is needed to set the timer used to close stuck connections. The time is in milliseconds and defaults to 5000
Otherwise you should not see any differences between this and a17 but there is a major re-write of the TCP server code under the covers
There are three conditions that are now handled
1. a client connects but does not send a request
2. a client connects and makes a request while you are running a program but you don't respond within the timeout period
3. a client connects and makes a request while you are at the command prompt
The server now acts as follows:
1. the connection will timeout based on the timer set in OPTION TCP SERVER and be closed completely transparently
2. This causes an error condition - you will get the Basic error "Error: No response to request from connection no n"
3. the server will automatically send a 404 code (page not found)
I have run this with a number of browsers updating every 10 seconds and it seems stable. You can of course overload the ability of Basic to respond to the incoming requests in which case you will see an error but hopefully this is more robust than before.
Edited 2023-02-18 01:05 by matherp
homa
Posted: 03:46pm 17 Feb 2023
Thanks Peter,
also for the detailed explanation.
I started a long term test with the a16 yesterday. Only USB console, the small web sample program, and only firefox browser from my PC, laptop, and mobile. My network is running streaming, sip telephony, and 3 kids :-)
I once recorded the different access times from the PC.
Test of a string: mystring is 16-02-2023 18:39:29
Test of a string: mystring is 16-02-2023 19:00:23
Test of a string: mystring is 16-02-2023 21:03:06
Test of a string: mystring is 16-02-2023 21:52:46
Test of a string: mystring is 17-02-2023 07:16:04
Test of a string: mystring is 17-02-2023 08:27:52
Test of a string: mystring is 17-02-2023 16:11:26
Test of a string: mystring is 17-02-2023 16:16:03
Test of a string: mystring is 17-02-2023 16:37:06
That's almost 24h of stable running.
Almost funny, just now as I am writing these lines the error message appears in the console:
String is POST / HTTP
sending page
Error: Invalid address - resetting
PicoMiteWeb MMBasic Version 5.07.07a16
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
Connecting to WiFi...
Connected 192.168.1.109
Starting server at 192.168.1.109 on port 80
> run
> load "server2.bas
> run
ntp address 172.104.134.72
got ntp response: 17/02/2023 16:42:55
By the way, I run the Picomite at its default frequency.
Now I will repeat the whole thing with the a17!
I deactivated and reactivated the tcp server option as a precaution.
Above in your example the port is missing, I thought you have a new syntax.
Then when activating the Picomite crashed!
I had to unplug the USB and plug it back in (---X---).
> option list
PicoMite MMBasic Version 5.07.07a17
OPTION COLOURCODE ON
OPTION WIFI xxx, *****************
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
> option tcp server port 0
> option list
Error : Expression syntax
> OPTION TCP SERVER Port 80, 5000
(---X---)
PicoMiteWeb MMBasic Version 5.07.07a17
Edited 2023-02-18 01:58 by homa
Hans
Posted: 05:02pm 17 Feb 2023
  matherp said  V5.07.07a17
Just tried and ....
1) You get a syntax error without the word "PORT"
2) The timeout does not show with the OPTION List
Thanks,
Hans ....
Posted: 05:13pm 17 Feb 2023
  Quote  You get a syntax error without the word "PORT"
Typo in my post - sorry
  Quote  The timeout does not show with the OPTION List
Will fix but like all options it will only show if not default (5000)
PS I'm probably going to change this anyway to allow 3 ports to be used
Telnet, HTTP, and other
Edited 2023-02-18 03:15 by matherp
bigfix
Posted: 05:18pm 17 Feb 2023
  Quote  PS I'm probably going to change this anyway to allow 3 ports to be used
MQTT would  be great for IOT devices
Became a de facto standard in home automation/control
Tasmota and many proprietary actors/sensors support it
They could then act as I/O to the WEBmite
Hans
Posted: 05:19pm 17 Feb 2023
I did test that, it was set to 6000 when it did not show.
Hans ...
Posted: 06:41pm 17 Feb 2023
After flashing a17 and running "OPTION TCP SERVER PORT 80, 6000", when I run the program I've been testing, after I enter "192.168.1.224" in the browser window, I get:
Connected 192.168.1.224
Starting server at 192.168.1.224 on port 80
(I'm also not seeing the ", 6000" when I do OPTION LIST.)
Posted: 07:56pm 17 Feb 2023
V5.07.07b18
PicoMiteWebV5.07.07a18.zip
Fixes the display of the timeout + big speed improvement in displaying web pages and small images
To ensure you have a clean start this will delete all options but not the flash disk
Clearly I don't get that. If you see that sort of issue use clean_flash and start from scratch. If that doesn't work I would need much more information on the sequence that created the issue.
homa
Posted: 08:59pm 17 Feb 2023
WOW, incredible the speed increase!
A small glitch, when entering: OPTION TELNET CONSOLE ON
picomite stopped working.
Restart and entered more OPTIONs - running!
> option list
PicoMite MMBasic version 5.07.07a18
OPTION COLORCODE ON
     Page 3 of 5
